Actually I don’t think I could even think I could see a rabbit 300 meters away unless I had a binoculars or a scope, then it would be hard to handle a flashlight at the same time.
What purpose do you plan on using it for, hunting?
Hi,
Thank you for your reply .
Can fenix E40 do it clearly ?
Varapower is quite costly .
Night master makers also confirmed me that the famous flashlight throws a very tiny beam .
Ive not heard of Clearnt .
Hope you would definately suggest me the best for me .
Recently I use a commonly available britelite rechargeable that can throw beam at max 110mts though the company claims 1450 mts .
Hi,
Ive already informed that its for watching my farm house that is by a river and forest and often small animals are watched for crops et c and its my dream to have such a powerful flashlight that would help in so many ways as walking throw forest etc .
And friend , I think its not bad to have such one while I live in such a lace .
And I dont hurt animals . To say clearly , I live on veg .
Regards.
Hi friend ,
Thank you for your reply.
Ive a flashlight that throws about 110 mts but its not helpful for me . If I can find any flashlight at that range , it would really help me . To say visulising rabbit , I mean I want something that can make me things really visuable just like broadday light at that point as it would help to protect my crops from small animals which I need . Besides its my dream tp have such a flash light . Hope I have made you clear about my purpose ….
I read the thread you mentioned … Thanks for your help.
Thers a few ssuggestions about few cheaps too within $50 or so . Ill see them all . I think crelant 7g5 v2 , small sun , tn 31 , fandyfire etc are to be considered .
I can recommend Klarus XT11.
I has quite a lot of spill and throws quite far - almost at par with Xeno G42.
It uses 1 x 18650, 2 x CR123, or 2 x RCR16340.
I just love this light.Plus it is very compacr.DD has them for $69.99.
With a 10% coupon the price is around $62.
Seriously, 300 metres of throw mate. Not questioning your needs but thats in the area of SAR For normal use a throw of around 150-200ish metres would do good Anyways, I’m no expert so GL with your hunt!
We shoot thousands of rabbits each year including up to 600 per night using a variety of LED lights. The three I recommend for general purpose bunny shooting are also the top three on the budget thrower list - Small sun C10, Jacob A60, and the excellent Maxtoch SN6X-2 - also known as the Skyray STL-V2. The SN6X-2/STL-V2 is not only highly regarded by flashlight fans - it is a superb hunting light.
However - while the SN6X-2/STL-V2 will in perfect colour/background conditions show up large animals at 300m, it will only show rabbits out to 150m and even then you need to use a scope. From our experience to reach out 300m to see rabbits you’d really need an HID and one with a 6-7” reflector for very concentrated beam. Its not always easy to see them in daylight at 300m so you’d need super powerful light to show them up at that distance at night.
Its also not so easy to hit small rabbits at 300m at night, and given this I’d suggest you re-assess your torch criteria. The SN6X-2/STL-V2 will certainly pick them up out to 150 with scope in ideal conditions, and the Dereelight will go a little further. But remember you have to have a safe visible firing zone beyond your target, and only an HID will give you daylight at 300-400m.
I dont hunt or hurt animals but need something powerful to see objects clearly at that point to protect my farm , fruits fom few smalll and larger animals like rabbits , deer , monkey or so , They often come to my farm house and destroy crops as my farm is by a river and a forest .
Ive also thought of skyray stl v2 ,fandyfire stlv 2 /6 , smallsuun zy 13 , crelant 7g5v2 / 7g9 .
Please help me to choose the best one for me .
I don’t recommend trying to see rabbits at 300m. If a light is going to be powerful enough to light it up like daylight, it’ll either have insane throw, or it’ll be super bright to kill your night vision.
You’ll need something with 3500+ lumens, along with 200k+ lux to be able to see something that small that far away. The only way you’re getting there is through a HID spotlight (7inch reflector or bigger) or a shortarc spotlight.
It may be your dream to own such a powerful light, but you’re never going to get something with good runtimes that can throw that far that’s also smaller than the fenix TK70.
I recommend getting an SST-90 light such as a trustfire X6, modding it with a 9amp driver to push the lux past 50k, then you’ll have a light which has 2000+ lumens which throws further than an STL-V2 and lights up about triple the area.
But honestly, in my opinion I recommend stretching your legs and walking closer to those rabbits because you’re going to have a hard time finding your dream flashlight. I dream that one day a stable nuclear flashlight will one day be available. 1 billion lumens+ would definitely light up 300m like daylight.
Go for the 7G9, it has 65k lux and just over 1000 lumens. But you can get a collimator head with the 7g5v2 and increase its lux to around 130k, but diminishing the total output from 830 lumens to around 600.
How big do you want the hotspot to be?
Hot spot (the britest spot ? )should not be too tiny but little bit wider to cover a deer , aprox 30 X 30 cm or little less /more .
What is collimator head ?
Please reply which one is better for me .
30cm^2 is puny, and you will definitely not be able to find rabbits at 300meters. That’s almost like a laser beam.
The hotspot is where most of the beam is concentrated, in the middle of the beam and the spill is the light coming out the side.
The collimator head is specifically for the 7g5v2, and is the same as any aspheric lens which turns the light into almost a laser. It eliminates all spill and focuses about 50-80% (depending on lens size) of the total light into one hotspot.
here are pictures of a STL-V2, 7g5v2, and 7g5v2 with collimator lens attached.
