because as mentioned polarity doesn’t matter. Both ends have the exact 1/8” protruding brass-cap style contacts with the positive in the middle in the form of a triangular u-bent protrusion. That’s one way designers kept this torch as compact as it is even when zoomed-out. No big tailcap spring like the MagLite IOW to handle the weight and sliding momentum of those D’s. Although of course the Mag’s spring does compress a lot so that deal is prolly not so much a big deal.
Btw, as I was checking out yesterday the young buck cashier got really interested in it. He ended up buying one after Lumatic planted the seed of flashaholicism in his unsuspecting fertile mind.
Keep in mind that it seems to be entire regions where this light is unavailable. Unless, of course, one particular store in a region where it is available happens to be out of stock.
I bought one from my local Costco today for $48.99. It is bright and from my rough estimate around 650 ANSI lumens (using the Duracell that came with it). I did spend some time going through three boxes to find one that has the best white tint. That is definitely an advantage shopping locally, you don’t have to play the tint lottery.
The light feels sturdy in my hand. Anodizing looks good and it has square threads with surprisingly ample lube on the tail cap. Although it does not bother me, there is slow PWM on low mode. I would say it is somewhere around 300Hz.
after watching your video comparison with the tk60. kinda making me want one of these now. does this coast throw like the hd 2010? And in flood mode, is it floodier than the skyrayking?
Yes, it throws and floods. Quite well. You can’t truly compare these lights to this one mainly because it’s a zoomable with an aspheric lens which gives it different characteristics including how it projects lumens OTF, but suffice to say it’ll be a bright unique tool in your light repetoire.
I think you’re gonna like it. But if ya don’t like it then take it back. What do ya have to lose? It’s not like you’re ordering it from China. 8)
The HP550 has a substantial raised dome in the center which if you compare it to a TIR with a recessed cavity which then essentially rests on the Led, then can ya really call it a TIR or is it something else? Perhaps a hybrid? I guess that’s why I prolly loosely called it an ‘aspheric’ in this case because if it weren’t moving it would look just like one - excepting the ribbon of concave perimeter. The dome btw is about 1” in diameter and the concave perimeter is about 3/8”. I would guess that it’s maybe about 1/4” raised from the concave surface.
I’m basically not familiar with other current Led Lenser’s out there with TIR so you guys that have those could you describe them?
Btw……here’s a thread with some good shots of TIRs (collimators).
The lenses are a polycarbonate lens. I don’t think it hurts the throw, but again plastic can be scratched where glass can’t unless you do something crazy.
Polycarbonate is still pretty tough stuff. It will hold up well unless really abused. It can also survive impact better. If that kind of lens had to be ground and polished out of glass, this thing would cost a lot more than $50.
I wonder if they’ve thought of adding a fitted filter cap at the end of high transparency glass for those who want a stronger cover, also they could have colored filters for those who want red and yellow and blue for night.
