It is safe to discharged to this level. I have two times seeing the red LED flashing even after I switch off the light, then I took the batteries out, both times measured 3V on my batteries. I guess under load, it will be below 2.75V. When I put the depleted batteries back, it will be green LED. If she has something like EA4 that can measure batteries voltage, she will be perfect perfect. She is already perfect with this low voltage warning feature as on par with many other new flashlights with low voltage protection.
Again, no matter how good or safe 18650 flashlights are, everyone should have at least one good multimeter if want to use 18650 batteries, I have two and put them in different houses. And treat batteries with respect and don’t abuse it.
Ok, very interested, so I would definitely want the U3 or XML2 version, how would I go about ensuring that I got the latest, greatest, finalized version?
You have to remember that this is definitely an outdoor light and not one for regular indoor use due to the nearly 500 lumen low. Having a light made for lighting up a lot of area at a good distance you just may prefer the U3 over a neutral T6. There will be a noticeable difference in output between the two. I measured a 400 lumen increase over the U2 version with the U3. You should see at least 400 lumens less than the U2 with neutral T6 making a difference of around 800 lumens between the U3 and NW T6. Outdoors that difference should be noticeable but, granted, only if you ever saw them next to each other. As they say, ignorance is bliss but for many here, just knowing they could have had it brighter is enough to cause dissatisfaction.
That’s a good point, there was 14 left in stock when I posted the link, we’ll see how fast they go as I won’t be ordering before February. Guess I have a month to make my mind up….
So your saying it won’t be much good for checking behind the sofa? :bigsmile:
I thought outdoor light is more suitable to use NW for better penetration, while indoor light is more suitable to use cool white for better brigthness.
