Your direct drive current is going to depend a lot on the resistance of the circuit and the health of the cell you are using. I had (notice I say "had") a cheap blue Ultrafire 18650 and it could only provide low current levels, even in direct drive. I also have a number of Sanyo laptop-salvage cells that can provide 4+ amps when freshly charged in the same light. Other factors that can affect the tailcap current readings are emitter lead sizes and dirty threads on the light.
Does this driver have visible PWM on low? If not, this would be an awesome driver for an XR-E/Aspheric light...
I will check for the PWM. What is the best way to check? Also I have made sure all threads are clean and the cells are new (they’ve only done about 10 cycles) Both Trustfires and Sanyo’s. It’s a good little driver.
Yes there is, but it is not as bad as my Solarforce XPG, the droplets appear much smaller with the XPG drop in, so you can make your own mind up there I’m afraid.
By the way I recharged my Sanyo as it was reading 4.16v. I took it off at 4.22v and it now pulls 3.1A. Not a lot of difference but I thought I would mention it.
I think I'll drop a couple of these on my next order for testing then. Sounds like it might make a good driver for a C8-type light since it's a fairly high Low mode but can be bumped up to Turbo if needed.
Yes, The way I see it I do not want a C8 with a 200ma low. What’s the point? So 1A and 3A is perfect to me. By the way it is not last mode memory, it always comes on high. So even better!
i changed to this driver on my cheap, underdriven xr-e c8. couldn’t stand the next mode memory, and it was very boring when it was underdriven. now it’s much more useful when it’s only 2-mode!
Used one of these in a build I like the direct drive part and then have another mode if you want it. No strobe no blinkies just good ole lumens in different doses…………. Mine pulled 1.3a on a green xre with long thin wires (was trying to be conservative) will shorten them and see if it pumps up the power.
I have played around and this little beast pushes 5A through my testleds…
I have powered it with a power supply so no voltage sag…but it got hot and smelled a bit warm.
