Does a Skyray king body screw onto the head of the Apex? If I remember to when I get home, I will see if the SRK body screws into the Terminator head. If so, you just need the Terminator and you are set for another killer bike light. Personally I think the floodiness of the Apex would make the best bike light.
Also, if the do all fit, then you just need to make one bike adapter that will work on all three lights and their derivitives (Fandyfire, Skyray, Solarstorm, Mimic, Rustu, Black Shadow, etc...).
You have to make different plate for every flashlight , you must be very lucky to fit the same plate to different flashlights.
I meant that you can use the same idea to every flashlight in the market and make it a bike light - sorry if my bad english confuse you
I read somewhere don’t expect magic among U2, U3 and XML2 U2. The higher the expectation, the higher the disappointment.
So I pulled trigger on my second Terminator. This one will be screwed into my current Terminator to make a 5000 lumens flashlight so that I don’t need to buy X6. She will be 8-LED running with 8*18650, sounds more efficient than Olight. My original plan is to get 5 Terminator to make a 20-LED to match 4sevens flashlight. Let’s see how things go with my 8-LED first.
Some people have “sickness”, I remember one guy amputated himself because he hated his legs for 40 years. He feels happy at the end.
I guess that owner hated Terminator handle so much.
Ya, I need something between them for proper fitting and not to scratch my Terminator so much.
Combine two will be easiest one. I can’t locate standard L shape or + shape adapters or screws to combine 3,4 or 5 Terminator. Might need to do custom build to combine more. Anyway, 5000 lumens will be really bright as my single Terminator already can light up everything in front of her.
The Terminator is being sold online by a local dealer in our country and I’m setting my sights on this beast. I can’t wait to get my hands on one. Thank you for this review.
I can tell you that Black Shadow engineers have a 1.5m Integrated Sphere that they test on. They test 3450 with a U2 version and over 3700 with the U3 version. It is very likely that IS are not linear in their outputs and that with my smaller IS (14") it is not as accurate with the extremely bright lights like this one. I read over 3200 lumens with my IS. My IS is not ANSI certified but is calibrated pretty dead on with lights under 2000 lumens and is exactly in agreement with Match's and E1320's OTF numbers for the same exact regulated light. The Terminator could very well be putting out the claimed number.
Another review on CPF did not test the U3 on an IS but they did do a lux reading and my U3 light returned the same exact number as his did. Build quality is exceptional and apparently consistent. I will say that people claim brightness to the eye is not linear. My SRK puts out around 2300 OTF lumens (IIRC) and I will tell you that the Terminator is not only brighter, it DOMINATES the SRK as you can see in my indoor photos. I really do not doubt the 3500 OTF lumens claimed by Black Shadow. Their numbers for the U3 were actually closer to 3800 in their tests.
I would love to calibrate my IS against a regulated and ANSI certified light that puts out 3000 OTF lumens or more. Once calibrated against that light I'd retest the Terminator and see what I get. I'm sure it would be higher than what I tested now. At the price the dealer mentioned is selling them I wouldn't walk, I'd RUN and grab one ASAP before the price changes. This light really is this good in my experience.
What lux reading do you get and at what distance? I’d like to compare it to mine.
I don’t think that the sphere size is an issue. I get the same values using the internal sensor and the external sensor (that sees 1/100 the light of the internal one) on my 16” sphere. Also, the numbers that I get with my 15,000 lumen light ( 15,000 Lumen Bridgelux C9000 Light Engine ) match Bridgelux’s published data quite well.
