Nice review! Been wanting this host for a while! Just got in some AA drivers from DX and what a sweet place to put one of those.
Bank Account Punishment!!!
Thanks
Thanks
Good job .
A sk68 clone competitor?
I find it hard to compare reflector lights with zoomies as the light patterns are just to different. With the SK68 zoomed out to show the LED die it would slaughterter this kit light on throw but would have a very tiny hotspot and no spill where as zoomed in the light radiates a light with no discernable hot spot and all spill where the kit light has a large hot spot and reasonable spill if that makes sense. Cheers.
Thanks for the review. :) I'm guessing the reflector fits a XM-L?
This hole for the LED is just big enough for it to fit over the square on the XP-G. If it was drilled out to a larger size it would chew into the tapered side of the reflector as there is no flat at the base. I would not recommend it. Cheers.
Darn, thanks though. :)
I think you should do a battery life test and if possible some lumens estimate. Other than that great review and thanks!
Temperature and run times added to the first post
heh man. I know im bugging you but can you please add a white wall pic? This will make me get a better idea of the hotspot/spill. Thanks for a great review!
[quote=MRsDNF]
{Touch wood Quote}
FYI. You must ‘peck on wood’. If you touch wood, it will not take hold.
keith
[quote=budynabuick]
Thanks budynabuik. Here in Aus the saying touch wood is added when you say something and dont want what you said not to happen. Or in other words put bad luck on what was said.
I have tried to take white wall shots and they failed miserably with my camera. I will have to try and work out how to use my sons camera on manual and give that a go. It has been a lesson in frustration these white wall shots.
Thanks very much for this review! Very well done. Frontpage’d and Sticky’d.
Thanks sb. Now to work out how to use the template properly.
White wall pictures added to the first post.
Nice DNF like the comparison shots. I like red body lights. Been eyeing that one for a while.
MRsDNF
Well your review made me order this host and I received it yesterday. I have a question though about the assembly of the switch. Do you have to solder the tabs of the switch to the blue disc on the edges where the gold colored parts are? Hopefully that made some sense. Then the retaining ring makes contact with the other side of the blue disc for for the switch to work? I have never built a switch before.
Thanks
Yes you are correct. The retainer for the switch connects to the tail cap of the torch for the earth. In the top picture you can see the trace that runs from the centre to the outside. When the switch is activated it puts the negative from one side of the switch through to the other side to the battery board and then through the flashlight body. I hope that makes sense. The only problem I had though was the switch with mine was faulty. I would also advice to solder the spring on the opposite side first to keep as much heat as possible away from the switch as possible. Good luck.
