Thank you for the review with all the wonderful beamshots. It certainly looks like this driver is pulling its weight in this combination of host/emitter/battery. TY :-)
Thanks for the review. I have been buying a lot of these OEMs but have not tried that one yet. Seems like for every one it helps if you have some other spare parts laying around.
Nice review! Been wanting this host for a while! Just got in some AA drivers from DX and what a sweet place to put one of those.
Bank Account Punishment!!!
Thanks
Good job .
A sk68 clone competitor?
I find it hard to compare reflector lights with zoomies as the light patterns are just to different. With the SK68 zoomed out to show the LED die it would slaughterter this kit light on throw but would have a very tiny hotspot and no spill where as zoomed in the light radiates a light with no discernable hot spot and all spill where the kit light has a large hot spot and reasonable spill if that makes sense. Cheers.
Thanks for the review. :) I'm guessing the reflector fits a XM-L?
This hole for the LED is just big enough for it to fit over the square on the XP-G. If it was drilled out to a larger size it would chew into the tapered side of the reflector as there is no flat at the base. I would not recommend it. Cheers.
Darn, thanks though. :)
I think you should do a battery life test and if possible some lumens estimate. Other than that great review and thanks!
Temperature and run times added to the first post
heh man. I know im bugging you but can you please add a white wall pic? This will make me get a better idea of the hotspot/spill. Thanks for a great review!
[quote=MRsDNF]
{Touch wood Quote}
FYI. You must ‘peck on wood’. If you touch wood, it will not take hold.
keith
[quote=budynabuick]
Thanks budynabuik. Here in Aus the saying touch wood is added when you say something and dont want what you said not to happen. Or in other words put bad luck on what was said.
I have tried to take white wall shots and they failed miserably with my camera. I will have to try and work out how to use my sons camera on manual and give that a go. It has been a lesson in frustration these white wall shots.
Thanks very much for this review! Very well done. Frontpage’d and Sticky’d.
Thanks sb. Now to work out how to use the template properly.
White wall pictures added to the first post.
Nice DNF like the comparison shots. I like red body lights. Been eyeing that one for a while.
