Cree, Luminus, Seoul Semiconductor, and Nichia LED comparison
Oops, you're right. I just checked and no one has the 90 CRI XP-G2 in stock yet.
The problem with boosting the red with phosphors is the conversion from blue to red light tends to not be very efficient and the phosphors are expensive and hard to work with consistently. It is cheaper and more efficient to do the conversion with filtering agents. Or at least that’s how it was explained to me by an LED research guru.
Ok, I'll change it.
I understand that manufacturers need to drive down fabrication costs to facilitate adoption…but in my admittedly uninformed opinion, that sounds like laziness in the R&D dept. Interesting point though.
It’s not to say that there is no magic phosphor phoo involved with all high-CRI leds. I think that the filtering technique is used mainly in high CRI LEDS with high color temperature and ultra-high CRI values (95-99 CRI).
Just changed the title as I ran out of room to list all of the LEDs. And to think, I was only planning on this covering XP-G and XM-L.
Thanks Scaru for doing this!
Very useful!
Osram emitters? The dragon series isn’t as commonly found as cree parts, but they’re found in a decent number of low-to-midrange chinese lights.
Not quite enough info on them to do a full entry for them, by that I mean no one has done any lumen testing. (afaik)
My brain is a bit jello right now…
Do we have specified bin/(not nearly as important, but interesting)tint for Match’s emitter tests?
Wow, thanks, for all the info. I do think it was quite a large pill to swallow, but we are all on a geek diet. I will definitely refer to this post many times forward…
I certainly agree, I have trouble getting through it and I wrote it. :P
You would have to ask Match, I'm not sure.
Great information here! Thanks a lot for compiling and sharing it. Sticky’d.
Wow, very useful information. Being somewhat new to this field it will come in quite handy. Definitely going to save this info to pc for future referencing as well . Thx
Great infos! Big job! wow!
I re-read all twice, and found small missings or mistakes that made through the correction 'till now, so I'm listing them here to let you correct them (sorry to make you work more! ):
SST50 and SST90 as you know are from Luminous, it would be nice to mention this, as on all other emitters it was written they were from Cree.
The SST50 picture is derailing, because it's reflowed on a Cree star... can make some confusion to the casual reader..
SSC P7, same as above, would be nice to mention it was made from SeoulSemiConductors
Last, the ending source/list has CREE as provider of infos and datasheets for ALL the emitters, which is clearly not.
Cheers
THanks for the corrections, they have been fixed.
Updated with a better lumen graph for the Nichia 219 as seen below.
Updated with info on XR-E EZ900 v. EZ1000.
Thanks to you Scaru for the time you spent on this, and to everyone else who contributed. For me being a newbie this is a great reference for learning and purchase decisions.
“Bump to ask if there are nay other LEDs I should add. It currently has XP-G, XP-G2, XM-L, XM-L2, XP-E, and I’m doing XP-E2 right now. ”
SSC P4, used a lot of those.
Osram Golden Dragon / Diamond Dragon
Luxeon Rebel / Rebel ES
Nichia GS
edit
just read post 70 and 71 about the Osram.
