Review: Thrunite T10 (vs. DQG AA XP-E and BLF Tank007 E07)
30 posts / 0 new
HBomb
HBomb's picture
Last seen: 3 years 2 months ago
Thrunite T10
Reviewer's Overall Rating: ★★
Thrunite T10
Summary:
Battery: AA (14500 not recommended)
Switch: Twisty
Modes: Firefly>Low>High w/ Memory
LED Type: CREE XP-G (R5)
Lens: Glass
Tailstands: Yes
Price Payed: $30 (Also got free Ti on promotion)
Date Ordered: August 14 2012
Specifications (from manufacturer):
- Cree XP-G LED (R5) with lifespan of 50,000 hours
- Three modes of output:High (115 lumens, 1.5hrs) > Low (9 lumens, 39hrs ) > firefly(0.09lumens 147hours) with memory (Tested with Ni-mh battery with actual capacity 2500mAh)
- Stable current regulated circuit, stable brightness
- Uses one 1.5V AA battery (ni-mh, alkaline ). 14500 batteries are not recommeded, because they heat up quickly.
- 17-gram weight (excluding batteries)
- Made of durable aircraft-grade aluminum
- Premium Type III hard-anodized anti-abrasive finish
- Waterproof to IPX-8 Standard
- Toughened double ultra-clear glass lens
- Reliable twist switch
- Candle mode (Capable of standing up securely on a flat surface to serve as a candle)
- Accessories: key ring.
- Size: 81x17mm
Pros:
  • Firefly Mode
  • Current Regulation
  • Build Quality
  • 2 Spare O-rings and A split ring keychain
  • Thrunite Warranty and ANSI/NEMA F1 Certified Specs
Cons:
  • Price
  • No clip
Features / Value: ★★★★
This light's most unique feature is a very useable firefly mode. At 0.09 lumens, it is twice as bright as the firefly mode in the Ti, but I can’t really tell the difference.
Thrunite Firefly modes
Thrunite Firefly modes. T10 on left and Ti on right.
Please excuse the fingerprint on the lens, I had just put on a piece of screen protector to protect the lens from scratches (which I do to most all my lights). I like how the light goes lo to high in modes, and the memory feature is well done. It sets in after being off for around a second. It’s also awesome that all these modes are current regulated and so there’s no PWM. The firefly is way lower than the low on the BLF E07 and the DQG AA.
 AA Twisty Heads
AA Lows
Head shots and also LEDs at lowest levels. Left - DQG AA XP-E, Middle - Thrunite T10, Right - BLF Tank007 E07
My greatest complaint is the cost. I think it was a fair deal with the promotion, but the asking price of $30 seems a bit steep. Various XM-L lights like the Balders and Xeno can be found cheaper or at similar prices.
Design / Build Quality: ★★★★
PCC and Match touched on this already here. Nice machining and anodization on my light with a well centered LED. It’s a bit longer than the DQG AA due to the reflector, but that gives it some nice beam patterns. It is still slim and very pocket-able. I like the well-lubed, anodized threads and the design they use to close the circuit, where the bare aluminum rim needs to contact the driver board rather than the battery needing to touch the board. This allows them to use a spring in the bottom so there’s no battery rattle and it’s always in contact with the driver. I like that better than the standard foam discs that seem like they’ll wear out. My only fear is that if the anodizing layer comes off the threads then the thing might be stuck on. I don’t know how hard that would be to do though. It would be awesome if it came with a clip standard, and Match’s mod is stellar. The light tailstands well enough (better than the Ti), and there is a hole to attach a split ring that was included. I’ll probably fashion another dangle clip for this light like I did for the DQG AA.
Battery Life: ★★★★★
I haven’t done any in depth testing myself, so I hope the specs are right. The firefly mode on the light will definitely run a long time. I got over an hour on high on a fresh eneloop, but I didn’t check it again until much later, so 1.5 hours seems respectable, and the given 9 hours on low is nice. I'll update if I find anything different.
Update 2 December 2012 - I did some quick current draw tests with gen 2 eneloop at 1.353 V open with my cheap DMM and a paperclip. These might be causes for the discrepancy in my numbers vs. the manufacturer ratings. I am still a fan of the battery life so far in my practical usage. Also, I don't know if this light will lower brightness to prolong usable light time as of yet.
Moonlight - 35.5 mA (est. 56.3 hours runtime on 2000 mAh vs. 147 rated)
Low - 178 mA (est. 11.2 hours vs. 39 rated)
High - 2.23 A (est 0.9 hour vs. 1.5 hr rated)
Light Output: ★★★★
Again, I have no gear to test this myself. For an AA light on NIMH, this light performs well. It compared well with the other similar form factor lights. The 115 lumen high is nice for when you need it, and the low/mid is good for basic tasks in the dark. The firefly works great for me in the middle of the night to just get around, but I suppose that’s a “your eyes may vary” situation. I think a fourth, medium mode might be nice to get more brightness and good runtimes. Something like 40-50 lumens for 2.5-3 hours, but I suppose it would get annoying to cycle through so many modes on a twisty. Here are all the comparison beam shots at a off-white cinder block wall about 1 m from the lights. Camera was on auto, so you can't compare between levels, just between lights. Sorry for the mixed up order on the lows, I had to redo that pic.
Highs
Highest mode: Left - BLF Tank007 E07, Middle - Thrunite T10, Right - DQG AA XP-E
Mids
Middle Modes: Left - BLF Tank007 E07, Middle - Thrunite T10, Right - DQG AA XP-E (on Low)
Lows
Low Modes:  Left - DQG AA XP-E, Middle - BLF Tank007 E07, Right - Thrunite T10
Summary: ★★★★
All in all, the T10 is a nice pocket AA light. It’s well made and brings a firefly mode to the table while providing sufficient high and low modes for numerous tasks. I’ll give this a whirl as my EDC for a while, but I doubt it will dethrone my DQG AA. Stainless steel seems more robust to me for some reason, plus I like the magnet in the tail. As for this light, I think there’s one big advantage. I can give it to little kids to play with at church and babysitting and stuff while on in firefly and the kid’s parents won’t shout “that’ll blind him/her” as I sometimes hear now Silly Good  thing water resistant = drool resistant too. I think this would be a great deal $15 and a good deal at $20.
 Lows
Stop blinding my baby: Left - DQG AA on low. Right - Thrunite T10 on firefly.
Edited by: sb56637 on 08/26/2014 - 17:06
HBomb
HBomb's picture
I don’t know where all the strikethrough came from in the specs. That was just copied from their site.
Edit: Managed to get rid of it.
fishinfool
fishinfool's picture
Last seen: 8 months 6 days ago
Awesomw review HBomb!
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
Match
Match's picture
Last seen: 3 years 11 months ago
Great review Hbomb!  I've been meaning to do one on this particular light for months, so if you don't mind I'll just add to this one here:
BatteryTypeModeLumenOTF
eneloopLow.087
 Med12.5
 High129.6
Lithium PrimaryLow.09
 Med12.5
 High140.7
14500Low.087
 Med146.2 - unstable
 High355.7
Lux  = 1136@1m (on eneloop)
A note on running 14500's: Low and High work fine, but medium mode appears very unstable and flickers a lot.  It does get warm quite fast on high and output will drop off some, but I've been using mine since I got it for short bursts and it's still alive.
My only two gripes about the light as received were the lack of a pocket clip and somewhat loose threads. By somewhat loose, I mean that after a quarter turn off I can still press on the head and it will activate.  I guess I've been spoiled by my LD01.
Both were easy fixes...a little teflon tape for the threads, and a bit of SS welding rod for the clip.  I love the T10, and it's part of my edc rotation.
HBomb
HBomb's picture
Thanks for the technical tests Match! And thanks for the support of the review fishinfool. I did some teflon tape on mine like you said and that made it super firm and yet silky smooth. I like it, and it works great since there’s no metal connection needed. It’s probably a bit more water resistant that way I reckon. That was an easy fix. The welding rod clip umm… maybe easy for you Wink One of these days I might try though, that pic makes me drool a bit everytime I see it. Thanks again Smile
Match
Match's picture
Honestly, it takes maybe 20 minutes to make one. Using a cordless drill, I just put two holes on the thick side that are relatively parallel. It's not as critical as you might think because one has some leeway during alignment since the clip can be bent however it's needed.  If I had another T10 I'd do a tutorial.
You're spot on though...if this was $20 I'd by a couple more, and if it was $15 I'd by a dozen more.  It's that nice of a light.
Btw, I did swap out my stock xpg emitter for a NW xp-e (huh?)  Yup...I have plenty of really bright lights, but I wanted a small one with a bit more throw and the xp-e does that surprisingly well.  Granted, this was done before I received a bunch of xpg 2's from cutter...
Now that I think about it, I think I only have 2 lights that I haven't swapped emitters multiple times on....
HBomb
HBomb's picture
Haha, things are always better after you’ve improved them. Maybe I’ll try sometime after i find some wire stock. How do you secure the rod into the drilled holes? some epoxy maybe?
Match
Match's picture
HBomb wrote:
Haha, things are always better after you've improved them. Maybe I'll try sometime after i find some wire stock. How do you secure the rod into the drilled holes? some epoxy maybe?
Thanks.  Yup, just a few small drops of epoxy.  In reality it wasn't needed as such due to the way the clip is bent (tension keeps it secured pretty well).
If you want, PM me your address and I'll mail you a piece of welding rod to try.
HBomb
HBomb's picture
Thanks Match. I might take you up on that. I’ll paypal you some dough to cover postage too. What’s the drill bit size you used? I’ll have to see if I can scrounge one up from work to borrow.
On a usage note, I’ve liked the T10 lots as my edc. The DQG AA XP-E out throws it a bit, but for closer tasks the T10 takes it. I’ll have to see how the DQG AA XP-G I just ordered does comparatively when it gets here.
sb56637
sb56637's picture
Last seen: 13 hours 40 min ago
Very nice comparison! Thanks very much. Frontpage’d and Sticky’d.
likeaboss
likeaboss's picture
Last seen: 2 years 6 months ago
Match wrote:
Honestly, it takes maybe 20 minutes to make one. Using a cordless drill, I just put two holes on the thick side that are relatively parallel. It’s not as critical as you might think because one has some leeway during alignment since the clip can be bent however it’s needed.  If I had another T10 I’d do a tutorial.
You’re spot on though…if this was $20 I’d by a couple more, and if it was $15 I’d by a dozen more.  It’s that nice of a light.
Btw, I did swap out my stock xpg emitter for a NW xp-e (huh?)  Yup…I have plenty of really bright lights, but I wanted a small one with a bit more throw and the xp-e does that surprisingly well.  Granted, this was done before I received a bunch of xpg 2’s from cutter…
Now that I think about it, I think I only have 2 lights that I haven’t swapped emitters multiple times on….
Hey, what the emitter star size?
Candlepower (abbreviated as CP) is a now-obsolete unit which was used to express levels of light intensity.
Candlepowerforums (abbreviated as CPF) a website, also obsolete, drive
Match
Match's picture
@12mm, although there is enough wiggle room for a 12.5mm to work as well.  The last one I used was a 14mm star that I had to file down slightly.  Never let star size stand in the way of a good emitter swap Smile
HBomb,
As for the drill size for the clip...I'll have to get back to you on that (Gotta go find it to verify).
ezarc
Last seen: 8 months 1 week ago
Just wondering about the Ti
I read that with a eneloop that they are only 30 lumens and with a 1.5v battery they are 60 lumens.
Is that right?
Taken from here
Time to buy some cheap lithium primaries instead?
MountainKing
TI = crap light. Direct driven. I’d avoid that like plague!
Never ever forget and forgive. Niwal**er new kid on the block trying to act tough.
http://budgetlightforum.com/node/24847
Do not support this brand.
DINODIRECTSCAM COMPANY. DO NOT BUY
http://budgetlightforum.com/node/11324?page=2#comment-254983
Match
Match's picture
ezarc - This is a review for the T10, not Ti.
Mountainking - Ditto.  Also, the wrongness of your comment made me laugh.
scaru
scaru's picture
Last seen: 3 years 3 months ago
MountainKing wrote:
TI = crap light. Direct driven. I'd avoid that like plague!
LEDs cannot be direct driven off of a 1.5 volt battery. Not enough voltage.
ezarc
Match wrote:
ezarc – This is a review for the T10, not Ti.
Its mentioned 5 times in the review and has a picture of it, its also part of package when you buy a T10 so it wouldn’t hurt to know what you are getting with it when you buy one.
MountainKing
I meant to say the output is not regulated…
sandalian
sandalian's picture
Last seen: 3 years 8 months ago
Just received my T10 two weeks ago with minor problem. If I put the O ring, I can’t turn on the light.
I have to twist it very hard (using two hand) to turn on the light. I think there’s some problem with the thread or something. So I removed the O ring to be able using this T10 with single hand. A friend of mine also ordered T10 and arrived today, it has no problem with O ring.
IMO, T10 is a nice flashlight but I won’t buy the same flashlight again. With the same budget, I better looking for other AA alternatives.
I'm switching my BLF account into LumenZilla. Thanks!
vēer
vēer's picture
Last seen: 4 months 4 weeks ago
Could anyone actually comment on this flashlights real life battery numbers with NiMh?
Im pretty tempted to get this one despite problems with my Ti’s, which I will describe later in my Ti review, but this T10 looks like the best bang for the buck when it comes to single AA battery life with extremely long runtimes!
Match
Match's picture
I posted output/lux numbers above for nimh. Unless you're looking for runtime figures, which I haven't done...
vēer
vēer's picture
Yeah, sorry, seemed logical for me to assume that with battery numbers only battery life time should be associated :D!
Im interested in battery runtime :)!
GottaZoom
GottaZoom's picture
vēer wrote:
Yeah, sorry, seemed logical for me to assume that with battery numbers only battery life time should be associated :D! Im interested in battery runtime :)!
The lumen ratings are fairly close, so you can estimate your run time from the draws and run times posted above. I see some draw/resistance variance even among Eneloops from the same pack, so the specific battery capacity and resistance you use will have something do do with your own run time.
vēer
vēer's picture
I think youre talking about Ti that Ezarc posted about?
Because there is no data on how much power T10 draws in this thread Smile
GottaZoom
GottaZoom's picture
Correct. But my point was if the specs test roughly correct as Match showed then go back to T10 specs in the same manner.
High (1.5hrs) -> Low (39hrs ) -> firefly (147hours)
The T10 is literally a prize I always have with me – the low is very useful as my primary mode. Were I shopping today I’d also look at the L10 that L3 has been selling.
HBomb
HBomb's picture
@veer – I did a quick test with my cheap DMM to see what the current draws were. Also understand I had to use a paperclip so things might vary a bit. I’ll add this info to my original review too.
On a semi-used gen 2 eneloop at 1.353 V open
Moonlight – 35.5 mA
Low – 178 mA (I got measurements anywhere from 176-180)
High – 2.23 A
vēer
vēer's picture
Thanks!
Seems way less battery life on firefly and low modes than advertised, they used 2500mAh AA battery for their tests, however your data suggests that its 3-4 times less runtime on these two modes or am I missing something here?
HBomb
HBomb's picture
I’d probably trust their runtime specs pretty well, mainly because their lumen values are almost spot on with Match’s numbers like GZ said. I will have to run mine down sometime, but I haven’t yet. My draw measurements probably are flawed since there’s the effects of a cheap DMM (and the crappy included leads), and random point contact and resistance of a paperclip vs. the whole current path when the body is screwed on.
chrisc
Last seen: 7 months 2 weeks ago
I did not realise it worked worth 14500s so I whacked some in it tonight. A very impressive little light like that.
I’m also doing a quick run time test with a hybrio batter. Started it at 8:05 and it’s been going strong for 25mins – rather toasty warm now. I’ll try to remember to check on it later
chrisc
Pretty much lasted an hour then dropped to a lower mode. I flicked it off and on to see if could trick it into high again but it’s no go. Battery is too flat for anything now.
