actually works well enough for up to single 18650 lights, the 2x18650s are a bit too heavy for it. I just need another more rigid tripod to hold the lights. The various little ones are basically useless for holding lights.
Thanks for the info, Don. That clamp looks fine for most of my uses, I just don't want to wait a month to get it. :) I've had an Ultrapod II for many years and find it quite sturdy. Here it is holding quite a load.
I'd try your local music gear shops for microphone holders - take a suitable light and see if they'll hold it stably. Probably won't be a huge amount more than DX prices.
big metal clamp bend one leg in a vise drill hole ,add bolt , double nut and add to the tripod ,
OR
make a small piece of wood to use in your quick release ,bolt it to your clamp and done .
OR
2 clamps & 2 big rubber bands
rubber band the two together one up one down,, one left the other right ,two rubberbands grabbing them in the middle and bang instant clamp up clamp down .Used on numbers of things including bikes ..I like them better than the 4 different bike mounts i have bought .. this type of clamp >>> http://www.harborfreight.com/1-inch-spring-clamp-67091.html
Or get a couple of these really cheap mini tripods and put a small amount of silly putty on top. After your done you can always play with the silly putty. :D
