Yes, to find that type of LED you need the model number. This is listed in the datasheet. Then simply take the model number and google it. (In this case:
I am a newbie and have been reading this forum for a while trying to get myself educated. Your work on the XM-L LEDs has been most helpful for my to get a little better understanding of some of the technical aspects of these magic flashlights that I am so intrigued with.
I have purchased a few different lights and am now at the point where I want to build my first one. With this info I will be able to settle on at least one element of the new build.
I would not speak of the 5C1 or 5B3 as they were 1A or 1C, writing them like 5C and 5B. Starting with the number 5, CREE gets more "precise" with the tint that is offered. It's not like 1C which has a bigger quadrangle and it's not as precise as those.
CREE does not consider "2" tints to be Neutral White, they are still Cool White. Number "5" is considered Neutral White by CREE, not Warm White.
XM-L bins can go lower that T, like S6 is the lowest mentioned by CREE. Also I have not seen T1 anywhere mentioned by CREE so far. For example we have XP-G R5 then S2, XM-L S6 then T2, XM-L T6 then U2. Bot no S1, T1 and U1.
This may be true, but I see no reason the 5 bins have to be more precise than the 1A bins. If more people say I should change it then I will. :)
Good point, I will add that 2 is CW, however if you have ever seen a 5 it is quite warm... So do you guys think it should be based strictly off the spec sheet or reality?
Just checked on the sheet and you’re right. I’m changing that now. I don’t think the S bins need to be added because, well have you ever seen a S bin XM-L for sale? The only place they are found is Mouser or Digikey, a place that also would have the same tint in a T bin.
1C is actually 1C0. And 5B cannot be 5B0. If you buy 1C it can be greener or yellower, even so it's generally lemon-ish. But just because 5B is simply warmer that does not mean the second number should be ignored. Even so, almost all 5B are the same, while not all 1C are the same.
Regrading S6
If you take a closer look at CREE datasheets you can actually see, there are also S2 S3 S4 S5 and S6. Actually CREE shows S4 S5 S6 as being the High CRI (85 & 90) of the new XM-L2. I do not see a point in ignoring this fact.
"For XM-Ls the brightness bins range from S4 (which is the least efficient) to U3 which is the most efficient. The order is S4, S5, S6, T2, T3, T4, T5, T6, U2, then U3. Most lights are a T6 bin unless otherwise specified."
There is not a S3 as that is not one of the bins available for XM-Ls if you consult the datasheet.
Yes, the S2 and S3 are only present for the new XM-L2 http://www.cree.com/~/media/Files/Cree/LED%20Components%20and%20Modules/XLamp/Data%20and%20Binning/XLampXMBL.pdf
You could mention that "5" is specified as being Neutral White in CREE datasheets.
Nichia for example says White and WarmWhite for the 219 series. For them some Neutral Whites (5000K) are simply Whites, and below that they are all Warm Whites.
You’re quite right!
It makes very good sense of Cree to subdivide the bin boxes at the lower Kelvin temperatures.
The perception of the color shift between two temperatures is not proportional to the Kelvin temperature but to the reciprocal temperature. See the MIRED scale here.
So perceptionwise the 1A box is quite small and the 5C1 box is quite big.
XMLBWT-00-0000-0000U20E1 - 6500K, 65 CRI (on mouser.com)
XMLBWT-02-0000-000LT60E3 - 5000K, 75 CRI (on mouser.com)
The E1 and E3 are kits #'s, where E1 includes 1A, 1B, 1C and 1D, and E3 includes 3A, 3B, 3C and 3D (all from the CREE data sheet: CREE Xlamp Xm-l LEDS). So if the kit #'s can't point you to the exact tint, what would? Or do you simply have to take your chances?
Ohh! Forgot to mention: Thank You scaru!! This post is very informative!!
Ok, yes i saw those too but that info doesn't seem to be provided by Mouser. Those order codes are called the manufacturer part # by Mouser, so, still unknown what you are ordering?
Lol Scaru, I think that post of mine was up for all of 30 seconds.
Here is my revised response:
Some sellers know the bin code and will tell you if you ask. If the sales rep doesn't have that info handy, someone in the warehouse should know. If they sell individual stars, the bin code is usually printed on the back of the star. If they sell by the reel, the bin code is usually printed on the reel.
Having said that, I've never tried calling Mouser, so I don't know if that's something they would do. Same goes for Digikey.
