Very nice work as usual.
That's awesome Match!
Now I just have to convince my self that I need a luxmeter more than I need an other torch :P
Nice tutorial! Superb approach with the ball and newspaper. I'm still fiddling with fish transport stryofoam boxes... that reeks... :/
Trying to get one just like this one. :)
Match
Barium Meals.. mmmm... Wonder if I can get the stuff from radiology departments?
THats one HAWT sphere! seriously, I love it ! I should make one and calibrate it against a 120P before I emitter mod it.
Great work as usual !
I thought about a plastic ball but the papier mache solution is way better.
Measuring things is the only way to develop this stuff otherwise wrong conclusions are commons. Many people think that the difference between say, 250L and 300L is huge but actually is barely noticeable even side by side.
Brilliant idea match! That took more than a little creativity and artistic resources to produce. I'm seriously impressed how well it turned out. Your typical style transformation of common-->exquisite. Thanks for the clear write-up!
Frontpage'd and Sticky'd, I re-added one of your pics for the teaser pic, hope you don't mind. :)
It seems that your experiences with working with paper mache as a child were put to great use! Thanks for sharing! Is the size of the sphere going to be sufficient in preventing your light meter from maxing out with higher powered LED's (XM-L - SST90)?
Seems so since he already got a lumen reading of 5000+ form his fireball wand. A good driven SST90 does not make half of those lumens ideally.
Nice easy to follow write up. Great Job! Is there any differences to using a bigger sphere like an exercise ball(more distance between light and meter). different readings?
Essentially the maximum reading of the meter will "go farther" in a larger sphere. The bigger the sphere, the higher the lumens you can measure.
Very well done, match!
You might want to study this article that I mensioned in my own IS review.
What I mean is that if the sensor can "see" the "first strike" (that is the hot spot on the wall opposite the light input) then you will get problems measuring a "thrower" light against a "flooder". If you still have the plastic dome on the luxmeter then it will be sensitive to that "first strike" and the thrower light will give a number that is too high.
The remedy is to make the sensor less sensitive to "sideways" light by removing the dome and/or make a baffle hide the hotspot.
Keep up the good work
Love it! I'm going to call it "my tape" from now on....
If it moves and it shouldn't use duct tape on it.
If it doesn't move and it should, spray WD40 on it!
I've actually seen a guy trying to fix a puncture on a motorcycle tyre with duct tape. It wasn't a good idea......
But do you know why the stuff is like the Force?
Thanks for the nice comments guys. I was worried my "art class meets BLF" may have been too far off the mark !
No, I think it's right in the center of interest. Great job!
Iwanttohaveone
Really a great job. I think i will try to imitate your IS, "Guru" Match!
Pray, tell!
[quote=Don]
[/quote]
It has a light side and dark side, and holds the universe together? Makes sense
Btw Match, what do you do in life? It seems craftsmanship "force" is really strong in you...
