LED close-ups.
I posted these in the flashlight photography thread, but I thought they are appropriate here as well.
Click on images for full size.
XM-L:
XM-L profile:
Alright, thanks!
So it looks like XR-E has huuuge metalic square around it while XP-E has nothing but the dome on top of it, nice, now I know that all my lights ar XP-E, because I cant see that giant square around LED in any of my lights :D!
I think your pictures are more interesting. If you are going to do Macro... DO IT! The ones on CPF are clear but yours show "Life". A little better lighting and yours will lose the grain and be even more interesting. Nice! Thanks for sharing.
Dan.
I simply cannot believe you with your “only available light so they’re grainy” stuff, oh please man you’re surrounded by lights!!! Fire one up and shoot away! lol Seriously, I use a Triple Nichia 219 on med mode to get my macro’s
If you don’t like the “hot spot” pull a reflector and use it as a mule, :wink:
The one or two experiments I've tried to supplant available light with a flashlight looked horrible. It seems the only pictures that turn out are when there is abundant, indirect light. That was available in the kitchen of our last house from around noon to 6pm or so. Good light never happens in this stupid house but the short wall on the side "yard" is perfect most of the time, except with the sun at high noon.
I really need to master macro using flash.
learningcurveFoy
As this one was taken, low room light with a single Nichia 219 in a 2” keychain light running about 30 lumens. It’s also depicting a Nichia 219 in an OP reflector with Hi/Lo modes by VinhNguyen. I use a split 1 1/2” PVC pipe, drilled and tapped 1/4 x 20 to fit on a tripod. Mount that and use rubber bands to secure the light in the half-pipe so that I can direct the beam where I want it. Works beautifully. I now have a Triple Nichia 219 from EDC+ that is even better using the Med setting so that it can stay on for longer lengths of time without worry. Depending on how much depth-of-field I’m looking for, I might take 20 or more consecutive shots at 1:1 ratio .5mm apart.
This was taken with Canon’s 100mm Macro 2.8 L IS, 6 shots using a RRS macro rail to deepen the depth of field and stacked in CS5. Go ahead, left click on it then right click and select original in Flikr, see it at 100% from a 21MP full-frame sensor. :slight_smile:
That's an awesome macro.
needsmopracticeFoy
3 XM-L2 Emitters in a BTU
Click for full-size
PPtk
learning
pilot -
Wow, wow and wow.
verycoolFoy
Holy Foy! Foy’s Back!
Hope you’ve been well. Welcome back!
PPtk
Thank you,Foy,good picture,good review,
we can learn more LED on Cree website:
Cree
You don’t say! I don’t think anyone ever thought of looking for information on Cree LED’s on Cree’s website.
Genius, I tell you!
PPtk
Hello PPtk,I just give a advise,
No worries. I have a sarcastic sense of humor, that’s all.
PPtk
:smiley:
Just so you’ll know? The guys at Cree can probably learn a few things about their own product from PilotPTK. Look at his build thread on the bumper mount light bar he made for his own use, designed to the nth degree and so much better than store bought models they should hang their heads in shame.
And now you know.
Welcome to the forum.
pilot -
stillaughingFoy
Thanks for your help. I also neededthis information.
