garrybunk
(garrybunk)
November 16, 2012, 9:52pm
2
The Trustfire F20 "emitter swap" might be a nice first time "mod". Few threads here:
Original Post from old4570.
Newer post from keltex78.
Trustfire F20 found with correct 14500 compatible driver from Manafont and T-mart (US Warehouse) . Your choice of emitter.
Makes a nice inexpensive Pocket Rocket (on 14500) which can still run AA's for convenience.
-Garry
garrybunk
(garrybunk)
November 16, 2012, 9:59pm
3
Another One: DX's 52mm +/- modules into a Maglite (almost all require same grinding)
5xR2 module showing good detail on grinding needed. Another build .
My first mod was the DX single XM-L drop-in into a 2D Maglite with (2) 18650's (sorry I never posted a build).
-Garry
gords1001
(gords1001)
November 16, 2012, 10:05pm
4
Cheers Gary, that’s exactly the stuff I had in mind, I also need to add the popular light threads zy-t08/13 and Jacobs threads spring to mind. I’ll keep coming back to this as I have time, and probably move it to the mods section.
gords1001
(gords1001)
November 16, 2012, 10:41pm
5
Gentlemen,
Below is a quick tutorial on how I make my own deep carry custom pocket clips. For this example, I'm going to be using a L3 Illumination L10 graciously supplied to me by Jason at sbflashlights.com . This method will work on most small lights that have extra metal near the tailcap to allow mounting the wire. Please note that the photos below will show the poor L10 tail pretty beat up. This was not done during this mod, but was a side effect of experimenting with other clip designs…
Matches deep pocket guide.
[image]
[image]
[image]
Folks,
This is a short review of three OEM hosts I recently purchased from Ric at fancyflashlights.com (retail site of CNqualitygoods.com). Warning...pictures taken were with my phone while at my workbench and are not the best...
Short summery: Each of them impressed the heck out of me and was far and away better quality than most budget lights I've dealt with before. Since these are only hosts, I'm strictly speaking of machining, finish, and design. Shipping wa…
Matches host reviews.
[image]
As the resident Solarforce whore, I feel it is my duty to compare the more popular tail cap switches from my favorite flashlight company . . . and burden everyone with my opinions. I've also included a few pics of these guys on a flashlight so you can see for yourself if there's an improvement or if you just screwed $15 of ugly onto the end of your prized Solarforce.
[image]
[image]
[image]
Let's start with the first four that I'll call the self-defense group or, how to turn an inn…
Foys solarforce tailcap thread.
ULTRAFIRE P60 TRIO
THE STORY OF THE 3 CLONES WHO TRAVELED FROM CHINA TO EU
[image]
It's a story that begun when Surefire designed a 6P flashlight which was a great success. Apparently that sprung a ton of clones around the world. The most notable are The sloarforces who started with the L2. What about the others?
Can others make nice flashlight hosts for less? Yes, pretty much so. Even with variety!
The three P60 hosts are these:
The black one Ultrafire WF-504B - Black
The …
Budgeteers p60 review.
NANJG 105A 2800mA 4-Group 6 mode Driver
Reviewer's Overall Rating: ★★★★☆
[image]
Summary:
Size:
17mm
Voltage:
2.6-4.5V
Regulation
Linear Regulator
Current:
2800mA
Modes:
6 in 4 groups
Price Paid:
$4.70
Kaidomain 1)
1) This one was ordered early dec.2010 and seems to be a successor to the NANJG 105.
Pros:
Well regulated and efficient driver
Has memory
Has a 3-level group with no nonsense and good spacing
Has a high PWM frequency giving a stead…
Nanjg 2.8 driver review.
KD 7135 V2 drivers 3040/2280/1520 mA 8 modes
Reviewer's Overall Rating: ★★★☆☆
[image]
Summary:
Size:
17mm
Voltage:
2.5-4.5V
Regulation
Linear Regulator
Current:
3040mA
Modes:
8 groups selectable
Price Paid:
$4.79
Kaidomain
Pros:
Has memory (enabled by soldering)
Has 3-level groups low-med-high and high-med-low
Has a very high PWM frequency giving a steady light
Has a sort of low voltage protection
Cons:
Low …
Useful 7135 driver review.
Gentlemen,
Tired of always going to a party and someone else there has the same flashlight as you? Do you like bling but don't have the ching? Got an afternoon to spare? Read on...
(Quick summary: Here's how to make your own custom flashlight host using only a drill, hacksaw, sandpaper/file, and time)
[image]
Prologue: The plan here is to make a custom flashlight out of nothing more than 3/4" copper pipe and some spare parts using only hand tools, and without the use of a lathe. The e…
Matches build your own flashlight guide.
I wanted to start a thread where we can see all of the external mods that we do to personalize our lights . Whether it's for form or function , beautification or utility .
For example , I added a lanyard ring ( stainless steel split ring ) to my RC-G2 ( Q3-5C tint ) so I could easily detach or change lanyards . I also added a turkshead body wrap in type 1 paracord to facilitate an easier cigar grip .
[image]
Then I sprayed the lens on the inside with window frosting spray to diffuse the bea…
Jacktheclippers flashlight blinging post, warning, lanyards are addictive….
Hello,
I have been conversing with (cpf) techjunkie about the ever popular method of using multiple 7135 circuit boards as Master/Slaves in order to use multiple LEDs without having to go the series routine and have to use high voltage.
The following is a copy of the PMs between me and techjunkie. It's rather long and I hope it's clear enough as there is a lot of "quoting" in it, so read through and see if it helps. I did highlight all his replies in red.
1. Re: Everyman's Mod
Or…
Amc7135 master/slave guide
Soldering iron conversation/guide.
Well i decided i love the Dry but the look was well Dry, lol so i decided to follow Chicago and Dthrct, and do something different ,, i flamed mine in the oven ,, the tube could have probably stayed in longer but i decided having it two toned was cool , and if i want i can put it back in the oven to match it up i suppose but for now i think it looks cool , still dont know how to put pics in here so u will have to click on it sry ,, this is actually the first forum i have had trouble with pics an…
Flashlight baking guide.
This thread is intended for those who PROGRAM flashlight drivers and those who want to BUY/COMMISSION them for their own modding purposes.
We have a few members here who actively program drivers and the intent is to connect the people who want modified drivers with those who are willing to program and sell them.
Will those who PROGRAM and are willing to build-to-order identify yourselves in this thread. We'll keep it updated at the top of the thread so there's quick reference. You migh…
Custom driver thread.
Poor pic but it's too damn bloody cold out:
[image]
Had really good luck at the hardware store:
[image]
Heavy copper plumbing piece they had.
Watch this! [image]
[image]
Hip to where it's at, baby!! Perfect fit. [image]
Gonna solder ya now, sucka!!
[image]
(Found it at a flea market for 8 bucks)
Copper slug soldered to top, filed down KD pill to size ready to solder on the bottom opening:
[image]
Pill all done up:
[image]
Shiningbeam driver a…
Triple xp-g p60 build, no lathe required.
I am using a 2D Black Maglite to make a 3up XM-L T6 with a TIR optic. Remember I asked what the 50mm optic I had, was for? Well it isn't XM-L, but it's going to be anyhow.[Tongue Out]
[3up1]
I'm using a 2D Incan Mag and I am going to use the 3up star with copper backing it up. I don't have any solid copper rod, so it's 20ga sheet sandwiched into a 3.something mm plate. I still have to clean up the plate later on. This is "WIP", LOL.
[3up2]
The plate is four pieces soldered together.
Just one of old lumens mag builds, give you an idea of what’s really possible.
Old lumens reflector stippling video - removes rings from beams.
MarioSS
(MarioSS)
November 16, 2012, 10:44pm
6
Thank you gords that is one helpful thread for us noobs trying to learn some DIY techniques
gords1001
(gords1001)
November 16, 2012, 10:56pm
7
No worries, it serves two purposes, its easier to just link to this and not have to search to give an answer, and its easy reference for modders who can’t seem to fund a link. Just needs filling with any useful info hint hint. If you find a good post, throw it in here, someone else will benefit too.
Match
(Match)
November 16, 2012, 10:58pm
8
Gords1001,
Great idea to keep a lot of the good mod builds linked in one easy to find spot, although I'd call this post more of a reference than a guide.
Speaking of guides, that's something I've been meaning to piece together now for over a year... I should start on that tonight.
gords1001
(gords1001)
November 16, 2012, 11:09pm
9
[image]
[image]
[image]
[image]
[image]
[image]
[image]
[image]
[image]
[image]
Review was kindly made possible by Manafont.com
Product page link = HERE!
Model: SMALL SUN ZY-T08
LED: XM-L T6
Color BIN: White
Total Emitters: 1
Battery Configurations: 2 x 18650 rechargeable batteries (not included)
Voltage: 7.2-9V
Lumen: 1200
Switch Type: Clicky/Clickie
Switch Location: Tail-cap
Modes: 5
Mode Arrangement: Hi > Mid > Lo > Strobe > SOS
Carryin…
Smallsun zy-t08 guide/info thread.
This one came in yesterday. It’s not a bad light at all. The only negatives I see - the spongy switch, the fairly sharp machining edges just below the switch, and the ringy beam or artifacts around the hotspot. But these are all minor flaws. All in all its well worth the money. The beam is almost identical in brightness to the Small Sun ZY-T13. But it has pretty nice anodizing and machining all in all. It tailstands, and has a nice metal screw in bezel at the front of head. And it has a nice dee…
Smallsun zy-t08 thread with viffers resistor mod.
Just thought I'd share my latest pickup... I wanted a compact 18650-XML light I could cigar hold easily on my night-time jogs around the neighborhood. For this application the weight had to be well balanced between an XML throw-head and the tailcap. The body tube needs to be smooth without knurl, yet firm-grip-able between my knuckles. I wanted a good tight beam XML thrower (or at least one that leans more towards that). I need to be able to spot dogs and other potential threats well in adv…
Mdxl-76 skyray a01 clone guide - current mods/driver mods/taicap mods - serious budget thrower guide.
gords1001
(gords1001)
November 16, 2012, 11:13pm
10
I can sort that match, as I say, if we can stick all the usefull info links in here and get it stickied, we have a simple post for everything. Just a link and a brief description of the info is surely helpful, if it gets stickied, I’ll remove all my chat and would ask others to do the same, keep it a pure info thread.
MRsDNF
(MRsDNF)
November 16, 2012, 11:27pm
11
Fantastic idea. Would it be possible to keep the links in the first post and put the authors name on the title?
gords1001
(gords1001)
November 16, 2012, 11:43pm
12
My thought was, once the infos in here, I can gather it into specific posts - general skills, popular light specific info, mag mods etc, once that bits sorted, I’d askeach person to delete their post/chat so we end up with a reference sticky where we can click in, link a #post and hopefully guide people to the right spot. So any links you have, stuck em in here with a brief description, in a couple of days I can edit my posts and we end up with one topic with links to a series of guides, so please, try to be specific with descriptions of links, and try to keep the mods to stuff that doesn’t need a machine shop - if the guy needs that, they probably pretty much know what their up to…
gords1001
(gords1001)
November 16, 2012, 11:47pm
13
Missed that bit, I’ve tried to credit authors in my link descriptions, please do the same, eg matches mini mag, or viffer “light mod” etc.
Kokopelli
(Kokopelli)
November 17, 2012, 11:36am
14
That was the thread I were looking for. After those XPE2 mods Match have shown I plan to order some from Cutter or maybe just stick with XPG2 mods till Chinese shops bring in XPE2s. Unfortunately I don’t have much used lights to break into, so this thread will be useful to follow successful mod hosts.
I need a twist head mod change tactical light with a good circuit. But quality lights usually start from $40 like Limintop TD12. so I’ll keep my eye on here for cheaper moddable lights.
DON_KIDIK
(DON KIDIK)
November 17, 2012, 12:47pm
15
Good idea pal,send me your email Gords.
DON…
Rufusbduck
(Rufusbduck)
November 17, 2012, 7:16pm
16
Would the Anatomy of a 7135 driver fit? I answer quite a few posts referencing the threads collected. Some are mentioned above. I was hoping it would get stickied on the DIY page to make it easier to find but this is just as good, maybe better. I would add the suggestion that individuals bookmark your thread for rapid access. A sticky makes it easier for newbies to locate, “my subscriptions” I use to keep track of interesting threads, but bookmarks is where I keep items for quick access.
gords1001
(gords1001)
November 17, 2012, 7:28pm
17
That would certainly be a usefull link. I’ll spend a bit of time later editing this into sections, then delete whatever is no longer needed. Once I’m happy with that, I’ll probably ask people to delete their bits so we’re not duplicating links.
I was thinking something like :-
Driver links:-
Mag mods:-
Common light threads:-
P60 hosts and drop ins:-
And so on. Please offer up any other suggestions/ links then I can get started on it tonight or tomorrow. :bigsmile:
gords1001
(gords1001)
November 18, 2012, 2:50pm
18
I just got a UniqueFire UF-V3 and while it is an awesome little performer, it is way under driven (1.74A on high). Obviously I want to replace the driver but the pill in this light only takes 20mm drivers. This poses a problem as there are no 20mm drivers I know of that meet my needs. I first thought I could just place a 17mm driver inside behind the 20mm driver but the space inside the pill is only 4.5mm deep. Besides, being an all aluminum pill, soldering a good, dependable ground to the drive…
Johnnymac’s guide to adapting a 20mm pill to recieve a 17mm driver, light in question is a uf-v3.
gords1001
(gords1001)
November 19, 2012, 4:29pm
19
[image][image]
I said I was going to build 12 Maglites for the Holidays. Well, I decided to make sort of a reality build, with a time limit and time frame, blow by blow. I am going to mod 12 of the 2AA Mini Maglites. Two of each color (Black, Red, Blue, Green, Grey and Camo). All of them will have copper heat sinks and will be Direct Drive with Nichia 219 leds from IS. The Nichias will be reflowed onto 14mm Cree XP-G stars. The optics will all be TIR and vary from 15 degree to 45 degree. There …
Old lumens marathon nichea 219 into mini mag direct drive thread.
Old-Lumens
(Old-Lumens)
November 19, 2012, 4:52pm
20
Easy to link to my posts and they can look thru them.
JohnnyMac
(JohnnyMac)
November 19, 2012, 7:13pm
21
Converting hollow SA-305 pill to p60 pill
Some pics of a hurried upgrade to the SAiK SA-305 3*AA torch that I got the other day.
[image]
[image]
First a few words about this light in stock form. Simply put it's a great form actor. Build wise the machining and anno is decent but the 3*AA battery carrier, pill, driver, emitter, and lens all suck.
Battery Carrier: Sucks because the springs are too soft in it and don't hold the AA cells tight enough. They bounce in the carrier and can cause the light to change modes when set down …
