Match's Mods: Homemade Integrating Sphere
I’d love to make one of these spheres, but I just can’t justify the money for lights I’m going to get rid of anyhow. :frowning:
From a pure marketing standpoint, I don’t see how you can’t justify making one.
Nudge, nudge.
For all you intelligent guys out there, this might help with using Barium sulphate or Potassium sulphate coatings in a sphere.
It's all way beyond me, but it looked good, LOL.
EDIT:
Also, here's a recipe for making a stronger paste, for paper mache'
and here's where to get the "resin glue".
You know, if I've gone this far.......
Imused white glue and water with newspaper on mine. Took forever to get enough layers on it to be stiff enough on its own.
Ya, but you know me... Have to do it differently. Like making the first layer of newspaper out of "gores", so the inside has very neat seams. Using the weldwood for stiffness and longevity. Using some type of fabric like denim or strong cotton, for more stiffness, etc, etc, etc. LOL, it's got to be a challenge and it's got to be a one of a kind. I just don't know any different.
What it the wavelength range of “white” leds. From 3000k to 7000k.
500nm to 700nm?
I’m looking at all possible coatings and just want to know the range. I don’t expect I would do any testing on RGB leds.
Almost all the light for white LEDs of any color temp is between 425 and 750 nm. There is a pretty significant peak at 450 nm and virtually nothing below 425 nm.
So when you shine the light inside the sphere, do you shine it straight at the baffle? I'm assuming so given the point of it is to stop light going stright from the torch to the sensor.
Defintely building one of these :)
- Matt
No, you shine at the opposite wall. The baffle actually means an imperfection in the sphere geometry and thus is something bad, but direct light from source to detector is much worse.
What about making the first layers out of white paper?
I want such a sphere too and I thought that if we all get our olight i6s(I guess a lot of us have ordered this light) we can calibrate our spheres to each other…
I just found and read through this entire thread. And dangit! Now I’ve got to build one too! Wouldn’t ya know my son just burst a 20” rubber ball and we threw it away?
Subscribed.
Figured I’d give this thread a good ol’ necro bump.
Going to try my hand at making one of these spherical beauties in the coming weeks. No idea what I’ll use for the calibration… And I’ll need a light meter!
Funny, I just started at one just yesterday, before you dug this thread out :-) , only 25 cm (10ish inch) diameter because I do not have space for a bigger one, but using the 'match' method. No idea when it is ready, or if it is any good at all, but it has been a loooooong time since I last did paper mache :-)
Barium sulphate,out of date epoxy/polyester resin is quicker and stronger,after an initial papier mache layer,ping pong ball for light baffle,it's round so no direct reflections.Also,I might make a second light meter hole just to check the readings are the same.In theory,an IS puts out an even spread of light everywhere,that's the point!Always good to check.I stuck a layer of plastified foil(ground coffee packet)opposite the light source on the principle that ,for any excaping light through the sphere,throwers will lose more than flooders and hence underread.Opinions welcome
Considering that you can buy a 16” strofoam sphere for $40, I would not waste my time messing with paper mache, etc. The styrofoam spheres that are now available seem to all be made with a flat surface on the ends of the interior. I made a sanding jig by tracing the sphere inner radius onto a 3/4” thick board, cut the board, placed sandpaper over the edge, and sanded the flat spot to match the sphere radius.
Instead of barium sulphate, a light sanding with fine sandpaper on the interior of the styrofoam sphere will remove the sheen and perform pretty much as well as the sulphate/latex paint coating.
Epoxy/polyester can yellow with time. I would not use it.
How much to ship that foam to Canada, plus styrofoam does not reflect all the light striking it, i have styrofoam boxes that i can put a light in and see maybe 10% coming out the other side (maybe 3/4 thick), i would assume the paint will reflect more of the light, now mind you if the light penetration is linear with increasing brightness then a calibration should compensate when taking readings, if i had some calibrated lights of very varying brightness it would be a worthy experiment (unless you already did it and have data to share)
The reflectivity of the styrofoam is not much of an issue… it drops out when you calibrate the sphere.
With my sphere, I can do around 5000 lumens with the sensor mounted in the sphere. With the sensor mounted on the outside wall (using the styrofoam as a light attenuator) I can do over 600,000 lumens. The sphere is absorbing over 99% of the light.
Styrofoam is light… but bulky. Shipping to Canada should not be to bad. You might be able to find a local seller.
The reflectivity does matter in the type of IS we are building.
Not having build one myself I do not know how much it matters, but in this type of sphere the detector 'sees' the first reflection of the light. There are two scenario's in which that is not a problem: 1) the detector (luxmeter) is not angle-sensitive, i.e. it reads the same value for all incoming angles, or 2) the reflectivity is near 100%. If that is both not the case, the integrating sphere will be more or less sensitive to beam profiles: throwers will read different from flooders or bare leds. And that is precisely what we want to cancel out by using an IS.
At least my cheap luxmeter is not quite angle-insensitive, I found, so if I build an integrating sphere for it, I will pay attention to a good reflectivity of the inner surface.
Again, it may be a bit theoretical, and in practice may not matter that much, but in theory at least a not optimal reflectivity is not just a matter of a different correction factor.
Annnnd, now I have a desire to build IS. God dammit guys, you have a negative influence on me :bigsmile:
Luckily those fitness balls are way too expensive to destroy one…
I contemplated using one of those that had been torn. Patch it up and inflate it just enough to get a sphere. Probably would be far too big to be practical, and it got thrown away anyway. :frowning:
