You are paralleling current sinks so each chip will adjust its internal resistance so that it sinks its setpoint current - with these chips you can get integer multiples of 0.35A. For in between values you can shunt this parallel network of ICs with a resistor.
There is another issue and that is the ‘compliance’ of the current source.
What he said. Where ever you buy the driver should have info on star connection/mode selection. If they dont, buy elsewhere. The last thing you want to do is swap a driver and STILL be stuck with blinky modes unless you have to be.
Thanks pyro for the rev protection note, forgot that little tidbit
As for the mode selection, if you buy the two group version, the stars have no effect on functionality. Only the four group version uses the stars.
confused a bit. Dimbulb didn’t say even integers only so isn’t he correct? Since integers are simply whole numbers 1 x 7135, 2 x 7135, 3 x 7135, etc. these produce integer multiples of .350 A. Feel free to give me the face rub if this is not so.
Sorry, the main reason I thought it was so funny is because years ago I had a boss that was a retired supply seargeant, he’d get pissed and do a seriously wack face rub that required him to remove his glasses. “Dale, I’ve seen everything from a Jewish wedding to a Mongolian goat f*#k and I have never seen anyone do things the way you do!”
I worked with another carpenter I nicknamed machine gun Kelly for his penchant for shooting up trim(much to the dismay of the painters). I never could convince him to lay off the trigger a bit.
I took it to mean you can multiply .350A by any integer value, eg. .35A, .7A, 1.05A, etc., which is precisely what happens.
I’m ultra gullible so it did not even occur to me that Pilot was fooling with him.
