I’m getting back on mine tonight, drivers have turned up today.
Richie, did you just file the pill down a touch to get the focus?
I’ll post up picks of the drivers sat in the pill, one is 5a hi-mid-lo-strobe. Not ideal but its only 12mm in height so may drop in there. The other may need to pill extending to suit.
2cgr18650ch at 8.3V static, were sending 3.75A through my crappy test leads (drives me nuts that I haven’t come across the homemade 14ga leads I made w/ silicone wire).
The upper board would not fit in the pill. I trimmed the excess (the rough parts where the boards are connected to each other in a sheet when manufacturing) and then the upper board fits in the pill but only to where the inside threads end.
That is actually far enough to get the bottom board to touch the pill, but in all likelihood the upper board would be shorted to the pill.
so, I just finished taking the dremel sanding drum to the inside of the pill. Brass is so much easier to sand than aluminum!
The upper board now fits with a slight gap all the way around. It only went about a mm farther into the pill, then the largest component of the upper board touches the inside/top of the pill.
I will pot it, just to be sure it can’t short, and because ma_sha reported heat problems with the driver in the lck-led review page.
I wish I understood electronics enough to say for sure, but I suspect this driver isn’t truly buck/constant current.
The reading I took is roughly 30 watts - which is pretty close to an sst-90 at 9A (I’m not sure how much the Vf goes up). If I’m right, I should get 5 to 6 amps to the MTG2.
If not, then I’ll be reporting back (probably tomorrow night) that I have destroyed the emitter 8)
Its the one on the right. Mtg-2’s and xp-g2’s for comparison.
I removed the standard contact board, here you can see the driver sat in the pill.
I shredded the thermal pad to push in around the driver, potting is still an option if it becomes necessary.
I then fitted the retaining ring, adding a little protection to a component I thought may short. The ring went in upside down with the recess to the outside of the pill and a 21mm contact board was soldered on top to carry the spring, not pretty but functional and no chance of careless battery fitment smashing the driver.
I cleaned up the excess solder, built the light back up and its good. I’ve not tried filing the pill to drop the reflector yet, I want to try it as is for a while and then decide. It certainly looks like a usefully bright beam, shocked mrs gords when I showed her, I started on low, she was not impressed with my efforts, flicked it up to high and she was stunned. :bigsmile:
Just checking all your great photos. Looks like you’ve been busy and I’ve missed some things around here…LOL. Yeah, I used a table top sander very carefully and removed just about 1mm on the top. This allowed the reflector to sit closer to the base of the mtg2. I haven’t decided yet if I’m going to try removing a bit from the actual base of the reflector. But focus could still be slightly better.
BTW…with all those photos and great components, you are a tease!
Besides, you wont like that driver. It has strobe :Sp I only ordered it because its 12mm high it’d almost fit a c8…or an m10….but could be interesting if I can fit it in a trustfire t1 with an xm-l2 on a sink pad or a 3d mag light on a custom heat sink with 3 × 26650/32600…
Maybe in a month or so, got to tax and insure two cars and mot one next month, I really need to sell my zuk. The cool down period will let me mull over what to do too. Maybe build something tosell, get some funds back.
Sorry for the delay. Originally the ceiling bounce at 1 meter was 460 lux. After I performed the pill shave, this resulted in a slight increase to 550 lux. This was actually higher, but that’s at the point it started to settle at.
I literally have the 5A driver and MT-G2 sitting in the pill waiting to be potted and fujik’d but havent had the time to finish it.
The I-O 5A driver needed a lot of sanding and caressing to get into that pill.
Perhaps tonight.
My test runs leads a much warmer tint than the beamshots posted. I hope im doing it right. Perhaps because of almost no thermal transfer during the quick test?
Excellent you are so close to getting it going. I’m sure your tint is right. I believe this mtg2 should be rated at 5000k on the money, or close to it. It’s perfect for me because I’m a 4300k-5000k sort of guy. Hopefully you’ll love the excellent color rendering you get from it.
I got her all put together - de-domed mtg2 on (aluminum) sinkpad, potted 9A driver.
The sinkpad is the perfect thickness. I used a thin insulation disc just to be safe.
6A at the tail at turn on, and that quickly drops to 5A. These panasonic cgr18650ch are rated 10A max discharge. good 26650s might maintain that current.
I tapped the pill and I’m using nylon screws, but I think I’ll switch to steel and nylon washers so that I can be sure the emitter is tightened right down hard.
I’m getting ~20k lux@1m at turn on, dropping to 15k at 30 seconds and staying there. Spill is still very bright.
Holy cow that driver is really putting out! You really need to post some beam shots. It must be amazing at that current. I’ll bet with good 26650’s in there, amps and lux will maintain much higher than it is.
I used my bench sander with fine paper to remove a small amount of aluminum material from the base of the reflector so see if focus could be made even tighter. It had no effect from what my eye can make out. So I’d have to say it’s as focused as the Torchlite reflector will allow.
It’s easily one of my favorite lights and I love using this thing. I hope the rest of you have as successful a build.
