Review: Thrunite T10 (vs. DQG AA XP-E and BLF Tank007 E07)
Very nice comparison! Thanks very much. Frontpage’d and Sticky’d.
Hey, what the emitter star size?
@12mm, although there is enough wiggle room for a 12.5mm to work as well. The last one I used was a 14mm star that I had to file down slightly. Never let star size stand in the way of a good emitter swap :)
HBomb,
As for the drill size for the clip...I'll have to get back to you on that (Gotta go find it to verify).
Just wondering about the Ti
I read that with a eneloop that they are only 30 lumens and with a 1.5v battery they are 60 lumens.
Is that right?
Taken from here
Time to buy some cheap lithium primaries instead?
TI = crap light. Direct driven. I’d avoid that like plague!
ezarc - This is a review for the T10, not Ti.
Mountainking - Ditto. Also, the wrongness of your comment made me laugh.
LEDs cannot be direct driven off of a 1.5 volt battery. Not enough voltage.
Its mentioned 5 times in the review and has a picture of it, its also part of package when you buy a T10 so it wouldn’t hurt to know what you are getting with it when you buy one.
I meant to say the output is not regulated…
Just received my T10 two weeks ago with minor problem. If I put the O ring, I can’t turn on the light.
I have to twist it very hard (using two hand) to turn on the light. I think there’s some problem with the thread or something. So I removed the O ring to be able using this T10 with single hand. A friend of mine also ordered T10 and arrived today, it has no problem with O ring.
IMO, T10 is a nice flashlight but I won’t buy the same flashlight again. With the same budget, I better looking for other AA alternatives.
Could anyone actually comment on this flashlights real life battery numbers with NiMh?
Im pretty tempted to get this one despite problems with my Ti’s, which I will describe later in my Ti review, but this T10 looks like the best bang for the buck when it comes to single AA battery life with extremely long runtimes!
I posted output/lux numbers above for nimh. Unless you're looking for runtime figures, which I haven't done...
Yeah, sorry, seemed logical for me to assume that with battery numbers only battery life time should be associated :D!
Im interested in battery runtime :)!
The lumen ratings are fairly close, so you can estimate your run time from the draws and run times posted above. I see some draw/resistance variance even among Eneloops from the same pack, so the specific battery capacity and resistance you use will have something do do with your own run time.
I think youre talking about Ti that Ezarc posted about?
Because there is no data on how much power T10 draws in this thread :slight_smile:
Correct. But my point was if the specs test roughly correct as Match showed then go back to T10 specs in the same manner.
High (1.5hrs) -> Low (39hrs ) -> firefly (147hours)
The T10 is literally a prize I always have with me - the low is very useful as my primary mode. Were I shopping today I’d also look at the L10 that L3 has been selling.
@veer - I did a quick test with my cheap DMM to see what the current draws were. Also understand I had to use a paperclip so things might vary a bit. I’ll add this info to my original review too.
On a semi-used gen 2 eneloop at 1.353 V open
Moonlight - 35.5 mA
Low - 178 mA (I got measurements anywhere from 176-180)
High - 2.23 A
Thanks!
Seems way less battery life on firefly and low modes than advertised, they used 2500mAh AA battery for their tests, however your data suggests that its 3-4 times less runtime on these two modes or am I missing something here?
I’d probably trust their runtime specs pretty well, mainly because their lumen values are almost spot on with Match’s numbers like GZ said. I will have to run mine down sometime, but I haven’t yet. My draw measurements probably are flawed since there’s the effects of a cheap DMM (and the crappy included leads), and random point contact and resistance of a paperclip vs. the whole current path when the body is screwed on.
I did not realise it worked worth 14500s so I whacked some in it tonight. A very impressive little light like that.
I’m also doing a quick run time test with a hybrio batter. Started it at 8:05 and it’s been going strong for 25mins - rather toasty warm now. I’ll try to remember to check on it later
