DMM woes
So I have a Craftsman DMM item no. 82141 as seen HERE.
It is giving me a consistent issue of blowing through the 10A fuses when I use it to take tailcap readings and I have no idea why…
I am not leaving the leads on the subject for longer than 10 seconds at a time nor am I running more than 3A through the meter so what gives? I really hope that this is not an issue of me being a dum-dum…
Is it very old? Can you return it? I suppose you would have already done that, but I thought I would ask first.
You set the meter to 10A DC and move the pos. lead to 10A terminal?
quote from HKJ: "Select DC current measurement and move the plugs to the 10A/20A input terminal. For flashlight measurement it is best to select the highest current range, i.e. 10A or 20A range, this is done to keep the voltage drop in the meter as low as possible. For a multilevel flashlight on the lowest levels it can be necessary to use a more sensitive range, but this is only recommended if the reading can be keep below 1/10 of max. on the selected range. For lights that uses multiple amperes a clamp meter is better (see below)." (from here)
I have had this one for about 3 weeks now…. I returned the last one bacuase it was defective
I have the IDENTICAL DMM and mine works great! It’s also quite accurate.
I don’t see how it’s even possible to blow a 10A fuse unless you’re shorting the battery.
You cannot blow a 10A fuse with 3A, maybe it is the low A fuse you are blowing?
No. I am for sure blowing the 10A fuse (And yes the fuses are in the correct locations). When testing, I take the positive lead from the 200mA socket and plug it into the 10A socket, COM does not change.
While testing, I use the COM lead to hold against the negative side of the battery and the 10A lead touches the flashlight body to complete the circuit…
Will reversing this have any ill-effects?
No, you can do it reverse. You're just making a complete path, like you said.
Sounds like you're doing the right things. If you have any questions about your fuse I have a 10A 250VAC one I can send you.
Otherwise I suggest you take it back again. bummer
Reversing the leads will only show as a negative current on your DMM meter , so no ill-effects.
It certainly looks as though you have the meter leads in the right sockets and a 3A current should not blow a 10A fuse.
When you have the tailcap on the torch , can you switch the torch on and off OK ?
With the tailcap removed , when you apply a short-circuit from the torch body to the battery negative , does the torch switch on OK ?
If you use one of your spare 10A fuses as a short-circuit between the torch body and the battery negative , does the torch switch on OK without the fuse blowing ? … If the fuse blows , then either the current is greater than 10A or the fuse is rated lower than 10A.
I hope you resolve the problem soon.
Well craftsman requires the use of fast-burn fuses…. is this really a necessity? the fuses that I took out are indeed 250V 10A fast burn fuses. Can I just use non-fast burn fuses?
The lights in question that I had used this DMM on indeed function properly (i.e. I can bypass the tailcap with a short and switch modes, tailcaps function properly etc)
However I have not tested the fuse in line with the short, so when I get some fuses I will try that out.
You could do like a friend of mine would do back when we were teenagers - wrap the blown fuse in aluminum foil. However, I would not suggest this!
-Garry
(This was a joke, do not do this!)
Strange …
Some thing is up if the 10A fuse is blowing at 3A , so the MM reading is 3A when the fuse blows
1/ Dont have a second MM to check Amps [ Flashlight ]
This sounds very strange indeed, the only thing i could think of is that the fuse is rated at 1.0A and the printing looks like 10A, as i’ve had bulbs and fuses that are very hard to read. Also is the fuse actually blown? Maybe the action of changing the fuse can disturb a bad solder joint in the meter which makes connection for a while until the current flowing breaks the dodgy connection and makes things appear like the fuse has blown.
here are some pictures of the fuse in question
The link on these fast burn fuses are so skinny…
and as you can see it is a 10A fuse
ok i’ll shut up this is way over my head! Strange indeed.
So, is it acceptable to run non fast-burn fuses in this DMM?
Are the fast-burn fuses the root of my issue?
I think the fuses are for CAT rating safety incase one does something stupid or accidental. Two of my old DMM’s dont have a fuse at all on the 10A range. I’ve measured 15A in the past! The leads get warm but the meter handles the power no problem! I would try the slow blow fuse and see if it makes any difference. What i’m trying to say is, replacing the fuse might alter the safety rating slightly if you work with mains electricity, but for flashlight measuring nothing bad will happen at all.
Thank you for this information! To be honest, the only time I use the 10A setting os for flashlight related testing….
Maybe I will use Garry’s idea and wrap it in foil!
That's the same fuse in my Ideal DMM. per my manual: 10A (250V) fast blow fuse.
Something else is going on here… Fast or slow, 3A doesn’t blow a 10A fuse…
You must have a light that spikes to over 10A… That’s really the only possibility. 10A fuses simply do not blow with 3A of current… They just don’t…
