Maglite 2D - 3XM-L T6 - TIR optic, 8AA - Build thread - Beam shots in Post#36
I was lazy. I didn’t want to cut another two of those copper rounds (blisters) and I figured I would just use the plate. I know it’s better to not use it.
https://budgetlightforum.com/t/-/6223#node-7272
Should be floody, but with two optics, one clear and one frosted, at least I can test them both out on the same light and have beam shots of both.
I know it’s probably too late for this suggestion, but I would’ve heated up that triple MCPCB to remove the white solder mask, sanded it down a little, then you’ll have a blank aluminum plate.
Good luck with the build anyway! I always look forward to your builds :slight_smile:
I went ahead and cut two more copper plates and now the T6 led stars are on copper, no aluminum board.
Wink
nice project.
More photos added in the first post. The leds are on copper now and it's shaping up well.
Looking good, Justin!
8)
I love your work Justin.
Copper, on copper, on copper. That’s hot!
nice build :slight_smile:
what adhesive you used for mount LED to copper ? Arctic alumina ?
Yes
Is that a Ledil Rocket or a knock off?
Knock off, as far as I know. They are made well, but they don’t look like any current “big name”.
The light is working. Beam shots tonight. Photos in the first post, show the rest of the build.
Looking forward to the for sale thread. :D I don't think you will be melting the TIR optics anytime soon, PILOTPTKs module also has them resting on copper and the body of my light got uncomfortably hot and the TIR optics were fine.
O-L, beautiful! However, the mouseover isn't working for me.
-Garry
I would solder the braid on the next loop down on the spring (at the point the top loop ends). You should get a lot more contact area and lower resistance that way… the way it is soldered now you probably only get contact at the bump in the braid.
It does now.
Yep, works! Thanks!
-Garry
