Making a cutdown 1D Mag-lite LOTS-O-PICS !
Nice job Chicago X. Old-Lumens sprang to mind when I started reading this and yep there he was. Are you happy with the new purchase? (The lathe).
thats nice… i like how you saved the knurling on it the way you did. only thing i would have done different (no lathe and no skill with one, so no room to talk really :stuck_out_tongue: ) is save the side switch… but im sure whatever you have in store is going to be amazing
also, now that i think of it… if you did save the side switch, you wouldnt have been able to keep the knurling the way you did, so i guess its a catch 22 on that one
The 1D can be done with or without the side switch. The overall length changes since the switch stays, but it can still be done. The knurling can still be there, but it would not be as balanced as it is this way. It is, as they say, "doable". The OAL of the knurled section is (if memory serves), about 75mm, which works out ok, for either a 3 or 4AA holder or a 26650. The space between the knurl and the switch is (about 20mm??), so it would mean cutting right at the back end of the knurl, for proper OAL with a Std tail cap (which is about 40mm deep with spring compression). I've slept since then, so I may be wrong.Wink
He’s wearing gloves? I just assumed he dropped his wallet or something in a port-o-potty and had to fish it out with his hand. :~
Of course, people are noticing just how many Maglites are standing in the background, in that "hand photo". Looks like he's got a good start on a run of them.Wink
All I know is that one of them is mine. I'm THRILLED!!!
Oh damn, I didn't realize those were all cut down already :)
Don’t you mean a T8
The balanced looks resulting from the non-knurled band on the tailcap end…man!
I have access to some good machinery but I’ve never attempted cutting threads. If this was a class I’d be frantically taking down notes.
Keep up the super work C-X.
Thanks for the correction - I will update the OP.
Grumble grumble damn dyslexia.
I wouldn't normally wear gloves while machining (for safety reasons) but I was trying to keep oil/grease out of some stitches on the left hand.
No internals specced yet, but nice Firefly reference !
[quote=MRsDNF]
[/quote]
If I had known how much fun one was, I would have picked one up years ago. Now I need to sell a few lights to fund a mill.
i bet some HUGE DEEP mag heads could fund your mill 0:)
not that i could afford one, but id be here drooling
As soon as I saw title and author I had to read this. Really nice work CX. If you milled down a section of the tube, could Justin do a woody inlay? Then you could have a side switch and eliminate the knurling altogether.
Thank you sir !
Stay tuned....
I don't think it would be a problem turning the knurled part down by the thickness of some wood veneer. I'm ready to take such an order at any time.
If anyone needs some stock Mag parts, please shoot me a PM.
Do you mean modded?
What kind of parts
Don't you mean modded?
This is a double post, and will be deleted soon. Ignore!
Ignore this post, I am experimenting with a error.
Well, modded too.
I was in this case referring to the take-off parts from the last round of cut-down mags - switches, towers, springs, etc.
I’ve wondered why it wasn’t done this way to begin with, all that splicing and fitting and glueing and pressing be danged!
Very nicely done Wayne, perfection indeed!
Thanks very much.
I would guess that more aren't done this way, because it takes 3-4 times the work !!!
