Disappointed from FocalPrice Sipik SK58 (maybe bad LED?)
I bought Sipik SK58 from FP (http://www.focalprice.com/detail_LF554X.html).
It has a really recessed switch which makes it a bit hard to operate, but the real problem is light output.
It is not very bright, but draws a lot of power, the wattage is comparable to my C30 so I thought they should produce about the same amount of light (C30: 0.4A*4.2V=1.68W, SK58: 0.95A*1.4V=1.33W), but they don't. The SK58 (Osram Golden Dragon?) is much dimmer compared to the C30 (Cree XR-E P4).
It also has a very purplish tint.
The MXDL 3W is there just for fun.
At full flood (wall @ 1m, same exposure/WB setting):
At full zoom (wall @ 1m):
There's another thing that bothers me: The LED looks damaged.
Here's how it looks:
Who ate my golden dragon?
First of all
Most FocalPrice flashlights have different leds from other chinese sites.
You have found it: DX sk68 has a Cree q3. The focalprice Sk68 has an osram GD.
Second: the led is not broken, all osram golden dragon have an edge "cutted". Completely normal... but in the other edge I can see a kind of "kasjkasdjkahkhgduif" but I dont know if it is caused by the optics or not... maybe the led is semi-burned in that location
Yeah, I wasn't talking about the cut at the upper right corner but about the defect at the left edge.
That does look like UV-light .... maybe not enough phosphor applied in production?
I ordered this one and it should be here pretty soon. I'm guessing it'll be similar to the focal price one (about the same price.) I've heard good things about the SK58. Will let you know.
http://priceangels.com/SK58_Adjustable_Zoom_Focus_LED_Flashlight_Lamp_Torch_p17869.html
Your amperage is lower than the one reviewer on the focal price site who said he figures his light is :
60 lumens with a 1.6A draw form a 1.2V Ni-Mh battery
Yeah it does look like the phosphor was badly applied uneven over the surface and missing at the edge.
focalprice !!! what more is there to say
except don't do any business with them what you receved is the quality i would expect from them
and dont except ther customer service to be any better
You really can't compare flashlights with different input voltages fairly. Secondly, OSRAM LEDs are not as efficient as CREE Leds.
As covered by other people, seems your problems are.
1) Not so good an LED - cost cutting with cheap seconds? maybe, but whatever the reason, your led is lacking a complete phosphor coverage.
2) fundamentally your torch has an older and less efficient LED. That looks to be an OSRAM GDP (as said before)
Damn, I havent actually said any more than everyone else aLready has haHA!
I had a few OGD leds and they were not bad. Your sample really is quite dim. Should't be that bad. My OGD were hard to tell apart from not optimally driven Q3 in AA flashlights...
Wrong light. The SK68 has an XR-E. The Sk58 comes in either XR-E or Osram. I don't see this as that big of a deal - I have an SK58 with and OSRAM and an SK68 with a Cree and the SK68 is brighter with the same battery.
I have the same kind of flashlight, but never knew it was a Sipik SK58 (or forgot). I got mine at Meritline on sale for $5 delivered. That flashlight made me decide that I will never buy another budget flashlight again which is not a Cree, or at least which does not have the brand and model LED listed in the product description. I don't know Golden Dragons, but I highly doubt that reputable LED is what's in there (shouldn't be hard for those who know, by inspecting the poster's very accurate depiction of the die pattern).
My LED 'image' looks EXACTLY the same as Haggai's. When I got mine, I wondered the same thing. It's blueish/purpleish, dim, and has that funky die pattern with poorly-applied phosphor and tinges of extra purple at the fringes. Yet, it 'does' work. The metal flashlight itself actually has a nice feel to it, and the single mode switch with orange tailcap boot works fine. The weak link in the chain is obviously the LED. Compared with my next-closest flashlight, my TOrch Light C78 (which has a Cree Q-something), the C78 is noticeably brighter with the same type of battery, with a better tint too. Then again, I bought the C78 for double the SK58 ($10 versus $5).
The flashlight is naturally about twice as bright with a lithium cobalt 14500. Tint is still pretty bad, but usable I guess, if you don't have high expectations. But most of us here do.
So that one got gifted to the girlfriend, as her 'first flashlight' (not so much a "gift" as a pass-along--though for her, anything was a step up). She actually loves it, and uses it often, even though I think it's weak. She actually likes that it's dim (LOL), because she uses it inside at night (to go to the bathroom, etc) where it doesn't wake her up, or overpower her eyes like a lamp would. She only uses it with alkalines so far (she said she likes the word "safe"), hence a separate discussion about higher-voltage battery options (and chargers). She doesn't use the zoom function, nor does she screw off the optic for (kind of) 'full flood' mode.
She later dug out a 2 - AA mini-mag knock-off she'd forgotten about--replete with incandescent bulb and twist-to-zoom, but with extra feature of a side switch. We compared these two bottom-feeder flashlights side-by-side in the dark. The incandescent fake mini-mag DID put out more light overall, but was so ringy due to the bulb, that it was only usable in 'full spot' mode. The Sipik put out about 70% the amount of light (approximately), but did so with a truly smooth beam pattern due to the optic, and had usefulness in any zoom mode. We took it outside, and in full zoom, it does throw enough to see things at a distance, albeit a smaller square of it. The fake miniMag was also more than twice as long. The Sipik can easily fit inside a purse, or even a pocket--not the fake MiniMag.
I think the MOST embarrassing feature of this flashlight, is the yellow triangle "laser" warning sticker on their flashlights. As if you were really gonna hurt your eyes with this thing.
All that said, even though my girlfriend 'likes' it (she doesn't know any better), i DON'T recommend this flashlight, and i DO regret purchasing it. A decent LED is all it needs to be a nice torch. But it doesn't have one. I think a better purchase would be what was on Meritline's 1-day deals page today:
http://www.meritline.com/high-power-black-aluminum-led-flashlight---p-55386.aspx
Today's price is $4.99/shipped, BUT it takes 16340's/cr123's. However, it's advertised as having a 'Cree' emitter, though it doesn't say what kind. It looks like a fixed-focus, 16340 version of the Sipik SK68. For the same price as I got the SK58, this is probably a better value, even if you have to buy your friend some primaries or get them a cheapo charger--BUT getting an AA version of this (or similar) is probably best, even though the flashlight cost doubles just because of the greater demand created by the AA form factor. But then again, once you're into $10 flashlights, you're not far away from cheap P60 style host/drop-in and cool multi-mode budget CR123 flashlights of respectable names like Ultrafire. Decisions.... But I think lurkers & newbies are best-off avoiding bottom-feeders unless they really know their needs, and know what the flashlight can deliver. I personally now have a decent collection of mediocre lights, and prefer now to exercise self-control and spend the money on higher quality, if fewer, items.
That is an Osram Golden Dragon emitter, but even good LEDs can be let down by bad drivers and poor lenses. From what I've heard of the SK58 it's really hit or miss. I wonder if Sipik used the same driver for the Cree and Osram versions and the Osram LED just doesn't play as well.
For the record, I've got an Osram version and while it's not as bright as a comparable Cree on the same battery (Sk68), it's certainly not bad.
As to the colour variations on the emitter at full zoom, I do NOT think it's a phosphor problem. I think it's actually the crappy plastic aspheric lens that's causing chromatic aberrations. It certainly fits with how chromatic aberrations tend to occur, at the edges of major contrast changes (edges of the emitter, or between the two dies on the emitter surface).
semi-burned in the location? chinese sites show its low-price labor in the way of price label. just take the comparison the beamshots,then do it.
I just ordered a Sipik SK68 from them last week, so I can confirm this shortly. It doesn't say it uses a CREE Q3, so it probably isn't. I should have verified this before ordering. I'm not a big fan of these manufacturers that keep the same model # but change out the guts depending on the retailer.
Oh for the love of...
THIS IS NOT THE SIPIK SK68. This is the Sipik SK58 which is advertised as having either an Osram led OR a Cree led.
I know this thread started off discussing the SK58, but apparently, the same LED confusion also applies to the SK68, which is why we've discussed both here. I know the thread has veered slightly off course, but it is the same manufacturer and vendor under discussion, so I wouldn't let it get to you.
That's a close up on the emitter itself (sorry, that's as sharp as I could get):
Actually the photo is quite sharp. It is a recent make of osram golden dragon i think. I got several older...
I am not sure that that is a Osram golden dragon. It seems a chinese copy of the osram GD
