Yes, but isn’t Match is sinking copper to big chunk ’o copper? Results would be less spectacular if the copper sinkpad was sinking to a chunk ’o aluminium like in most flashlight bodies.
Thanks for the valuable information Match.
I guess amc7135 drivers are out at high currents. The battery wouldn’t be able to stay above vf of the led and the .12v overhead for the amc7135’s, at least not for very long anyways.
Thanks match, been waiting for a test on these.
Would the higher vf on these be accounting for the 2.25a draw using a 3.5a driver? Or is there something else coming in to play here?
Thanks again, your tests are invaluable to us here
Are you using a single cell driver?
And if so, what battery are using?
Update: Pulsar I found your thread with the mag, I’ll take the discussion there.
Sweet mother of pearl. As always—a big “thank you” for the data, match! I’m looking forward to how the XP-E2 fares. Will it have a higher Vf than its predecessor, like the XM-L sequel? Or will it be notably lower like XP-G2 vs. G1?
I know. It looks like high currents will call for 4xNiMH in a Mag. All the better for heatsinking, at least.
On the upside, the XM-L2 hovers around 62 lumens/watt at nearly thirty watts, >1.5A/mm^2, and delivers >400 lumens/mm^2. That’s crazy!
Pretty Awesome that you can see the increase in Vf (roughly 0.15V at 3.0A) with the emitter on the Copper vs the emitter on the Aluminum. This is almost certainly attributed to the lower operating temperature of the emitter on the copper. Some of the difference, however, is likely just emitter to emitter variation. I’d love to see what the difference in the Vf to Current curve would look like for the same emitter soldered to an Al vs. Cu star.
You should, in fact, be able to work backward and figure out what the actual die temperature difference is between Al and Cu. It’s easy to calculate - 1.6mV difference per degree C.
This is how I would rate the upgrade by looking at your graph.
Up to 1,5amp, no difference
1,5-2,5 minimal difference
2,5-3,0 some difference, about 10% at 3A - or 100 lumen gained compared to aluminium.
3,0-4,0 defiantly some gains. Especially when getting close to 4A. About 200 lumen gained compared to aluminium star @4A. Or 15% increase.
4-6, huge gains
1500+ lumens @ 5A. NICE!
But, gains are mostly when having high vf.
Can someone explain to me how real life gains would be when using a 4-5 amp driver and only 1 li-ion like a Panasonic NCR18650B Protected in combination with a linear driver… Would there actually be any gains at all?
Using one protected 18650 in combination with a boost driver, would there be any issues?
If using only one battery, I am assuming larger , low resistance, no protection would be helpful. But pushing 5A for some time would not be realistic even with one “high ouput” 26650, or??
And even if it does make that suggested current it would not stay there very long maybe a couple of minutes at best. A IMR cell would probably stand the best chance at it. Possibly 8 to 10 min judging by HKJ’s IMR graph.
