Looks like another very interesting OL build.
Just making sure you know you need to hold the power button down for two seconds to turn the stock rook on.
I had to search before I figured it out too.
Oops! Too late now, though I expect anyone sending him a light knows what’s in store for it.
It's DONE. See all the photos in the OP.
Have fun and look for the giveaway now.
Nothing has changed. More confused than ever. To top it off the thing (for want off a better word) works like a charm. Back to the Bex and another Nanna nap for me. Well done.
Congratulation for this impressive and useful mod, O-L, i really enjoyed the whole (photo) process!!!
Great mod, Justin! Just wondering : if the stock voltage input was 1.5~4.2V for 3xAA in parallel, then won’t 3xAA in series be 4.5v?
Each
Nanjg drivers will work at 4.5v if need be, just alkaleaks won’t last too long I guess. Nice work o-l I like this a lot.
Beautiful work and a fairly simple solution to lockout parasitic drain. You da man!
+1
Nice mod, I dont know how I missed this one.
I added a video explaining Parallel to Series on this Rook mod. It's laughable, but maybe it will be useful to someone out there.
EDIT: "The Driver Contact Plate"
I stripped all components from that driver plate, so it was a bare contact plate. Since the plate is bare now, I can use a meter and see where the one area is, that makes the contact, from one side of the plate to the other side. I just metered the plate and there was one location, where it went through to the other side. Then I cut the plate, so that area was the positive contact.
Thanks Mr Lumens. I'm probably speaking for .1% off people on this forum. I think that just leaves me? I know about parallel and series no problem. Its just the way you went about making it work. If a pictures worth a thousand words your video is worth 10,000 words. From all the .1%off people here, thanks for going to the effort off explaining it further.
Are you giving away another?
Nope, I am selling the second one. It will be polished (well shiny anyhow), aluminum, instead of gold.
I imagine there’s more than .1%, but they just don’t say anything. “The Silent Majority”.
Great mod OL your a creature of lumens
Olds, I loved that revision in series and parallel batteries. Esp that part when a cig popped in and out quickly! Me not smarter than a 5th grader in this. Just to be sure, its 6v total for a double stack of 3xCR123s in an M6…yes?
What’s the voltage of one? Multiply by 2. 3.6 volt is “nominal spec” for any Li-ion, I believe, so 7.2 volt for two in series.
