Thank you. This addresses a question I had about dedoming.
Quote
To increase luminance the TIR light needs to be reflected back to the die, thus the reflecting surface must be very near to the die. Either you remove the dome completely or you only leave a small layer (<0.5mm).
Unquote.
I had Wondered if there was a range of apparent focus/tint shift. Edit relative to the amount of dome removed.
One of the biggest problems I see here is that the surface of the blue chip is not flat, not even close to flat, so while the critical angle in a GaN:Air interface is still 24 degrees, the way the surface is photons emitted from the active layer at many angles still have a chance to escape.
Thanks Dr., very illuminating (pun not intended) , I have been thinking a lot about led optics (without being a physicist -I am a cell biologist actually-), but there is not that much written down in a way I can understand it. This read helps a lot, some things I knew, some things I suspected, some things I knew wrong, some things are new to me .
I wouldn't mind the long version sometime (illustrated and well?)
Which high powered LED now has the highest luminance? Is it still XR-E, or is there anything that surpasses it? The XP-G2, XP-E2, XP-C or anything else?
Also, is there any breakdown anywhere that lists the luminance of all the different LEDs, like the Cree, Nichia, Luminus, etc, so that we could look at that data and decide which LEDs we want to play with and which ones we would not?
Well, this shows that the XP-E2 produces more light per mm2. Of course the XP-E2 has a wider viewing angle at 110 degrees v. the 90 of the XR-E. Then you have to take into account the XP-E2's efficiency at higher currents.
You can beat the h*ll out of a XRE (heat¤t-wise that is ) without destroying it, this remains to be seen with the XPE2. In other words: what does it do at 2 Amps instead of 350mA.
thanks for the article, very educational. i learned a lot.
i have a question. according to your explanation, d=sqrt(I/E0)=sqrt(L*A/E0)=sqrt(L*pi*0.9 / 4*E0)D = ~ 8200 D,
throw distance is directly proportional to reflector diameter. so what is the purpose of deep reflectors such as solarforce skyline, HS-801/802 ? what do deep reflectors do?
another question. is there a limit to the throw distance-reflector diameter relationship? i mean, having a reflector infinitely big doesn’t give u infinite throw, right? at which point would the reflector size has no effect on throw distance?
I’ll have a go at this. When it is deeper the spill diameter is reduced because the led is farther from the opening. That little bit of light that would have been in the outer spill that is blocked by the longer reflector is instead reflected out the front with the rest of the light, resulting in that fairly dim amount of light being added to the light in that smaller area. So while it does add a little to the hotspot, it’s not enough to make much of a difference.
