Why exactly?
There’s always demand for throw, no matter how small the light is
The xml doesn’t even produce much more light unless you drive it over 2A.
I still think that the TIR lens with make or break this light depending what type it is.
Size? Well its just like a longer TF Mini 01 as I see it.
With that no one would ask is that a flashlight in your pocket…….
Sounds cool, but does it run hot?
And that will depend on what each individual wants from the light. It’s a very subjective thing, flood vs. throw.
For me, and EDC needs a balance, with a lean towards flood. This light with a 15 degree TIR might do the job, maybe a 25 degree.
Any specs on the TIR dimensions? Is it even accessible in case we want to experiment?
My bet is that it will be floody. So it will just be a larger TF Mini-01 with longer runtime. But if it has more throw than the TF Mini then I’m interested.
Must have.
Yesterday.
I gotta have this!
Nice light. Just don’t overprice it like you did the BTU Shocker…
Stainless steel twisty - not for me. My DQG lll AAA left my keyring about 2 weeks after starting service. Can’t use it single handed easily.
The body is aluminium, so that shouldn’t be a problem.
I’m guessing pricing will be around $50, but hoping it’s closer to $40.
Huh? Of course the XML produces more light than the XPG.
And I use my DQG AA single handed easily.
Woody:Stainless steel twisty - not for me. My DQG lll AAA left my keyring about 2 weeks after starting service. Can’t use it single handed easily.
The body is aluminium, so that shouldn’t be a problem. I’m guessing pricing will be around $50, but hoping it’s closer to $40.
I’m hoping for $30-$35 but I won’t argue with even less.
I’m with you JohnnyMac !
$$30-35 would be nice
$30 would be nice i’d love to have it as my edc
RedForest UK: Woody:Stainless steel twisty - not for me. My DQG lll AAA left my keyring about 2 weeks after starting service. Can’t use it single handed easily.
^ This! Eagletac D25LC2 Mini that kreisler mentioned can be had for well under $50 and it is a well known brand with warranty.
I like it, other than the clip its good for me, and the clips removable….
Truth be told though, however it comes, some of us are going to tailor it to ourselves anyway, that’s the beauty of budget lights. :bigsmile:
Tecmo:The xml doesn’t even produce much more light unless you drive it over 2A.
I think Tecmo was implying that an XP-G2 R5 produces similar, if not practically identical, amount of light to an XM-L U2, while producing a tighter, higher-lux beam that appears brighter than the same amount of light in the XM-L’s floodier beam.
the smaller emitter lends itself better to a small light than the XM-L. Sometimes I get carried away…
Woops, so it is - thought it was stainless in the blisteringly bright afternoon London sun. Alternatively, I could have read the specs. My bad.
