That's a good looking light. I definitely prefer the T08 parallel cell design over the T16 series. Would like to see beam shots of the T08 in real world testing.
SmallSun seems to have really kicked up their quality judging from these pics and by the T13 I just received the other day. A simply outstanding lit for the money. The best light you can buy for $24!!
I do indeed. Lux meter and IS. Not sure I can do it real soon but I will try to get something. I have a long overdue review to get together then I think I will do a full review on the T13.
I’m tempted… 2*18650 in parallel, big reflector, I’d probably try to get a NANJG105C in with 3.5A and a copper core XM-L T6 3C. I hope the thermal path is good and the driver can be changed easily. There should be enough space behind the battery contact plate. Still hesitating though.
The thermal pathways/heat management of this light look to be outstanding. The aluminum is thick around the pill, in addition to five deep fins directly around that.
If it's like the UltraFire, it could handle some serious current, no problem.
If it’s anything like the other new smallsun “big” lights, it should be pretty decent in quality. Functional machining with fairly straightforward electronics (pwm, etc). It’s just a tradeoff of how much you’d like to spend. Personally, it’s probably worth getting the real deal if it’s a daily user light, but the clone is just a fun to play with.
I'd be curious to see the difference. Not enough to buy another, however. It's going to have to be pretty good; quality on this UltraFire version is right up there with the best of the best.
