I’m interested to see if the amperage is adjustable with the trim pot on the board. I will be testing that tomorrow. Depending on that, I might either use that board, or use a 7135 board.
OH, the lens measured 54.7mm and the overall OD of the reflector is 60mm, but the lens sits down into the reflector, so the usable diameter is 53mm. I still didn’t measure the depth.
The LED voltage measured 3.34vdc under load. High setting on LED.
Pad on heat sink, that star touches against. I'm thinking of milling (dremel), it down and just make a copper one, the same thickness, but fills the whole bottom diameter. Not sure yet, but that's my inclination right now.
I tested the board trim pot and it is for the LOW setting. The HIGH setting is non adjustable and still reads 1.8+A, so I guess it will have to go and be replaced with a 7135 driver. If I knew electronics, I could probably just change out one of the resistors, but that's way beyond me.
Was thinking about it further, you could probably improve the thermal contact and heat performance with a little dremel work.
Cut the 3x screws that attach the star to the reflector. I would leave the screws in the reflector and just dremel off the philips heads. Use a damp sponge to keep the metal cool as your dremel does its thing. You don’t want to melt and deform the reflector plastic. Use whats left of the screws to center position the LED in the reflector. That will create a flat heatsink-star plane. Next grind down the rectangular pedestal on the cast heatsink, go slow and make sure its a flat surface. Next grind down the 3 posts on the reflector, little by little until you get the LED star to sit flat against the heatsink. You might have to shorten the 3x remaining screws by the height of the removed heatsink pedestal. A little dab of AS-5 or heatsink grease and youre good to go. If you did this you would have the same thermal design as the home depot Defiant.
EDIT You might have a lose fitting lens after doing this. It looks like the reflector presses firmly against the glass. With the removed heatsink pedestal, you’ll be shortening the overall height of the LED+reflector stack by the thickness of the removed metal.
A mod like that might be just enough to alleviate the angry blue-ness from the XPC (if you wanted to keep it in there).
Sounds like an excellent mod. The Nichia 219 is a good one.
Does anyone sell the 219 with a cooler color temp?…. around 5000K?
Awesome mod… I might give this one a try too. I’ve got enough spare eneloops just laying around, and I have a spare XML-T6 in 1A tint. That would be an EASY drag and drop mod to double the lumen output., if you skip the dremel work.
I’m willing to bet this light was designed and manufactured by the same folks that did the Stanley fat max. I am seeing a lot of similarities between the two.
-It looks like they spent similar efforts in the thermal design.
-The trigger lock mechanism is identical
-Lite-trend is also the supplier for the stanley XML star
-Nearly identical hand-grip shape
-Trigger switch design is identical
-Identical use of a thin O-ring gasket around the lens
-Reflector shape and design is nearly identical, just scaled down in size
-The circuit board looks to be comparable quality, and overall complexity too.
Curious is it possible to turn that trim-pot around and get more than 1.8A… turn the LO into a HI for an XML?
Whats the little red LED for? Does this light have a charge port, or 12V cigarette lighter cable?
Great dissection O-L and good luck with the 219 mod… I expect greatness, thats a GREAT led.
The red light just turns on, when the light is on.
I am sure, like many other things, there’s only so many places that actually manufacture and they do it for many companies and either change the labels, or the colors, etc. It’s done all the time and has been for a long time.
Nope, not an XM-L. Heat is the factor here. Sure there is a heatsink, but it’s cheap cast aluminum EDIT: (Or Die Cast Metal, which would be useless for heat transfer), so it won’t transfer heat very well. Also it’s very thin and has no real mass. The heatsink can take heat from the LED, but after that, there’s no where to go. The outer shell is rubber and plastic (both are insulators), so the heat will be trapped. I will keep it as a lower amp LED, than an XM-L driven at 2.8A to 3A. A Nichia 219 at about 1.4A should be fine. Again, I’m not going for mega lumens, there’s other things than just that, like high CRI LEDs, that give a more natural illumination.
Hey OL sorry for the rapid-fire, scatter brained comments and questioning (thats just how my mind works some times).
I would think carefully about a driver swap to 7135s… they can generate a lot of heat in lights like this that keep Vin > Vf for a good percentage of the discharge. 7135 heat generation can be as much as any plane-jane RLC circuit, or FET with current sense resistors.
I think you should load up some eneloops and run it on HI for 10-15 minutes. If that OEM driver circuit remains moderately warm to the touch… stick with it. I have found 7135 drivers can get painfully hot to the touch the longer Vin remains greater than Vf.
I know, that is a concern for those 7135 boards. There is room in the board area, for a separate heat sink for the board, once the original board is gone, it leaves quite a bit of space for that.
I may try to send this board to another member and see if it can be changed to 1.4A, I just don’t want to put a large die in it like an XM-L and I don’t want to push a small die to 1.8+A, with a poor heat sink that is enclosed in a plastic insulator. As far as modifying this board myself, no way! As bad as I shake, I would have it looking like a figure eight demo derby track in a few seconds, LOL.
So, any of you electronics gurus out there feel like tackling this board and change the High setting to 1.5A, or recommend a different board that would take from 6v to 4.5v input (4AA Alkalines or NiMHs) and output 3v-3.2v @1500ma??
R150 is the sense resistor . The easy way is changing it to an R220 or .22 ohm axial resistor not hard to find and measure the current , if too low adding an 1 ohm in parallel to convert it at R180 …with 2,2 ohm go to R200…
No, the R050 resistor by his thumb is most likely the main sense resistor. It could be a 0.5 ohm or 0.050 ohm resistor depending upon who made it. The R150 may be used for the low level setting.
You know, if I could remember where I put my memory....... LOL. I already did a Nichia 219 at 1.8A Here!
If I can make a good heat sink, I am just going to use the board I already have. Man oh man, I hate to think what a few more years will do. Probably won't remember that I like to modify flashlights.
I’d try it with the current heat sink. Within reason, extra mass does not affect the ability of a heat sink to get rid of heat. It just delays the inevitable rise in temperature. What does matter most is the surface area of the heat sink and its emissivity. Also, the thermal conductivity of the material. Cast materials can have less that half the conductivity of forged materials because of trapped microscopic air pockets.
Very thin materials (i.e. it bends) can be bad because of thermal conductivity issues. We did a test on a copper heat sink that started out with a 3/8” thick plate. Then it was milled thinner and thinner. It was just as effective at 1/8” as 3/8” (accounting for loss of surface area).
