I amended the instructions with the proper depth (I was tired and couldn't remember during the write-up). Here's the deal on this idea:
The average diameter of a pill base is 19.66mm. The stock internal minimag diameter of where the pill needs to be is 16.38mm. Now consider that the internal diameter of the thickest part of the pill base is 16.26mm that would only leave a 0.06mm wall thickness. Add to that most drivers are ~17mm and it gets harder yet.
One of the big advantages of drilling is that the pill base is left untouched, so you could still take it out and put it back in a P60 host if you wanted to.
[quote= brted]
Also, how do you power it?
[/quote]
I made an assumption here, but I'll edit the origional post to expound on this. With the stock 2xAA configuration, one will need to use a low voltage drop-in. Cheapest thing to do is is get an empty pill and add a driver/emitter. I'm very happy with the DX driver I linked to in the post.
One could also use a higher voltage drop-in (3-18vdc) and run it on two 14500's, or a single and a spacer. There's a bit of flexability here. I chose to stick to the alkaline set-up because most of these I make will be given away to family/friends.
[quote= srfreddy]
Only problem being where to find a bit that big....
I don't know how well the tightening to On works, but you could also get a Terralux tail clicky for Mini Mags. They have a simple On/Off and an "IQ" switch that has 5 modes built in. I already have a simple clicky.
Do you have to have a drill press, or can you do it with a handheld drill?
Any guesstimate on lumens using that DX driver? I like the idea of being able to use NiMH's.
[/quote]
The tighten to "on" actually works quite well. One could use the various aftermarket clickies available, I've tried em and they seem to do ok. Call me a purist, but I like the clean look of the stock minimag.
[quote=brted]
[/quote]
I won't lie, a drill press makes it much easier along with a vice and a strap of leather to keep from marring up the head. But yes, it can be done by hand.
[quote=brted]
[/quote]
I was actually suprised by the output using that driver/xpg combo on 2 alkalines. It compared favorably with my H51. Output was in between high1 and high2. I'd guess 150-160ish lumens? Needless to say I'll be ordering some more of those.
Match, thanks for taking the time to post all of this information. It'll give rookies like myself a chance to get our feet wet modding......without blowing anything up.
Match, that is so cool. I have 3 Mini Mags that are "loved" but not used. The truth is; I've always secretly thought the Mini Mag was a handsome little devil, just not enough umph for my needs/wants. I'm going to try this with an XP-G R5.
Match this is a great mod, well done indeed. The only probelm is now I'm going to have to build one, so little time and so many thing s to play with, sorry I mean build.
Suddenly... demand for 2xAA drop ins. ;) That SolarForce looks nice, but I wonder for how long it'll go before it's sold out. I'm looking at a MiniMag right now, the "ED" my boat carries will take a quantum leap. I have a Brinkmann 2D Mag clone I want to mod too, but the switch got chewed by a dog. (not even a hint of a scratch in the anodizing) Is it possible to get replacement switches for those?
Unexpectedly my brother gave me one minimag to play with , therefore I'm able to follow the path which was marked by the mod's guru BLF has, Great Master Match...
The idea is put it a tir optic from DX which look promising ,21 mm...I have a doubt , with this TIR lens the frontal lens go or not ?...if yes a coated lens from KD is in order soon together with the empty p60 set up
I don't know about the guru thing....I'm just a guy who likes tinkering. My father always told me, "it's better to be lucky than good..." I'm just lucky
For this particular mod, I stuck with the stock reflector to keep things cheap/simple. As far as TIR lens go, I have experimented with the 20mm narrow TIR from ledsupply and it works out well. Fitment wise, the diameter is about 1mm from perfect, meaning it will fit the head without the stock plastic lens, but won't self-center perfectly. One could probably adhere an o-ring around the edge to help with this. I've been playing with a few more variations of the "mini-match" theme, and one of them does use a TIR. One of these days I'll get around to posting some of them up.
Shopping at Target when i saw Mini-mags for $7.86. Grabbed a sweet red one immediately! The hard part is finding the proper bit locally. Looks like I will settle for 3/4" since it's just 1/32 off from 25/32. I can sand down the pill threads the rest of the way to make it fit. I'd rather figure out a way to get the best heat sinking out of it since i have an XM-L and a 2.8mA 5-mode driver i plan to run with two 14500 cells. High mode wil be just for show and low and medium for real use so I'm not too wworried about heat killing it. It's going to be a beast!
I have 1 already and 2 more on the way in for a few XM-L mods I plan on doing but on further digging I don't think any of them support 8.4 volts so running 2x14500 in the mini-mag will be tough unless you can direct me to a suitable driver. If not then I will have to go with regular AA rechargables.
The last one I already have from KD and is the standard 5-mode 8xAMC7135 driver: http://kaidomain.com/ProductDetails.aspx?ProductId=10995
I'm afraid the last one doesn't list input specs but one of the reviewers said 2 Li-Ions would burn it out. I need to research it further to be sure. I wouldn't have thought it too hard to find a 2800-3000mAh multi-mode driver that handles 7.4-8.4V. I hope you have a suggestion.
