Nice review Match ..
Cool lookin' knife.
Nice review, same thing happened to me last week. i just bought an mte m2 and dropped it. wont turn on but i had my x2000 with me so i tried the tail cap and the led lit so i was relieved. opened the switch and found no solder on the pcb to hold the spring on. i soldered the spring on and added solder to the outer ring of the pcb and seems to have done the job.
Great review Match, thank you.
I got Yezl Z1 yesterday and here are some notices:
It has very thin - and much less - threads and body is different - worse - than Brinyte PD08 (which looks the same). But it is crazy bright and fits a pocket so as long as its threads are ok and nothing breaks, I very much like this light.
How much is shipping to the US for one flashlight typically?
If you order multiple lights is the shipping only a little more or does it go up a lot?
$4.95 for 1
$7.40 for 2
I registered and cost delivery is 5$ air mail,
35$ is big.)))
Dx UltraFire P10 18$, + KD xm-l 9$, + KD AMC7135 Circuit Board 5$
ONLY 32$ + FREE R5 AND DRIVER LEFT,
OR change Dx UltraFire P10 ON Dx TrustFire TR-801 13$
ONLY 27$ +free Q5 and Driver.
BINGO!! Someone on here has a 801 with a KD 7135 and XML, I would love to see some pictures/ beam shots
Take a look at the AURORA SH-032
That´s my next modding project for XM-L.
p.s. Reflector of the Aurora is 20x20mm, all other "EDC XM-L´s" have 18x12mm and it´s stainless steel ;)
I've got one, and it is a very nice light. Review here. Heat is going to be a very big issue in an stainless steel body. Keep the current down - I suspect an XP-G R5 with the stock driver would be better.
Andi thanks,
It’s good too,
but I think AURORA SH-032 Wight its is 104g. rather more for EDC
UltraFire P10 weighs only 52g.
True, but it is a very, very nice light - just not one to mod with a high-power LED.
no matter about weight, i have stable trouser pockets.....my interest is more the size.
Don, as about UltraFire C303, you did its review. There probably to put xm-l 16mm
And driver KD 8* AMC7135 Circuit Board?
That would be better - it would lose more heat. But I like my one the way it is...
It would be a pretty easy light to mod.
Wow that’s weird Mine has the longer threads like the bryinte on the right … It is 6 full turns before it drops off the threads … The head side does look a little bit shorter threads and went 5 turns before it fell off the threads . Wonder if your tube is just flipped around?? …I do like my bezel ground down smooth it looks and feels much better …My biggest complaint with this light (xp-g version )Is the body,specificly the center tube The flat spots on the body makes it slicker for no reason ,just so they have a place to advertise .What I want is just all knurling . This is the same reason I’m afraid to buy the D-11 Nitecore …Silly flatspots
Send me your bezels ..
Boazs' Yezl bezel grinding services
lol...thank you Dr. Seuss!
No, it isn’t flipped, it is a different body. Even the lanyard holes are ultra thin on Yezl. I suspect different batches or even built by different factories with the “same”(!) specs…
