Technically it is but you would lose the ability to turn off and on or change modes. Only an issue if that’s important to you.
I really much prefer the handle being on it. Really easy to carry and easy to put in/out of a holster with it, too. If you need to warm your hands you can always hold it by the body like a normal light and work the switch with your index finger.
You could always swap out the green LED for a white one. It was not designed by BS to be an actual firefly mode. It was intended to be a battery indicator. Green is good, red is bad. I simply noticed one night while it was on my nightstand that I could see the entire room quite easily by the glow of it and fond it to be a rather brilliant unintended feature of the light. I prefer the green as well because it doesn’t mess with your night vision. Also easier on the eyes while trying to sleep while a white light would really annoy and distract me.
i am reading reviews of this light and i am having a hard time……
a hard time not buying one….
i almost bought a u2 version when it came out… i had it in my cart on going gear with the blf coupon for $135 and was about to hit the paypal button when i decided to not be impulsive and wait for reviews…. not its a few months later… i know a xml2 version is in fact not coming per the blackshadow rep i messaged last month… so the u3 is the best of the best
Great review and pictures, JohnnyMac! I only have one question, how hard would it be to replace the emitters with XM-L2 or U3? I can’t see it very clearly in the photos. I’m planning to get the BlackShadow Terminator, but I want to replace the emitters with XM-L2 or U3 later on. Thanks!
It wouldn't be hard at all. The individual reflector "barrels" unscrew to expose the emitters. They only have thermal grease, not paste, so they come out easily. Each LED has its own plug to the driver. Just unplug and remove the led and wire, unsolder the write from the old led, solder wiring to new led, feed the wiring back in and plug into the drive. Dab some gear onto boron of the new star, position it, then thread reflector barrel back on.
Is it really that simple? No need to switch drivers and all? I’ve never done any Flashlight modding so I’m a bit reluctant to try this till I’m sure on the steps.
What materials do I need to make this all happen? My terminators are due to arrive next week and I want to mod them to sport the latest U3 bin leds. My soldering skills are pretty decent, do I need a soldering station?
Thank you for your reply, JohnnyMac! That sounds great! Still thinking if I should replace the whole MCPCB or reflow new emitters to the existing MCPCB. I prefer to change the whole thing, because then I will have 2 sets Could you kindly check what size the MCPCB is, if it isn’t too much trouble and if you have time? Thanks a lot!
Great review. Now I want to get one but this is gonna be about three times more expensive than any of the other lights I own. I’ve been debating whether or not it’s worth paying so much for a flashlight. Also,does this warrant paying double the cost of the Darth, since I’ve been eyeing that for quite some time now as well. I really need some help deciding. :~
