Emkay, if you do try johnnymacs suggestion, ( I would) just use a partially depleted 18650.
Exactly. Freshly charged 4.2v might damage the emitter. 3.6v should be fine.
JM, it really depends on the cell. IMR cells can easily kill them but the crappy trustfire cells will work just fine cause of voltage drop. Either way just run it in another light for a bit. :D
Ah, great idea to push the driver out through the switch hole... I finally got it out! Thanks, Serifus :)
Now I have plans... ^_^
DrJomes, you know more about chip programming than most of us.
Eagerly waiting for to your magic! :bigsmile:
There are 3 SOT-23-6 Buck drivers + external FET.
PIC/AVR send PWM signals though 10K resistors.
Good luck with the micro controller Dr Jones. Also it seems ive finaly found my self some time to do some sketching around in Eagle. if this all works out the way I hope it does, I’m probably only going to be getting more kings in the future.
the problem is connectivity between the circuit board and the led
If I apply power to the corner of the led it works
I would be tempted to get 3 xm-l u2’s on 16mm stars, ditch that one and keep the two functional ones for other projects…. 0:) J)
You should be able to resolder the connection or solder on a wire.
I saw on another post that with U2, initial output was higher, but then it decreased… maybe those U2 had flat PCB, copper PCB is the way to go in that case.
I’m going with 3 cheap U2 ones from dinodirect, just got to wait for them to arrive now…
I found this on google
That definitely looks like it could lead to something interesting.
Except as far as i can tell, it doesn’t match up to, what i assume is the PIC.
so the MCU isnt a known unit?
if someone drew out the actual circuit on a king, you could mount a attiny upside down on the board (pins sticking up) and use small external wires to solder to the correct pads on the board and then write custom controls for it fairly easily.
with those inductors on the board sticking up high, you have height for some creative wiring of a attiny in there.
Brian
The MCU seems to be one of these unknown Chinese MCUs with PIC layout, but I haven’t yet heard of anyone being able to reprogram these.
Removing it and put an ATtiny there with “some creative wiring” was exactly my plan
I also have some creative ideas for the UI, too
with enough room for mod, by replacing stock MCU with ATtiny, its easy to mod King as you wish
And it doesn’t need 3 separate PWM outputs. one PWM can handle 3 Drivers without any problem.
unfortunately I have no king
more useful modes
temperature control
battery monitoring
It would definitely be nice to have a circuit diagram, wiring in an ATtiny is something i would be willing to do for the sake of custom modes.
