To be kept in a lady's purse. Small & cute enough.
Just 7.5 cm !
Beam is brighter than the Powerlight I got from FocalP. Beam is slightly bluish, beam is just as good as Powerlight. Body seems thicker.
Lens better quality than the Powerlight, thought it was glass for a moment.
Preferring it to the Powerlight. Might get 3 more to give away, just $2.65 each.
Did not power on at first, dropped the head on a wooden table-top and it worked perfectly thereafter ! Users at DX say battery sometimes does not make proper contact, body/top is a bit too long, it is a twisty.
Quite happy, if I get about 5 - 6 hrs with a AAA alkaline.
Will try and find a forward clicky tomorrow.
btw : Rom RC-G2 (forward) clicky is available at a online store.
I found the good DeLight but seem to have lost a Preon 2. This is not a good rate of exchange.
It doesn't really get fully dark at this time of year - these shots were taken at about 10:45pm BST (UTC/GMT+1)
Control
BLF DeLight on an alkaline. Must do a comparison shot with the Powerlight. The tree is 50 feet away.
By meter, the shorty is brighter than either of the Powerlights (all on alkalines), but I couldn't fid the one used to take this shot when I was pointing them at a meter.
Thanks Don! Very nice shots! I am expecting my BLF DeLights tomorrow or early next week, I hope they work out well. That is a pretty nice looking bright beam for a $1.48 piece of aluminum.
Ah yes, you guys are really way North there aren't you?
North of Labrador and Moscow but the climate is heavily modified by being an island so it isn't nearly as harsh as could be expected. HAving the Gulf Stream run up the west coast helps a lot too. That said, where I was failing to take beamshots last week, I have personally seen -30C (-22F) and about 28C (82F) max (once, 30 years ago). People die of the heat here when it stays above 25C for any length of time.
The BLF DeLight is definitely brighter than the Powerlight, but is less well made, only one of the two of them is actually usable.
On the lightbox (All of them running cheap alkalines) An Eneloop here would cost about the same as 3 BLF DeLights
DeLight 1 (shorty)
83 lux
DeLight 2
169 lux
Powerlight 1
65 lux
Powerlight 2
72 lux
Will do some runtimes on all 4 of them soonish - they are likely to be very long.
Received my order of two BLF DeLights today from digitalzone88 (shipping to Los Angeles). Ordered on 4/28/10 and received 5/12/10. I'm liking them quite a bit. Pretty good brightness for the price. Quality is good and consistent between the two I ordered. There are scratches/specks/dirt on the lens but the beam/hotspot was still pretty clean. So far so good...looks like a good buy. May buy more!
This time, I'm going to use the same cell in all four of them - a well-used Duracell measuring 1.31V - I'm running low on alkalines though i nearly bought a 40 pack at the weekend. I don't approve of disposable batteries though so prefer not to use them. I'll do the same tests with an Eneloop as well. It measures as 1.37V. Also decided to dig out a new alkaline (1.53V) as it seems these lights are heavily voltage dependent - they'd be really good with lithium AAs though it does seem strange using a disposable cell that cost twice as much as the light. For the price I'd put the cheapest alkalines in it and toss the whole thing if the cell leaked.
DeLight 1 is the shorty - I now suspect that it is actually too thick a layer of hard plastic goop that serves as the switch retaining ring because it is exactly the same length as the good one.
The throw measurement is in lux at 1 metre, the output number is in lux
Throw
Throw
Throw
Output
Output
Output
Light
New Alkaline
Used Alkaline
NiMH
New Alkaline
Used Alkaline
NiMH
DeLight 1
1050
617
985
178
97
163
DeLight 2
1488
836
1457
196
114
180
Powerlight 1
328
185
288
92
61
80
Powerlight 2
310
167
239
98
59
77
Just for fun since Mr. Shorty - DeLight 1 - is not actually usable, let's see what happens with a 14500 in it. Nothing at all. Cell protection must have cur in or something as it still works. I was expecting smoke.
About to fire up the runtime box - the only one in the house that runs Windows in order to do some alkaline, NiMH and anything else I can think of that the meter can log. I've ordered a stock of batteries for the meter given that the 9V batteries only run for about 3 days continually before needing replacement.
I imagine the DeLight will not run for as long as the Powerlight though a switch mod involving a resistor to give a low mode ought to be an option. I have an otherwise useless DeLight to experiment on. The high (the level it normally is at) is useful enough, but if it is possible to add a low a fair bit lower than the Powerlight for eternal runtime, it would be really nice. Component cost would be a few cents (1/4 watt resistors are tiny and about 2 cents each retail) plus an hour or so of time to fit the components if I can figure out how to turn the stock switch into a two level one.
And how to dig out the hard plastic that holds the switch in place without killing the tailcap.
By the way, after a temporary hike in shipping costs (a scandalous $0.09 or 18.75% increase), they're back down again, and lower than ever. $0.47 if you live in the USA and $0.47 if you live anywhere else in the world. ;)
I think the marks are mostly pollen. Must cut the grass today. The DeLights got stuck in a bag with a lot of other lights when I was away. Do you think I took enough lights? I make it 68 of them there - the blue plastic thing lives there.
There were a few missing there. Pity I never got any beamshots as the sun would go down and it'd rain. Again.....
I don't think there were any marks on it when I got it. The finish isn't glossy, it is a sort of satin finish with a mild sheen.
Not a bad way to carry them especially since that is a lot. I thought you were going to build yourself a runway at first to help the local airport out, lol. Also nice to see a bunch of cells being taken as well, one can never have too many batts right.
Not normally - I keep a few charged and the rest at storage voltage so they need charging before use. I'm pretty sure I have enough cells to fuel all of them at once. Just.
Ok, I received my BLF DeLights, and they are, well, DeLightful for the price. They all work perfectly. Bright, bluish beam, slightly ugly around the edge of the aura. Rather ugly, blotchy finish and scratchy reflector. The threads feel fairly nice and are actually lubricated. The switch works well. They do not tailstand. I'll try to do a detailed review later. I'm quite happy with these.
Just joined this forum; I have been CPF member for almost a decade but it is not the same anymore. I have been browsing BLF for a while and now decided to take the plunge. Being avid DX'er (ha! ha!!), this is more suited for me.
I ordered 5 of the light from the ebay seller. i am shocked at what I got for under $1.50 I compared this with my first Luxeon light, LGI from Mr Bulk. It is 3AA and cost me $55 shipped few years ago. The light output of this $1.50 is almost comparable to my beloved LGI
