Hi-Max 18650
30 posts / 0 new
Stittville Ed
Stittville Ed's picture
Last seen: 13 hours 46 min ago
Hi-Max 18650
I just got a shipment of Hi-Max 18650 batteries for my 3 new UltrsFire 2100 that Eric built as a group buy.
My problem is that the new Hi-Max batteries are a little “Big Boned” and will not slide into the new lights…………..
The question is can I remove the clear plastic covering, which looks a little thick.
Edited by: Anonymous (not verified) on 08/23/2012 - 14:00
scaru
scaru's picture
Last seen: 3 years 1 month ago
It is generally not a good idea to do that because it would allow the batteries to short through the walls of the light. However if you have something else to recover it with it should be okay.
AlexGT
AlexGT's picture
Last seen: 16 min 30 sec ago
I am using those batteries in mine, only one didn’t fit the other 6 did, try rotating the battery and see if it fits, it is a snug fit indeed
BetweenRides
BetweenRides's picture
Ed: The Hi-Max has two layers, white under, clear over. You can remove the outer clear layer but be warned that the under layer is somewhat brittle. Just treat the batteries carefully and inspect them for nicks in the future.
wshyang
Last seen: 6 years 10 months ago
I am kind of new about this, how is it that the batteries can short itself when the wrapper is removed?
scaru
scaru's picture
The metal casing on the cell is negative so it can touch the spring in the front shorting it.
ultey
Last seen: 7 years 6 months ago
you’d better not for the short reason.
selling decent flashlights and batteries with wallet friendly priceLaughing http://www.tinydeal.com/flashligh
NightCrawl
Last seen: 3 years 10 months ago
As mentioned before, the HiMax cells are double wrapped. The white layer is pretty much like the one from the old white-blue Solarforce cells. Its OK but, as said, brittle.
Stittville Ed
Thanks for the comments
I will cut the clear plastic off one and see how it looks/works/holds up.
Ecig
Last seen: 7 years 1 month ago
You can remove both and wrap it with thin scotch tape
Ecig
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=320944707574&ssPageNa...
I think its a good price.
But I dont understant, someone said that Samsungs charge to 4,35V??
Can someone more knowledgable explain?
Buwuve
Buwuve's picture
Last seen: 2 years 8 months ago
I can’t explain it, but it is written in the Samsung homepage, that the Samsung 3000mAh 30A needs 4,35V to be full.
The Samsung 2800mAh needs 4,3V.
http://samsungsdi.com/battery/cylindrical-rechargeable-battery.jsp
Light up the darkness.
Ecig
Can this be dangerous for lights that are specified for 4,2V? Or it snot a problem, just 0,1-0,15V difference?
scaru
scaru's picture
Not a problem for the most part. However, unless you get a special charge for them (or have a hobby charger) then they are not going to reach that voltage.
Buwuve
Buwuve's picture
This are only 4% more and I don’t think, that this will harmful (in a single 18650 flashlight). But I would not try to use 2-3 of them in a flashlight in serial.
HKJ
HKJ's picture
Last seen: 7 hours 34 min ago
Ecig wrote:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=320944707574&ssPageNa... I think its a good price. But I dont understant, someone said that Samsungs charge to 4,35V?? Can someone more knowledgable explain?
This depends on the actual cell/battery, in my battery review I do test cells/batteries that need higher voltage, both at the high voltage and at 4.2 volt. You are not required to use the higher voltage, but will get less capacity when using the 4.2 volt on a 4.3 or 4.35 volt cell. To see how much you loose, check my reviews.
Ecig
Thanx
toysareforboys
toysareforboys's picture
Cottonpickers sells a VERY nice charger that can do the 4.35v batteries to full capacity! They work REALLY well Smile
http://www.cpfmarketplace.com/mp/showthread.php?240304-gt-FS-Cottonpickers-Chargers-incl-Worlds-smallest-Li-ion-charger-with-display
-Jamie M.
weiser
My Hi-Max 18650 needs to be rotated until the ‘sweet spot’ is found to fit in the UF T50 and then it slides right in, albeit quite snugly. It’s a slight nuisance but manageable. However, if there is going to be trouble with them fitting at all in some lights then it’s a pretty big issue, imo.
Try rotating it as you let gravity (and maybe just a little bit pressure) force it down. It’s the positive end (PCB) that hangs up so once you get past that there shouldn’t be any more issue. That’s the case with mine anyway.
Stittville Ed
I had to cut the outer clear layer off mine to fit into my UltraFire 2100 and do not see any problem with doing that
Ecig
I dont know why tere’s not group buy for these here on the forum.
I bought 12pcs (2600mAh) from ebay (from that pingyi seller, something like that) for 59$ with shipment. Thats 5,25$ per cell, great price, and these cells are way better than 2400 TF flames.
CB
Are these the way to go as a step up from Trustfire Flames?
There seems to be so many brands and deals around that I can’t keep up; I realise there are better batteries out there but these seem to be well thought of for the price. Would they be a better buy than the Tank007s from here?
http://www.torchdirect.co.uk/rechargable-li-ion-batteries/tank007-18650-...
wshyang
With the known reputation of the HiMax why consider some new unknown brand?
CB
Well, as someone who’s fairly new to the flashlight scene, the Tank007 cells are an unknown quantity; they may be better or worse than the HiMax and I was hoping someone with greater knowledge than myself could advise me on these and other cells.
Sometimes the best option isn’t always the one directly in front of you! Wink
ILIKEFLASHLIGHTS
ILIKEFLASHLIGHTS's picture
Last seen: 1 year 4 months ago
These cells are made by Samsung.
SashiX
SashiX's picture
Last seen: 5 years 9 months ago
HKJ’s review of this one is indispensable Silly 8)
CB
Looks like HiMax are the way to go then! :bigsmile:
wshyang
Wait, HiMax cells are made by Samsung?
HKJ
HKJ's picture
SashiX wrote:
HKJ's review of this one is indispensable Silly 8)
You will get it soon, I have the test data ready Smile
ILIKEFLASHLIGHTS
Yep. I was told that by Shane who sells them. He ought to know since he buys them.
