New XinTD C8 V3, deeper reflector? More throw?
48 posts / 0 new
Rockspider
Rockspider's picture
Last seen: 1 year 3 months ago
Just stumbled upon new version V3 of the well known XinTD C8 at IntlOutdoor.
The pictures of the new deeper reflector looks promising, anyone has noted this before?
Previous version was nice and throwy but personally did not like the beamshot, a lot of rings and artifacts.
Hope this one is better!
Does anybody has bought one yet?
Link:
New XinTD C8 V3
bose301s
bose301s's picture
Last seen: 4 weeks 21 hours ago
Looks nice, assuming it will still be out thrown by the HD2010 and others though.
Rockspider
That’s a completely different animal, much larger reflectored 26650 light that works also on 18650, not a fair competition to me…
I would like to see how better the V3 beamshot is compared to the older version, but don’t expect it to beat a 7G5 in throw… Wink
The XinTD C8 I had was nicely driven but the reflector was inferior to the Ultrafire C8, it had a larger hotspot with lots of rings, so I ended up swapping the XinTD pill into the Ultrafire body and reflector, so I got a “perfect” C8, with tight hotspot and nice clean spill “almost” ring-free.
…maybe I’ll end up buying one just to compare to my modded one!
agedbriar
I have a Manta Ray XM-L C8. The reflector is of standard C8 width, but somewhat deeper. Compared to a regular C8, this one yields a wider and brighter corona, which makes a very nice beam for walks, as it lights up the path length pretty uniformly thanks to the additional intermediate brightness level. No gain in throw, though.
Loris
Last seen: 3 years 6 months ago
I’ve got one, seems to throw more than the other C8s I have, there is a hole in the beam shining against a wall which the other C8s don’t have, but it’s not noticeable when used.
mertinator
mertinator's picture
Last seen: 3 years 8 months ago
I have the V2 and I am also curious on how much the V3’s beam has changed.
...and God said: "Let there be light!" and there was budgetlightforum! Smile
DrJones
DrJones's picture
Last seen: 2 years 2 months ago
Reflector depth has only a minor influence on throw. Diameter is most important. (more info here)
Vectrex
Vectrex's picture
I own the V3 NW 3-mode... the beam is pretty much perfect... in fact it is a little too throwy for my taste. No rings... much better thrower than the KD C8, but it isn't as throwy like the UF C8 XR-E  from Ebay which is to be expected. I highly recommend the V3 NW 3-mode (high PWM) ... my almost perfect light. I would rate the perfection level over my (not so similar) DQG III NW and the Shiningbeam S-Mini II which are the runner ups.
Suncoaster
Suncoaster's picture
Last seen: 2 weeks 6 days ago
Location: Where the girls are green and the grass is pretty.
Just received the XinTD V3 with a T6 C3 Neutral White tint, 2 mode, from int-outdoor.com
Thanks to Jeansy’s review.
This is easily the best C8 type light that I have, out of these:
2 Ultrafire C8 XM-L T6
1 Ultrafire clone C8 Q5
1 Ultrafire clone C10 XM-L
and may even best this:
1 Ultrafire UF-980L
It has great tint, and wow factor after dark, lights up the whole street.
I will eventually do some beamshots and tailcap readings, as I’m curious now.
I’m using these protected Blazar batteries, based on the Panasonic NCR18650A 3100mAh, from an Aussie seller (supersports600) on ebay.
"In the land of the blond the one eyed man is king."
*This message is protected with ROT26 encryption.Old Lumens
rikr
rikr's picture
Last seen: 3 months 5 days ago
1 Ultrafire UF-980L
I have the new V3 and the 980L and the 980L is still the better thrower…
SashiX
SashiX's picture
Last seen: 4 years 3 months ago
Interesting. I’d say 980L throw better because it’s DD on HI, right? (or 980L has more concentrated beam? Flat Stare )
rikr
rikr's picture
That’s what I said, the 980L throws better
Ptery83
Last seen: 5 years 1 month ago
Can anyone give a firsthand comparison of this new V3 vs. the Romisen T-601 U2?
SashiX
SashiX's picture
because of DD on hi or because of more concentrated beam?
Yup, +1 for that comparison (980L, XinTD, Romisen and… HD2010 :bigsmile: )
stevetexas
Last seen: 4 years 10 months ago
I was one who bought one of the very first XinTD C8 style flashlights.
Some persons have said that they saw a Green Ring in the beam.
If you change the position of the LED to the Refelctor that problem will go away. The problem is that the pill is screwed to far in, in relation to the reflector.
It took me half an hour to screw it UP grins
d337944
Last seen: 3 years 5 months ago
Hi all
I’ve got one of these V3 versions, and am more than happy with it for the money paid! I bought one of the “scratched” ones that Hank was selling off for a while, but that didn’t affect the performance. Mine came with a scratched lens though, but Hank threw in a replacement lens with my next order.
The beam is just fine – there are no rings at all. The only “issue” is that the hotspot is not perfectly focussed … you see a defined circle at the centre of the hotspot, then the wider spread of the beam. I’ve played with unscrewing my reflector, but that made it worse so I’ve left my reflector screwed in as much as possible and it is perfectly acceptable.
From my experience in playing with various P60 drop-ins, it seems that either the reflector is not exactly matched to the LED used, or the reflector (in this case) needs to be screwed in more … which is not possible.
But the throw is great! It out-throws my second-hand Malkoff Hound Dog XML (which is not a cheap light!), and also out-throws everything else in my collection except for my dedicated modded Mag thrower with XP-G. Very impressive indeed.
The only other issue I’ve had is an apparent loose solder joint at star 4 on the driver … I ordered a 2-mode, but on several occasions it became a 5-mode by itself, then changed back! I’ll have to find someone to fix this for me, but should be easy.
So, if you want a small (smaller than the 980L … which I don’t have) single 18650 thrower, I highly recommend the XinTD C8 V3! Couple this with the great reliable service from Hank at IO, and you have a definitely worthwhile purchase!
Cheers
d337944
d337944
No worries aL1, my experience (even with the couple of issues) has been excellent with the XinTD C8 V3, and also with Hank at International Outdoor.
I forgot to mention that the XinTD is also a very solid, thick-walled light, and the fact that the reflector screws on to the pill … which then screws into the host, means great heat-transference compared to those push-in / push-on type reflectors. It feels hefty and reliable in the hand, and also the switch is quite a beefy unit and should hold up well in time.
Still a great reliable buy in my mind … no gambling with quality issues or variable driver performance with some other similar throwers out there!
trooplewis
trooplewis's picture
I’m so tempted to get V3 (really like the original), but the HD2010 I just got is so awesome (even on 18650 batteries) I might have to get another one of those instead.
Rats, finally sold my 2010 509hp Mustang...now I can buy more lights!
Sold the red one too! Now guess what I drive, doing my penance for 500 hp commuters...
http://dreammustang.com/
http://i884.photobucket.com/albums/ac47/Ha
SashiX
SashiX's picture
No, it’s not an “issue”, d Smile It’s just a different reflector. Could be that, a “not exactly matched” reflector for the LED, but for me, this type of beam is quite useful, actually. It combines throw and flood.
Suncoaster
Cheers
d337944
+1.
I love my XinTD C8 V3 (Neutral White 3C mmmm.)
I also love my 980L.
I must point out that the 980L is a little smaller than the XinTD C8 V3:
L-R: Clone C10, Clone C8 Q5, Ultrafire C8 XM-L T6, XinTD C8 V3, Ultrafire UF-980L
d337944
Hi mate – gee that 980L really is smaller than the XinTD! Thanks for that info mate – I don’t own a 980L and was going by what someone else reported.
Nice collection you have there too!
Cheers
d337944
Suncoaster
Yes, the 980L was smaller than I expected, and the XinTD larger !
I’ll bet the HD2010 is smaller than it appears online too….
visigoth
Last seen: 5 years 7 months ago
Has anyone had a chance to compare V2 to V3 yet? I have the second version, and if I had any complaint it was the reflector — rings in the beam — although I stippled the surface with hairspray to make a DIY orange peel, and it’s pretty nice now.
visigoth
I received an emailed notification that someone had responded to this… yet nobody has. Very perplexing.
I’ll ask again, however: anybody here have experience of both versions?
Oh, and would it be possible to put the new reflector in the older version? (Doesn’t look it — seems you’d have to replace the whole assembly.)
BanglaBob
Last seen: 9 hours 59 min ago
_
d337944 wrote:
Hi all
I’ve got one of these V3 versions, and am more than happy with it for the money paid! I bought one of the “scratched” ones that Hank was selling off for a while, but that didn’t affect the performance. I highly recommend the XinTD C8 V3! Couple this with the great reliable service from Hank at IO, and you have a definitely worthwhile purchase!
Cheers
d337944
Just like d337944 I got myself one of those “scratched” V3’s. It’s a darn good flashlight, for the money I paid. It’s well made, bright as anything and can be ordered without those annoying blinky modes. I got the 3 mode version (low-med-hi). The beam pattern is not bad at all and it throws pretty good too. I’ve owned a couple of C8’s in the past (which I’ve since given away) but this one’s the best.
Lights out! That's when things get interesting...
Ecig
With such fancy internals, they could have done some better design.
For example something like this http://www.dinodirect.com/flashlight-led-multifunction-1000lm.html
If it wasnt to expensive for me for such light, I would take it. Reflector is very important Smile
visigoth
So, just for the hell of it, I unscrewed the reflector completely from my V2. Makes for a really nice mule: perfect circular wall of light.
I find that even the neutral XML has a bit of a green corona thing going on, which disappears when you take out the reflector. I suppose the only downside, mulewise, is that the emitter’s a bit far back from the opening. Also, you need some sort of spacer to keep the lens tight against the front o-ring — I figure I’ll just find a rubber washer the right size, if I decide to keep it like this.
f42
Last seen: 2 years 1 month ago
I have two questions for those who owns XinTD C8 V3, the driver in the picture below directly touches to the battery? Is there a seperate battery compartment? (Inside the battery tube)
And is this light suitable for Mountain biking ? (Lots of shocks, tremors and shakes etc.:)
Thanks in advance!
Nationalism is an infantile disease. It is the measles of mankind.
Albert Einstein
Vectrex
Vectrex's picture
A small foam disc might be a good idea, preventing the battery smacking into the 7135 chips of the underside of the driver on rough landings.
f42
Also something like this :
Albert Einstein
thomasdeurne
Last seen: 2 years 10 months ago
i’m thinking to buy this light with cool white led, but i already have a ultrafire C8 with xml-t6, but i measured the tailcap yesterday and my multimeter says 1.12, so i think that it means that my xml-t6 is only driven at 1.12A? correct? so would it be a big difference if i buy the XinTd?
greetz thomas
