Gentlemen,
(Foy inspired quick summary: I made my own I.S. using a $2 big rubber ball, paper mache, and a luxmeter)
When I was into building disturbingly fast street cars, one tool that I always wanted was my own personal dynometer so I could accurately test/tune the fruits of my labor. Seeing as how they cost over $15k and would take up the entire garage, I was stuck either finding a local shop with one or testing at the local drag track.
For reasons I can't fully explain (or completely understand), six months ago I found myself drawn into the flashlight world. I would have never guessed messing with lights would be so much fun! Yet, once again, I found myself in need of an accurate testing device...and for this hobby an Integrating Sphere (I.S.) replaces the dyno. It serves the same function, but instead of reporting horsepower/torque it gives me lovely lovely lumen ratings. Seeing as how there are no "hobbyist" IS's for sale, I was in a quandary as to what to do. Thanks to some of the wonderfully inventive folks on this forum, I saw how one could be built fairly easily. Being a traditionalist and an accuracy junky, I wanted to stick with the sphere instead of a box. I've read where others have used large styrofoam balls, but the price for one (after shipping) was close to $100. So, I decided to make my own from scratch - which is more fun anyways!
While perusing the aisles of my local Walmart, I saw the perfect "host" for this project. A $2 big rubber ball in which I was going to entomb in paper mache to create my sphere.
I actually ended up buying two of them, just so my young children could play with one while I destroyed the other.
First step was to wrap the ball in plastic so the forthcoming paper mache doesn't stick to it. I used an old plastic picnic tablecloth cut into strips, but thinking back any type of food grade plastic wrap would work. Once the ball is covered, it's simply a matter of layering thin strips of newspaper over it. I tried a few differerent adhesives on this project. The first was a leftover can of wallpaper glue, which seemed to work fairly well, but then finally settled on a 50/50 mix of white glue and water.
Here's the ball in the beginning stage after the plastic is on and the first layer of newspaper is going on. I honestly lost count on how many layers of paper mache I ended up using, but want to say it was around two dozen. The test I would do to determine if it needed more was once it was dry I would give it a squeeze. If I could still feel the rubber ball underneath, I put more layers on. Eventually it felt solid (just don't push too hard), and ended up looking like this:
The moment of truth comes when taking that first cut into it with a razor knife. Carefully cut across the equator to create two equal halves. Then, remove the remnants of the rubber ball and plastic wrap. If all goes well, it should end up like this:
Next, paint the inside of both halves with a white matte paint. Mine took a couple of coats to cover up the type on the paper. Once the paint dries, the two ports need to be cut into one of the halves. One is for the luxmeter, and the other is the entrance for the flashlights. These should be at a 90 degree angle from each other. The only other addition required on the inside is a baffle. From researching, this should be as small as possible but still cast a shadow over the sensor port when a light is shown into the input port. This prevents any light from directly hitting the luxmeter. Here's how mine turned out:
Once this step has been completed, the sphere needs to be reassembled. I used duct tape (or as I've been calling it, "Don's Tape") to hold the two halves in place while I re-applied paper mache to the outside. It only took a few more layers around the cut to firm everything back up. Once back together and dry I decided to shoot it with a quick coat of spraypaint to make it look more complete. And here it is:
At this point, the only thing left to do is plug in a luxmeter in it's port and determine what the sphere's correction factor should be. There's a lot of different ways to do this, but the most accurate one I tried was to simply take a light of known value, test it to get the lux reading, and then divide that reading by it's alleged lumen rating. For example, I have two lights that have been tested a lot by others. The zebralight SC60 (300L otf) and the H51 (200L otf). I came up with a value of 12.65, which, when tested shows the H51 at 200L and the SC60 at 300.4L. I also tested various other lights and the values returned seemed quite plausable. One thing I found helps is using cardstock with a perfectly sized hole cut into it for the head of the torch. I've got a bunch of these now of various sizes. Here's me testing my L2P:
And a couple shots of the luxmeter and how it looks attached to the I.S. It is a tight press fit, so no other retention is needed to hold it in place.
Summary:
I'm very happy with the results of this and now having my very own 14.5" I.S. Unlike the other flashlight projects I've done, I was able to get the kids involved with this one. Gave them a tray of glue/water mix, some newspaper, and let them have at it! Thankfully my 7yr old is as anal as I am, so it all turned out well. The project was pretty simple and went fast. The longest part was waiting between paper mache layers for the glue to dry. Total cost for creation was @ $5 in change, for the ball and a couple bottles of white glue (assuming one already has a luxmeter, if not add ~$20). The best part is the repeatability. I can take any torch I've previously measured and using a battery of the same charge level get results within a tenth of a percent.
Here's a few reasons why it's a handy device to have:
- Accurately test recently purchased lights and ensure proper performance
- Test outputs of a torch on various battery combinations
- Compare before and after results after modification
- Determine how various reflector/lens combos affect total light output (It's hard to subjectively compare the light output of a flooder vs a thrower by using the naked eye)
- Troubleshoot a bad driver or emitter
- Give lumen ratings on new flashlight creations!
Some test results can be found here. Thank you all for reading and humoring my flashaholic DIY sickness.
Definitely needs to be stickied. I didn't know a luxmeter could be had for so cheap.
Is it important that no outside light (other than from the light being tested) enter the sphere? What if I get the baffle size wrong, is that a big deal?
thanksFoy
No referral links and nothing embedded . . . ever.
Yes, the only light entering the sphere should be from the torch being tested, which is why I used stiff white cardstock with tight fitting hole that matches the head to cover the the sphere entrance.
Baffle size was trial and error for me. What I did was use a torch shining into the input port of the sphere and tried various sized baffles until I found the smallest one that would cast a perfect shadow over the luxmeter sensor. Then I confirmed it by using other torches with various beam patterns. I made good use of a FTT here.
Hey, nice work! If you can still open that up, take a look at
http://www.candlepowerforums.com/vb/showthread.php?312940-Improving-the-DIY-integrating-sphere
A very good coating, for just 6 bucks apparently. Problem is you have to paint first, then dust powder on.
awesomethanksFoy
Need to make one of these from a nice globe
Did you say ...6000 lumens ?? diggety ...
> You forgot one more reason .. to impress your BLF buddies ... Very cool
You are a good Dad ...Now go out there and give that lil girl a set of new streamers for her bike and 2000lumen bike light that will make the neighbor kids cry .
Dc-fix diffuser film >… http://budgetlightforum.com/node/42208
WOW .
Simply outstanding job as usual , Match .
My Paracord Stuff
Very nice work as usual.
That's awesome Match!
Now I just have to convince my self that I need a luxmeter more than I need an other torch
Nice tutorial! Superb approach with the ball and newspaper. I'm still fiddling with fish transport stryofoam boxes... that reeks... :/
They're gonna send you a green redcat with a black LED.
Match
Let a flooder be my wife and a thrower be my mistress
Barium Meals.. mmmm... Wonder if I can get the stuff from radiology departments?
THats one HAWT sphere! seriously, I love it ! I should make one and calibrate it against a 120P before I emitter mod it.
"like everyone else - I’m looking for my next “last” flashlight" - ohnonothimagain
Great work as usual !
I thought about a plastic ball but the papier mache solution is way better.
Measuring things is the only way to develop this stuff otherwise wrong conclusions are commons. Many people think that the difference between say, 250L and 300L is huge but actually is barely noticeable even side by side.
Brilliant idea match! That took more than a little creativity and artistic resources to produce. I'm seriously impressed how well it turned out. Your typical style transformation of common-->exquisite. Thanks for the clear write-up!
Frontpage'd and Sticky'd, I re-added one of your pics for the teaser pic, hope you don't mind.
It seems that your experiences with working with paper mache as a child were put to great use! Thanks for sharing! Is the size of the sphere going to be sufficient in preventing your light meter from maxing out with higher powered LED's (XM-L - SST90)?
Ban all Klarus flashlights! >>>>> https://www.reddit.com/r/flashlight/comments/a0n88o/klarus_with_a_strong...
Review: 150 Million Candlepower Military Xenon Arc Battlefield Illuminator (AN/VSS-3A)
My new collection of 50+ Chinese knives
Seems so since he already got a lumen reading of 5000+ form his fireball wand. A good driven SST90 does not make half of those lumens ideally.
Nice easy to follow write up. Great Job! Is there any differences to using a bigger sphere like an exercise ball(more distance between light and meter). different readings?
03/04/16
8 lives left
Essentially the maximum reading of the meter will "go farther" in a larger sphere. The bigger the sphere, the higher the lumens you can measure.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
Very well done, match!
You might want to study this article that I mensioned in my own IS review.
What I mean is that if the sensor can "see" the "first strike" (that is the hot spot on the wall opposite the light input) then you will get problems measuring a "thrower" light against a "flooder". If you still have the plastic dome on the luxmeter then it will be sensitive to that "first strike" and the thrower light will give a number that is too high.
The remedy is to make the sensor less sensitive to "sideways" light by removing the dome and/or make a baffle hide the hotspot.
Keep up the good work
Love it! I'm going to call it "my tape" from now on....
If it moves and it shouldn't use duct tape on it.
If it doesn't move and it should, spray WD40 on it!
I've actually seen a guy trying to fix a puncture on a motorcycle tyre with duct tape. It wasn't a good idea......
But do you know why the stuff is like the Force?
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
Thanks for the nice comments guys. I was worried my "art class meets BLF" may have been too far off the mark
No, I think it's right in the center of interest. Great job!
Iwanttohaveone
Really a great job. I think i will try to imitate your IS, "Guru" Match!
"There are always new jobs, women, and apartments......there is only ONE BLF." - Chicago X (27/03/2012)
Pray, tell!
It has a light side and dark side, and holds the universe together? Makes sense
Btw Match, what do you do in life? It seems craftsmanship "force" is really strong in you...
After a failed career as a shepard, I joined the US military to work on nuclear reactors (and also picked up the nickname-Match). After six years of being a zoomie sponge, I found myself working as a project manager for a large chemical/gas company. These days I do automation engineering for a steel company...but with the added perk of getting to play "hands on" out in the shop in the dirt and grime (never going back to a cubicle). The paychecks are handy, but what keeps me coming back are the fireballs and explosions (ever see a 150MW DC arc furnace? It's a lovely lovely creature...)
(actually I only dreamed of being a shepard...I'm not what you'd call a "people person").
Piers said " ....but who wants enough light, when you have the option for far too much "
Yes. A sphere means the light is spread evenly across the inside. So unless the ball is tiny or it's a massively bright light, it's more than enough.
Reading this makes you smarter: http://lesswrong.com/
