Wow! Glad your okay! I have to disagree with you about the ammo can though, I have seen them take a lot of excuse without breaking. One of the ones I got had a bullet hole in one side and it only dented the other side. The other advantage to the ammo can is if it is a simple vent with flame you just grab the handle and take it outside.
Edit: Oh yeah, forgot to ask were there any fumes and did the battery seem to have a good capacity? I personally think the number one danger with lion cells is using the cheap ones rather then name brand ones. My 3p Sanyos withstood a prolonged short without anything to dangerous. (Small flame but it did not escalate)
>>>>>>I think using cheap protected Ultrafire cells is much more dangerous then using unprotected brand name batteries. (Sanyo, panasonic, etc.)
I now use almost-all (95%?) unprotected NAME-BRAND (sanyo, LG, Pannasonic, Sony, Samsung, etc.) cells. Although I use matched-voltage TFFs in the few multi-cell lights I still have. I really try to stay away from multi-cell lights now because of the explosion.
There are many arguments for and against protected/unprotected cells. My personal feeling is that I can’t trust the PCBs in ANY protected battery to do more than become shrapnel. They’re the weak link even in expensive “designer” protected cells. No one can see inside any battery wrap and know who made that PCB. It could come from a tin shack in China. I just don’t know. If a manufacturer said where and how the PCB was manufactured, I might trust it more, but then some of these vendor/manufactturers are the same ones who try and sell me 1200 lumen lights and crap batteries that supposedly have 3000 Mah.
I feel safer with straight as-manufactured unprotected cells from major manufacturers with established safety records, but that is me and I don’t expect anyone else to follow my example.
Not what you would call fumes exactly, but a strong odor that smelled EXACTLY like the afternath of a dynamite/gunpowder/cordite explosion. And the gooey flakes were in the air for a few minutes. We quickly set up exhaust fans to vent the flake crap, but it had mostrly settled by then.
Yes, the gray 14500 ultrafire was “protected.” whatever that really means. You can see the bottom disk from the protection unit on the floor in picture three, lower right.
To be fair, re-read the 3rd from the last paragraph - Ubehebe refers to the explosion as a 16340, while the title says 14500, so the question was legitimate.
Ubehebe - I'm glad everything worked out ok and there were no injuries or fire. It takes reminders like this every once in a while to keep us from getting complacent with Li-Ion. No matter the statistics, we need to treat these batteries with respect and be vigilant when chargingl. Thanks for posting.
On reflection it seems more likely that this was an internal chemical fault, not really anything a pcb would’ve helped. Electrical safeguards offer protection for a different (perhaps more common) type of fault.
I apologize for any confusion.
I am talking about TWO events:
1. 14500 gray ultrafire explosion 6 months ago.
2. 16340 xtar battery overheating event (without explosion), covered in another thread, which occurred two nights ago.
I thought I was explaining it clearly, but apparently not. As a professional writer, I try to be concise, but often I try to detail too much and include too much spurious detail. My apologies. Hopefully with this further explanation, it will all become clear now.
I also changed the original post to hopefully make it clearer. Thanks for poiting that out to me.
Another ultrafire kaboom story. Somehow I think these batteries are living up to their names.
Ubehehe, did you happen to check whether the protection circuit actually has circuits on them? They look flat to me.
The reason I'm asking was because, I once disassembled a protected 18650 with dubious characteristics and found that the "protection" was nothing more than a shorted bare PCB. It was painstakingly soldered, placed and rewrapped there JUST to make it look protected. Looks a lot like yours.
The ultrafire had a PCB in it. It was recovered with the various debris. Was the battery protected, i.e, would it shut down as designed and prevent a catastrophic event? As I said, I wouldn’t trust that or any battery pcb to do anything more than become shrapnel. As I said, I for one have no idea who makes those PCBs or even if they work reliably at all. As I said, I don’t trust them any more. I just buy the best unprotected batteries I can.
But I don’t wnt to get into an argument about the benefits of those PCBs. Not trusting them is my choice. I’m not trying to push that choice on others.
Yeah, watch out for those seagulls, especially the ones carrying fish. :P OL, I still think you should try Li-ions; they are really great and rarely explode. :)
