Test / Review: Sanyo UR18650FM 18650 2600mAh
31 posts / 0 new
JackCY
JackCY's picture
Last seen: 4 years 5 months ago
Battery: Sanyo UR18650FM 18650 2600mAh
Source: FastTech
Voltage on arrival: 3.77V
Protection: Yes
Button top: Yes
Claimed capacity: 2600mAh
Measured capacity: 2563mAh @ 1A / 2.9V
Internal resistance: 20mOhm
Calculated capacity: 2389mAh @ 900mA / 3.0V
FastTech
Used the battery a bit, charged it in ML-102 and discharged in my flashlight.
Finished my battery holder for a Turnigy Accucel 6 and tested the batteries.
18 mOhm / 2.95V / #1
22 mOhm / 4.12V / #1
20 mOhm / 3.86V / #2
Charged one battery on Turnigy Accucel 6, it trips the protection when charging, showed 4.12V with my DMM, but yes my charger even when set to Lion 4.1V does like to go even up to 4.25V to speed up the final charging and charges the unprotected batteries high.
No temperature raise during charging or discharging.
Discharge capacity at 1A from fully charged 4.12V down to Turnigy claimed 2.9V, once I took the battery off and measured it with DMM it had 3.5V or so. I’ve seen it at 2.95V with DMM once when my flashlight told me to change it, so there certainly is still some charge.
Discharge capacity at 1A:
2563mAh / #1
As expected a very good battery, will pull 2.8A on a 8*7135 driver but not for long, driver/LED heat up? Or battery can’t deliver the needed voltage?
Anyway it is a long battery with the protection and a button top, think 69.6mm. Does fit into an ML-102 charger with a little push in.
Came with a clear transport box, wrapped in bubble wrap and bubble envelope.
Will test the second cell after finishing Trustfire 26650 5000mAh.
It seems to have the claimed 2600mAh, when fully charged and fully discharged even at not so modest 1A.
Edited by: sb56637 on 08/26/2014 - 17:45
myst999
Last seen: 2 weeks 4 days ago
Great review – Thanks! Any idea of why these protected Sanyo’s at 2800mah (versus 2600mah) are actually cheaper? (.02cents lol)
http://www.fasttech.com/products/1420/10001901/1143804-sanyo-ur18650zt-1...
Okinos
Last seen: 5 years 10 months ago
Because sanyo 2800mAh, should be charged to 4,35V to have 2800mAh capacity. Battery protection allow only about 4,2V. So 2600mAh could have more mAh than 2800mAh.
JackCY
JackCY's picture
myst999 wrote:
Great review – Thanks! Any idea of why these protected Sanyo’s at 2800mah (versus 2600mah) are actually cheaper? (.02cents lol) http://www.fasttech.com/products/1420/10001901/1143804-sanyo-ur18650zt-1...
Search Sanyo UR18650ZT I believe, they are newer 4.3V cells, been asking similar questions before buying the 2600mAh, look around you will find it Smile
They are not bad but are 4.3V and won’t give you 2800mAh without going to 4.3V and maybe even then they might be slightly over rated.
I went with the older and proven UR18650FM.
JackCY
JackCY's picture
4.3V
UR18650ZTA is 4.35V @ 3000mAh.
myst999
Ahh! Thanks for the info guys – definitely going with the 2600mah then Smile
Okinos
yes, sure , I made a mistake. Thanks
Werner
Werner's picture
You can calibrate the voltage of the b6 charger, look at hobbyking manual.
JackCY
JackCY's picture
Cannot, covered it in another thread somewhere, I have a limited version that has Lixx internal resistance testing, can’t be calibrated by entering the startup configuration mode by holding buttons, I have tried all combinations before. Only option would be to modify the firmware or adjust the sensing resistors or something, none of my equipment is calibrated so it’s impossible anyway.
It also doesn’t have logging output, only temp. probe in the options.
jmpaul320
jmpaul320's picture
Last seen: 1 week 1 day ago
hmm – any more info on this? I have 4x of these which I ran in my firefoxes 3 in series which supposedly pulled 4a fine… the cells got warm but i didnt notice any sag?
I am running the same 4x in my skyray king now but i guess the currents much less because the 4 of them are in parallel.
I am curious now, I think I might throw mine on my hobby charger this weekend to see whats up lol.
thanks for the review!
Would you mind keeping the wrong flashlight?
Best wish, May
Tmart service team
Soumil wrote:
PLEASE HELP ME GEARBEsT! IM LITERALLY CRYING!
JackCY
JackCY's picture
Well I have only one flashlight, sure I could dig out some resistors and measure Amps with my DMM, I’m quite sure the battery can supply tons of Amps, at least if you look at discharge graphs in some other tests, they do test it at 5A.
I think it is the driver or emitter in my flashlight, it overheats quickly with so many Amps, heat rises, resistance increases, Amps go down.
Comparison graph, Sanyo FM, ZT, Panasonic A, B.
jmpaul320
jmpaul320's picture
I think it is the driver or emitter in my flashlight, it overheats quickly with so much Amps.
ah ok… thanks for the additional info
Best wish, May
Tmart service team
KristofB
Last seen: 6 years 4 months ago
Hi Jacky,
Did you measure that internal resistance using the new Turnigy Accucel 6 LiXX Internal Resistance feature?
How do you do that for a single cell? I tried, but it does not give me any value – seems that I need a balance lead as well? On your picture, it seems you are using a special balance lead (with only two wires) – could you elaborate on that?
nekdo12
Last seen: 5 years 8 months ago
Is there any difference between UR18650FM and UR18650F? (I do not find anything about FM, only about F on Sanyo/Panasonic site)
JackCY
JackCY's picture
KristofB wrote:
Hi Jacky,
Yes, I’m not sure how accurate it is, if you have a precise/calibrated DMM and a resistor of appropriate value you can measure it that way.
I use the Turnigy’s feature.
Yes you need to connect it to the balance port obviously Smile
That is how it works, charging port is for power, charge, discharge.
Balance port is for monitoring cells, measuring cells, balancing cells (low current).
Just connect the battery correctly to the balance port. From right: GND, cell1, cell2, …
JackCY
JackCY's picture
I’ve seen some crap on Panasonic site, never understand what is Sanyo doing there in descriptions of some batteries. Basic stuff there only no pics.
No F is not FM.
There is many batteries and many Fs:
Code stated mAh ring sleeve Volt
UR18650W2 1500 pink red 4.2
UR18650FJ 2200 red red 4.2
UR18650A 2250 violet / white red 4.2
UR18650FK 2400 green red 4.2
UR18650FM 2600 teal blue red 4.2
UR18650ZT 2800 violet orange 4.3
UR18650ZTA 3000 yellow violet 4.35
And many more!
The ring color denotes capacity.
The cover color probably indicates different voltage.
flash.light
flash.light's picture
Last seen: 6 years 8 months ago
Panasonic Buys Sanyo for Its Batteries as reported in December 2009
Noodles
Noodles's picture
Last seen: 1 year 1 month ago
Thanks, I was just looking at these and the 2800’s for practically the same price
Can you take a real life measurement of the Diameter? I know itt says 18.3mm but sometimes they are off.
The Giggle Loop
nekdo12
I know that Wink
But I do not know these:
JackCY
JackCY's picture
nekdo12 wrote:
I know that Wink
Yes.
Find the UR18650F, or rather get the specs from the source you’re buying them from, who knows what they are selling, they should inform the buyer.
If you already have them, just test them to find out capacity and so on.
JackCY
JackCY's picture
UR18650FM 18.5mm diameter over the protection connection strip, otherwise 18.35mm.
Why would you buy ZT? If you can charge it to 4.3V, why not, otherwise it might actually be worse than FM if charged only to 4.2V.
I could probably charge to 4.3V on my Turnigy in LiPo setting, maybe, maybe to even 4.35V, I know my LiPo had around 4.3V when finished. Would have to charge it again to find out.
Otherwise you are out of luck charging over 4.2V, need a rare charger for it.
sixty545
I have four pc of UR18650ZT, protected. I could not charge higher than 4.25v because the protection circuit switched off. Then the capacity was lower than for the FM version. Sad
JackCY
JackCY's picture
Yes, I forgot about the protection!
It kicks in on my FMs as well, they do stop at 4.15V?
My TF 26650s stop at 4.21V.
So yes, you need a protection designed for 4.3V cells, and so on.
I’m glad I really stick to the older FMs, see the ZT thread and probably go there to post questions about ZTs.
nekdo12
JackCY wrote:
nekdo12 wrote:
I know that Wink
Yes.
Ok I foud it.
UR18650FM=UR18650F, but not always Silly
You have UR18650F group. And in that group you have UR18650FM, UR18650FK, UR18650FJ,…
JackCY
JackCY's picture
Yes I found out yesterday, there is a thread about bigmicro selling UR18650F.
Panasonic website has only UR18650F pdf, did not notice any info there though in regard to different code names.
I think the lower the second letter the older the type of cell and potentially lower capacity. FJ 2400, FK 2500, FM 2600, my guess.
nekdo12
FM= 2600mAh
FK= 2400mAh
FJ= 2200mAh
JackCY
JackCY's picture
nekdo12 wrote:
FM= 2600mAh
FK= 2400mAh
FJ= 2200mAh
Lol I’m dumb, see I forget, I even have it in the table up there few posts up XD
ri chevy
Last seen: 1 month 1 week ago
I realize that these batteries can put out a lot of power, but if using a drop in that only draws 1.5A, will these batteries be OK? Specifically a Malkoff M61 drop in. Are these Malkoff drop ins regulated for input voltage or amperage?
This is weird. I posted this on 2-3-2013 and is shows listed after 2-26-2013. ?????????????????? Now it doesn’t, but I have the screenshot. Edited on 2-27-2013
scaru
scaru's picture
Last seen: 2 years 11 months ago
ri chevy wrote:
I realize that these batteries can put out a lot of power, but if using a drop in that only draws 1.5A, will these batteries be OK? Specifically a Malkoff M61 drop in. Are these Malkoff drop ins regulated for input voltage or amperage? This is weird. I posted this on 2-3-2013 and is shows listed after 2-26-2013. ?????????????????? Now it doesn't, but I have the screenshot. Edited on 2-27-2013
Yep, these batteries will work just fine. Smile
ri chevy
Thank you.
sb56637
sb56637's picture
Last seen: 2 hours 16 min ago
Thanks very much for the review! Frontpage’d and Sticky’d.
