I truthfully do not know, I can tell you when I have taken the phosphor off the LED in the past (while dedoming) it becomes a deep blue.
Based on that chart, I would say it was around 8000k. (general estimate)
Edit:
As ryan pointed out, their blue XM-L is 450-465 nm so it would be a royal blue.
However, for what ever reason it seems that the blue LED in their colored XM-L is much less efficient than a white one. So now I am doubting myself. :( The white die produces 100 lumens at 350 mah and the blue one produces 13.9 lumens at 350 mah.
nice run through scaru. Only niggle is that CW Cree LEDs are generally 65CRI, although the newer XM-L2 CW seem to be 70CRI. NW and warmer are 75CRI, one reason so many people like them over CW
That’s what I don’t understand. If it is more blue and brighter the less phosphor, why are blue xml dimmer? I don’t think there is any way to “redome” an led after stripping the phosphor is there?
"For example, the efficiency of a typical...yellow phosphor based white LED ranges from 3 to 5 times the efficiency of the original blue LED because of the greater luminous efficacy of yellow compared to blue light."
Basically, human eyes are much more sensitive to white (or yellow) light which is the cause of all this.
http://en.wikipedia.org/wiki/Luminosity_function
The blue light produced is at 450 nm while the white light (after going through the phosphor) is around 575-600. So if you look at the graph, the human eye is very sensitive to white light, but not the blue light.
Excellent resource. Now if you could do one on the meaning of “XM-L” vs “XP-G” etc. It would be neat to know more behind the naming and designation of each.
What do you mean? The number of bond wires, size, efficiency, etc? Maybe if I get a chance I'll do that but this one was prompted by a few people PMing me in the past about tint, along with Nitro's question about where to get a neutral LED.
What surprises me is I was able to do 90% of this with out having to look anything up, I guess that's what happens when I spend so much time here.
I’m beginning to worry about how much I soak up on something I take an interest in, six months ago, I didn’t know what an xm-l was….know I’m growing bored of them…not bored as in not using them, just want to play with other things, I’m going backwards though, starting playing with xp-g’s etc. Bothering about modes and tint more than total output.
Sometimes a q5 in a suitable host with a good 1.4a driver is more usefull than an over driven xm-l lumen monster.
