That is a beautiful light, Hank! With an XP-G2 that is going to be the EDC of choice for many folks here on BLF. Would be even better with the V2 driver for moon mode low but that’s as close to perfect as I’ve seen from any non-modded torch yet. 8)
True. I don’t see much difference from Roche f12. And F12 does not have visible PWM for sure. But F12 has a higher low (around 50lm I guess). This new one has a green clickie, which does not go with the golden body IMO.
Hey, nice host, Hank
Have a question though: what’s the difference between those drivers? Nanjg 101-AK-A1 is just a one sided Nanjg 105C and less 7135 chips? Everything else is the same?
You have this beauty with clip Don’t know what driver does it have though
actually this one. The v2 nanjgs use 380ma chips and have nicer mode spacing and come in 4, 6 & 8 chip versions. KD isn’t the only place that sells them though they were the first.
PWM
Pulse Width Modulation. A technique of varying the brightness of a LED by flashing it on and off very quickly, making it appear to the eye that the LED is dimmer. Good PWM is at such a high rate that you can’t notice it. But if you wave your hand in front of the light and get a strobe effect, the PWM is getting too low. Some use current regulation which makes the light dimmer without PWM and is also more efficient.
Here is a link that you might find useful that has some of the words and stuff related to flashlight stuff
Built on the revolutionary SC³ Technology Platform, the XP-G2 LEDs combine high light output, reliability and efficacy to deliver up to 151 lumens per watt at 350 mA, 85°C or 165 lumens per watt at 350mA, 25°C in cool white (both at 6000K). In warm white (3000K), the XP-G2 LED delivers up to 133 lumens per watt at 350 mA, 85°C or 145 lumens per watt at 350mA, 25°C. The SC³ Technology Platform leverages Cree’s advanced silicon carbide technology, features advancements in LED chip architecture and phosphor and showcases a new package design to deliver the most advanced lighting- class LED components in the industry.
The problem with PWM is that it drives to led to HI then Off. On High, the led is less efficient than at a lower current level. Just because it is off for a small period of time does not mean the average brightness, as seen by user, is not lowered. I believe the bottom line in the CPF forum was that PWM is NOT the most efficient approach, because of this principle. I am wondering why this technology persists in drivers?
