Thanks for your contribution!
thanks , i saw led chip clear first
Nice shot Xiotis!!!
Thank you Relic38, it’s a nice light too!
I already opened a new ‘flashlight photography’ thread to post more flashlight photos
Awesome pictures, unfortunately I cant find any pictures of XRE and XPE side by side, they look the same to me, but there is some difference in size or?
You can see the difference here on brted’s wiki:
http://flashlightwiki.com/Cree
The ring around the XR-E is square while round on the XP-E.
I posted these in the flashlight photography thread, but I thought they are appropriate here as well.
Click on images for full size.
Alright, thanks!
So it looks like XR-E has huuuge metalic square around it while XP-E has nothing but the dome on top of it, nice, now I know that all my lights ar XP-E, because I cant see that giant square around LED in any of my lights :D!
Man, those make my sad pictures look stupid. I still think I can get it right with the right lighting.
mypicturessuckFoy
I think your pictures are more interesting. If you are going to do Macro... DO IT! The ones on CPF are clear but yours show "Life". A little better lighting and yours will lose the grain and be even more interesting. Nice! Thanks for sharing.
Dan.
I simply cannot believe you with your “only available light so they’re grainy” stuff, oh please man you’re surrounded by lights!!! Fire one up and shoot away! lol Seriously, I use a Triple Nichia 219 on med mode to get my macro’s
If you don’t like the “hot spot” pull a reflector and use it as a mule,
The one or two experiments I've tried to supplant available light with a flashlight looked horrible. It seems the only pictures that turn out are when there is abundant, indirect light. That was available in the kitchen of our last house from around noon to 6pm or so. Good light never happens in this stupid house but the short wall on the side "yard" is perfect most of the time, except with the sun at high noon.
I really need to master macro using flash.
learningcurveFoy
As this one was taken, low room light with a single Nichia 219 in a 2” keychain light running about 30 lumens. It’s also depicting a Nichia 219 in an OP reflector with Hi/Lo modes by VinhNguyen. I use a split 1 1/2” PVC pipe, drilled and tapped 1/4 x 20 to fit on a tripod. Mount that and use rubber bands to secure the light in the half-pipe so that I can direct the beam where I want it. Works beautifully. I now have a Triple Nichia 219 from EDC+ that is even better using the Med setting so that it can stay on for longer lengths of time without worry. Depending on how much depth-of-field I’m looking for, I might take 20 or more consecutive shots at 1:1 ratio .5mm apart.
This was taken with Canon’s 100mm Macro 2.8 L IS, 6 shots using a RRS macro rail to deepen the depth of field and stacked in CS5. Go ahead, left click on it then right click and select original in Flikr, see it at 100% from a 21MP full-frame sensor.
That's an awesome macro.
needsmopracticeFoy
learning
pilot -
Wow, wow and wow.
verycoolFoy
pilot -
Wow, wow and wow.
verycoolFoy
Holy Foy! Foy’s Back!
Hope you’ve been well. Welcome back!
PPtk
