wow, this is exactly (almost) what im looking for. Im currently EDC’ing a Xeno E03 XML with a 14500 which is 97mm x 22mm. It fits in my “little” jeans pockets with a knife. But Im looking for soemthing in 18650 which is the same size (or smaller) with brighter output. I would really love to see a version with:
turbo output (or something over 600 lumens)
Strobe (i know, people hate this strobe mode but I want it)
Would be nice to have it be a little thinner like the QuarkX, Xeno S3A, CityCat Yee-Lic, D25L2C, etc which are all 18650’s at or under 23mm width. But at 86mm Length I feel like I would be asking too much.
Tell me when this is finished so I can buy it instead of the PALight V60!
On high Ric wrote it draws 2A, this will likely give a bit over 500 lumens OTF. As the lens is a plastic TIR I think you can not run it too hot or it will melt/deform, and also I think in this light (like the other DQG's) the led is mounted on the driver board. So I think 2A is very respectable for this small light.
hmm, ok I do not own the DQG AA, just the AAA in which the led is indeed mounted on the driver board and the TIR is plastic, you just now made me less sure about my assumptions.
I do not know of any glass TIR's commonly fitted in flashlights. Anyway, I'm surprised there is a complete pill (led and driver separated) in the DQGAA, and in this new light -if you consider the length- if there is a complete pill it must be a very very short one.
Thanks for the link, nothing beats good pictures . I see the led is deep inside the pill, close to the driver board on the other side, and the TIR is reaching into the pill onto the led, all making the assembly as short as possible, nice!
d*mn, just tried to remove the led/driver board of my DQGIIIAAA to make a picture of the led sitting on the driver board (I removed it before, so no calamities expected) and while removing the foam insert a current regulator was ripped off the board with it (*##@!!!). Stopped there but now it won't switch to high anymore. Too tiny to solder back I'm afraid....
Result: no nice picture to show you, and no working flashlight *sigh*.
Yes, everything can be fixed. If you dont have a very small soldering iron, wrap some copper wire around the tip. It works! Its a hack job, but it really can save some hassle. Sorry for your potential loss though. :(
If its really dead, send an email to Ric. They sell the drivers alone if you ask.
You encouraged me to try it, but at this moment I can't get the board out of the head anymore . anyway, here's how the disaster looks:
On the left side of the board is where the part is ripped off, the part still sticking to the foam is seen bottom right next to the flashlight head. Now that I see the picture, it appears like the complete solder pads were ripped off with the part. It's beyond repair after all
Getting a bit off topic now, let's talk about happy stuff again, the 18500 DQG....
Replace star with 20mm triple XP-G2 R5 neutral 5000k and put appropiate optic on top.
Remove driver and replace with contact plates for direct drive.
Add QTC at head for brightness control.
Run on IMR 18650.
EDIT: hm. maybe this idea won’t work with this light. With the LEDs mounted on the driver board there wouldn’t be enough separation from the top of the batteries.
The mini 01 is about 6 cm long so there we have a nice pocket rocket.
But the great on this is the capacity of a 18650 which is about five times a 16340 or 14500
