1. Nightwatch NS59 v2 9x SFQ 60.3
2. Astrolux MF01 18x Nichia 219c
3. Astrolux S42 Nichia 219
4. Astrolux S42 XPG2 CW
5. Astrolux Copper X5
6. BLF Sofirn LT1
7. BLF Q8
8. BLF Q8
9. BLF GT
10. BLF GT 70.2 3000K
11. BLF GT mini CW
12. BLF GT mini NW
13. BLF Chronos X5/X6 Boxed Set
14. Convoy C8 mod Mtn Ele XinTD 5+A XM-L2 U3 dedomed
15. Convoy S2 Nichia UV
16. Emisar D18 18x SST-20 3000K
17. Emisar D18 18x Oslon Reds
18. Emisar K9.3 9x E21A 2000K 3x SST20 6500 WW Switch
19. Emisar K1 SBT 90.2 5700
20. Emisar KR1 All Cu W2 6500K
21. Emisar K1 W1 CW
22. Emisar K1 W1 Green
23. Emisar D1S
24. Emisar D1S modified with W1
25. Emisar D4 V2 WW 4x SST-20 3000K RGB aux
26. Emisar D4 V2 CW 4x SST-20 6500K RGB aux
27. Emisar D4 S NW 4x XPL HD 5000k Red aux
28. Emisar D4 S NW 4x XPL HI 4000K Cyan aux
29. Emisar D4 S NE 4x XPL Hi 5000K Green aux
30. Emisar D4 S WW 4x SST-20 3000K Amber aux
31. Emisar D4Sv2 CW 4x SST20 6500 multi aux Cyan host
32. Elektrolumens FireSword IV
33. Elektrolumens Big Bruiser Tri DeDomed 90CRI XM-L2s
34. Elektrolumens Big Bruiser Tri XM-L2 CW
35. Fire Foxes FF5 100W HID
36. Fire Foxes FF5 100W HID
37. Fire Foxes FF4 60W HID
38. Fire Foxes FF3 40 W HID
39. Fenix HL55 NW headlamp
40. Fenix LR35R
41. Fenix Tk16 V2
42. FireFlies E07 7x XPL HI 4000K Purple aux
43. Haikelite MT09R NW 3x 70.2
44. Haikelite SC04 4x SST-20 4000K
45. Jetbeam RRT-M1X Raptor LEP
46. Jetbeam M2S Raptor LEP
47. Lambda VL Hydra 4XM-L 4D
48. Lambda VP Hydra 3XM-L CW
49. Lambda VP Hydra 3XM-L NW Optics
50. Lambda VPT Prototype 5700
51. Lambda VPT 3 SMO SBT-90 MB
52. Lambda VPT 2 4D 6500 SBT-70
53. Lambda VP2000 6500
54. Lambda VP2000 6500 DeDomed
55. Lambda VPT 4500
56. Lambda VPT3 4500 DeDomed LOP
57. Lambda VP1000 DeDomed SST50 Custom Host
58. Lambda VPT2 XM-L
59. Lambda VPXM-L 3c
60. Lambda VPXM-L 3c
61. Lambda 2D XM-L
62. Lambda 2D XM-L
63. Lambda VPT2 XPG2 Dedomed
64. Lambda XML 2c
65. Lambda XML 2c
66. Lambda Keyring Locators (many)
67. Lumintop CL2 (lantern)
68. Macs SST50 Drop in 4500 4DMag
69. Mag*64656* 275W 24V bulb powered by 7 26650 IMR cells (No.2 on most powerful Mag mods)
70. Maglite MagCharger
71. Manker T01
72. Neosekian Legion II SST50vn 4.6A modded w/ WWI XM-L2
72. Neosekian Legion II MCEvn modded to 4.5A WW XM-L2
73. NiteCore Tube
74. Noctigon M43 Stone White 12x Nichia 219c
75. Noctigon M43 Sand 12x Nichia 219c
76. OMG DEFT with XPE2l and pre collimator OMG upgrade
77. OMG DEFT with R2 pill
78. ThruNite TN42 NW
79. ThruNite TN40S NW
80. ThruNite TN40S CW
81. ThruNite TN32 CW
82. ThruNite Cat 6 NW
83. ThruNite Cat Mini
84. ThruNite TH-20 NW
85. ThruNite Archer 2a v3
86. ThruNite Ti NW
87. ThruNite Ti3 V2 NW
88. Solarforce L900 SST P7
89. Supbeam K40VN
90. Tiabo A10
91. Vesture of Blood HiCri 3c XML2
92. XANES KT XP-G3+UV 350LM 3Modes Rechargeable Mini LED Keychain Flashlight
93. Xeno E03 WW
94. Xeno E03 WW
95. Xeno E03 NW
96. Xstar D31 Howitzer
97. Mateminco FT01 SFQ 43
98. Mateminco FT02 SFH 55.2
99. Malkoff XPG2 Maglite drop in
100. Kel-lite 7D
101. Maxtoch L2k LEP
102. Noctigon KR1 W1 red
103. Noctigon DM11 W2 blue
104. Nightwatch NS59v2 9xSFQ60.3
105. JETBeam RRT2 Raptor SST70
106. NOCTIGON K9.3 9 EZ21A 2000K 3 SST20 6500K
107. NOCTIGON KR1 Cu W2 6500k
108. DM11 W2 Blue
109. KR1 W1 Red
110. NOCTIGON DT8 8 W2 6500K
111. NOCTIGON DM1.12 1 SFT40 6500 12 SST40 4000K
112. DM1.12 1SFT40 5000K 12 SST40 2700K
113. DM1.12 1SFT40 3000K 12 519A 5700K DD
114. Wurkkos Headlamp XHP50.3HI 5700-6000K+ LH351D 5000K 90CRI+ LATTICEPOWER XG 660nm
115. Wurkkos Headlamp XHP50.3HI 5700-6000K+ LH351D 5000K 90CRI+ LATTICEPOWER XG 660nm
116. NLightD T90 SBT90.2 6500K
Some of what goes into Varapower Lights, Copper works wonders
This is a comparison of this light (camo VPT3 SBT90 MB VS a top binned and dedommed , old P bin (now called N bin) VP2000 both direct Cu mount
The light on the Left is the VP2000 and still is around 1800 Lumens OTF— Oh my what a difference a few bins and reflector will due. Both are 6500k, but dedoming lowers the appearant Kelvin temperature
Mag LED VPT2 XP-G2 OSTS modded TN31 and VPT2 XM-L
The modded TN31 was sold because the VPT2 XP-G2 modified with DEFT Lens and CF bezel like picture below was much much better thrower. I am one the few not a big fan of the body of the TN31. I think it’s way too big in the hand because of the battery carrier and switching mechanism (LegionII style carrier-less, for example, and the teflon bushings and light spring return switch are significantly more ergonomic)
VPT SST90 5700K Prototype with OMG Lumens DEFT Carbon Fiber bezel and Aspheric
I would not recommend the Aspheric VPT in SST90, SBT90, or XM-L, only in XP-G2. Because the others are too large of a die. I know the SBT90 version has been tested to be over 360K lux, but the XP-G2 version is so much better that it’s not even funny. The VPT2 XP-G2 with reflector alone throws about the same as an unmodified DEFT.
There are 2 of these DEFTs, they look the same, the one has an a R2, this one with the 5A. The other has been upgraded by OMG to XPE2 LR
OMG Deft X-RE and upgraded OMG Deft X-PE2 DeDomed LR
**Fire Foxes FF3,FF4— 4,000 and 7,000 Lumens of Incan like light in a light that is easily the brightest for it’s size. 225K and 428K Lux
Lamdalights Keylight Locator, still running well remaining on only a few Months(runtime with some of my other units has been well over a yr)! with dedomed SST90 4500K VPT3
