If your car is running right you’ll be max 14.4 volts. At full charge a 4S lipo pack will be at 16.8 volts. You’ll definitely be shortening light bulb life considerably if you run it at those kinds of voltages. 3S works perfectly for all 12v nominal uses. It peaks at 12.6v.
How does the sunwayman clone stand up to the original? Im obviously guessing it loses in many aspects, but by how much? Does it still give the original some competition?
Is the Trustfire X8 comparable to the Fandyfire STL V6? I know there is a comparison out there with beamshots but over all is it really worth the purchase? I already have the X8. Would I need to go one step higher with the Trusfire X6 or perhaps the Crelant 7G6 or V9 to see a big difference?
Well I need to take a better one with my Crelant 7G5 at 350yds.
But I can show you some other shots with my Crelant 7G5 if it will help. The new EagleTac with the updated driver is currently my best single XM-L thrower.
Well now those last 2 were my better XM-L throwers.
But like I said for under $50 if there is a better XM-L thrower for the money than the FandyFire STL-V6, I sure don’t know of it. But $ for $ the Small Sun ZY-T13 is probably the better deal for $24. But I still would rather have the FandyFire.
