Not quite enough info on them to do a full entry for them, by that I mean no one has done any lumen testing. (afaik)
My brain is a bit jello right now…
Do we have specified bin/(not nearly as important, but interesting)tint for Match’s emitter tests?
Wow, thanks, for all the info. I do think it was quite a large pill to swallow, but we are all on a geek diet. I will definitely refer to this post many times forward…
I certainly agree, I have trouble getting through it and I wrote it. :P
My brain is a bit jello right now… Do we have specified bin/(not nearly as important, but interesting)tint for Match’s emitter tests?
You would have to ask Match, I'm not sure.
Great information here! Thanks a lot for compiling and sharing it. Sticky’d.
Wow, very useful information. Being somewhat new to this field it will come in quite handy. Definitely going to save this info to pc for future referencing as well . Thx
Great infos! Big job! wow!
I re-read all twice, and found small missings or mistakes that made through the correction 'till now, so I'm listing them here to let you correct them (sorry to make you work more! ):
SST50 and SST90 as you know are from Luminous, it would be nice to mention this, as on all other emitters it was written they were from Cree.
The SST50 picture is derailing, because it's reflowed on a Cree star... can make some confusion to the casual reader..
SSC P7, same as above, would be nice to mention it was made from SeoulSemiConductors
Last, the ending source/list has CREE as provider of infos and datasheets for ALL the emitters, which is clearly not.
Cheers
Cheers
THanks for the corrections, they have been fixed.
Updated with a better lumen graph for the Nichia 219 as seen below.
Updated with info on XR-E EZ900 v. EZ1000.
Thanks to you Scaru for the time you spent on this, and to everyone else who contributed. For me being a newbie this is a great reference for learning and purchase decisions.
“Bump to ask if there are nay other LEDs I should add. It currently has XP-G, XP-G2, XM-L, XM-L2, XP-E, and I’m doing XP-E2 right now. ”
SSC P4, used a lot of those.
Osram Golden Dragon / Diamond Dragon
Luxeon Rebel / Rebel ES
Nichia GS
edit
just read post 70 and 71 about the Osram.
also wanted:
Nichia A versus B
Luxeon PC Rebels, versus ordinary Rebels
(or a pointer to a more recent list of LEDs with pictures if there’s another one somewhere, I vaguely recall another …??)
Thank you for very useful infor. I’m using XM-L with 500 lumens. I want to change to XHP70.
Summary:
Cree
XR-E: oldest - 7.0x7.0 - 1.0x1.0 - 1mm2 - 56-114 lm
XP-E: 2008 - 3.45x3.45 - 1.0x1.0 - 1.0mm2 - 80-306 lm
XP-G: ??? - 3.45x3.45 - 1.4x.14 - 1.96mm2 115-573 lm
XM-L: 2010 - 5.0x5.0 - 2.0x2.0 - 4mm2 - 200-1105 lm
XM-L2: 2012 - 5.0x5.0 - 2.0x2.0 - 4mm2 - 186-1193 lm
XP-G2: 2012 - 3.45x3.45 - 1.4x.14 - 1.96mm2 - 113-558 lm
XP-E2: 2012 - 3.45x3.45 - 1.0x1.0 - 1.0mm2 - 78-329 lm
MC-E: ??? - 4x 1.0x1.0 mm - 16mm2 - 280-1085 lm
MT-G2: 2012 - 9.1x9.1mm - - 506-920 lm
Luminus
SST-40-W: 1000lm
SST-50: ??? - 7.3x9.0mm - 2.2x2.2mm - 5mm2 - 275-1890 lm
SST-90: ??? - 10.0x11.0mm - 3.0x3.0 mm - 9mm2 - 600-3915 lm
SBT-90: ? -? - 2000 lm
CBT-90: ? -? - 2400 lm
CBT-140: ? -? - 3800 lm
SeoulSemiConductors
SSC-P7: 2008 - 4x 1.0x1.0 mm - 16mm2 - 251-1100 lm
Nichia
219: 70-512 lm
Hi
This may be a stupid question, but can someone refer me to the comparison between the various LEDs by luminous efficacy. I want to see which are more efficient ( provide most lumens per watt of power fed to them). I know i am oversimplifying it, but ultimately i’d like to figure out a rough comparison which lights (which emitters) will stay on longer fed by the same batteries, all other things being equal.
The tables on first page seem to show a lof of data to this extent at different currents but they don’t always list what the voltage is, so not sure how to get the watts. Can someone clarify or refer to a different source?
thanks!
Cloud
The efficiency of your lights is largely dependent on your driver’s efficiency. The efficiency per watt of the LED is less than half the story. Amc7135 drivers burn off the excess voltage and maintain constant current meaning that an S2+ with two different emitters (ex: a 3v xhp 50.2 and a 219b) will drain the battery at the same rate, but the 50.2 will be brighter.
If you’re using a constant current switching driver which converts the battery voltage to the LED voltage, efficiency will be much higher most of the time.
Yes! I too am very keen on finding a power efficiency chart for the most common modern emitters. Like for example: what’s the difference in power draw on the standardized flashlight, (same reflector and driver) between sfp40 and xhp50.2 emitting 1000, 1500, 2000 etc. lumen.
This would be very useful info to have if you want to find a sustainable lumen and a specific battery life for a specific “flashlight chassis”.
I have seen individual charts here, but no-one seems to have collected the data and made a comparison.
