Triple xre q4 Ultrafire p10
5 posts / 0 new
jonl
Last seen: 11 months 3 days ago
Hey guys, great forum, been lurking for a while. I had to jump on the triple bandwagon. I purchased a triple q4 with narrow optic from led supply. I was going to put it into my solarforce. Then it hit me, I pulled the bezel off of my ultrafire p10, removed the glass and the optic fit perfectly. The triple sat well on top of the pill sidewalls too, but then it was not contacting enough for good heat transfer. I found that a brass 1/2"male x3/8" female pipe reducing bushing would work to add mass to the pill. I cut off the hex part, inserting the treaded part with a wrap of foil tightly into the pill. I then filed the pill flat for the triple to sit on. It is powered by a 8x7135 driver set to high/low, with an Ultrafire 2500. This thing gets hot very fast. I have the batteries charging. I will do beam shots comparing with my solarfoce xml, and a 501b xpg r5, as well as tailcap measurements. Please excuse my crappy pic posting skills.
Pics
Edited by: jonl on 03/07/2011 - 11:31
Don
Don's picture
Last seen: 2 years 6 months ago
I'm no use at the fiddly stuff. Glad other folks are...
Welcome to BLF
Good to have you here jonl.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
fishinfool
fishinfool's picture
Aloha and welcome to BLF jonl!
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
Match
Match's picture
Last seen: 3 years 6 months ago
Welcome Jonl.  Good job on the p10!.  I always enjoy seeing what other folks can come up with for mods Smile
jonl
Thanks for the warm welcome guys. I took beamshots 10' off the wall. This was a fun little project. The p10 puts out a massive hotspot with nearly no spill. Great for less than 30'.
Tailcap readings: Fully charged ultrafire 2500 18650
Triple p10               1.84A Should be higher? 8x7135? Only .6a to each led.
501b xpg r5            1.39A 4x7135
Solarforce 2lm xml   2.7A   8x7135
Pics
