NOW 70% OFF COUPON!! DIY TorchLite 2x26650 XM-L, SST-90, SST-50 etc Host!
476 posts / 0 new
Richie086
Richie086's picture
Last seen: 51 min 37 sec ago
gords1001 wrote:
Thought so. I’ll possibly order the enerpower cells in April. I think the exchange rate and shipping kills them for you guys. I know they tested well for hkj.
Yeah, I really wanted to order 3 of these cells to use in my Skyray 9xT6 or AK-47. I’ll have to wait until they are sold by some US sellers or non-fake versions from China.
Richie
Richie086
Richie086's picture
On Friday I placed an order with Jason from EDC+ for some high output MNKE IMR26650 3700mAh cells. Although unprotected, they are IMR, so they are pretty safe batteries to use. Over at CPF, I’d seen them push these upwards of 9a or more and have received excellent reviews.
I’m going to use 2 in my Torchlite, which work great in by the way, and the other 3 in one of my higher current lights. All charged fine to 4.2 volts and are already in service.
Jason somehow got these batteries here so fast, I had to look out the window to see if they were actually being delivered by the postman, or if Jason had his running suit on delivering them himself. Great job Jason, and as always, thanks for the great service you provide to the forum.
Here is the link to the cells: http://edcplus.com/mnke-imr26650-3700mah-p-5.html
Richie
gords1001
gords1001's picture
Last seen: 2 years 8 months ago
They look pretty good Richie, same problem for me as the enerpowers for you though. By the time I bought two, paid the shipping, paid the import duty and “handling fee” |(
I could have the enerpowers. 8)
Richie086
Richie086's picture
I think I was a bit lucky with the Enerpower 26650’s and to also get them with 9amp PCB’s. They charged me 7.50EUR’s shipping, but some of that shipping was due to some type of shipping container for each battery. Either to protect the cells in transport, or to satisfy customs, or perhaps both. But I feel your pain too.
Richie
Richie086
Richie086's picture
Hi folks,
I wanted to see if I was able to get better focus on my Torchlite, so I removed the pill and star from the light. I shaved just less than 1mm from the top of the pill where the reflector actually sits in contact with the pill. I did this in order to get the mtg2 LED to sit further into the reflector. In fact, it’s about as far as you can get it now. I put everything back and compared it to the previous beamshot. I was able to see a more defined clearer hotspot. With the size of the mtg2, I’m doubtful it can actually be made into a very tight narrow spot beam unless a reflector is designed for this emitter. Still, I’m happy with the final result, if only subtle.
Previous Torchlite Beam Shot
Latest beam shot with less than 1mm shaved from top of pill at reflector seat.
Richie
ImA4Wheelr
Last seen: 6 hours 40 min ago
Thanks for the great beam shots Richie. That pill shave really made a big difference.
EDCPlus
Last seen: 1 month 1 week ago
Dang that looks quite a bit more focused. Do you have any lux measurements before and after?
gords1001
gords1001's picture
I’m getting back on mine tonight, drivers have turned up today.
Richie, did you just file the pill down a touch to get the focus?
I’ll post up picks of the drivers sat in the pill, one is 5a hi-mid-lo-strobe. Not ideal but its only 12mm in height so may drop in there. The other may need to pill extending to suit.
dthrckt
dthrckt's picture
Last seen: 5 days 7 hours ago
wow, that made a big difference
sinkpad mtg2 pcbs should be about that much thicker.
I finally got de-doming right, on the third try, and then I reflowed it to a sinkpad, so I’m waiting for a driver to arrive and i’ll have 1 done.
____________________
Girls can shoot!
gords1001
gords1001's picture
Muh hahahahaha haaaaaaaaaa :bigsmile:
How does 3.12a at tailcap, no pill mods and 3 mode with memory sound? 8)
dthrckt
dthrckt's picture
which driver, the lck-led 5A?
I just tested the IOS 9A driver.
2cgr18650ch at 8.3V static, were sending 3.75A through my crappy test leads (drives me nuts that I haven’t come across the homemade 14ga leads I made w/ silicone wire).
The upper board would not fit in the pill. I trimmed the excess (the rough parts where the boards are connected to each other in a sheet when manufacturing) and then the upper board fits in the pill but only to where the inside threads end.
That is actually far enough to get the bottom board to touch the pill, but in all likelihood the upper board would be shorted to the pill.
so, I just finished taking the dremel sanding drum to the inside of the pill. Brass is so much easier to sand than aluminum!
The upper board now fits with a slight gap all the way around. It only went about a mm farther into the pill, then the largest component of the upper board touches the inside/top of the pill.
I will pot it, just to be sure it can’t short, and because ma_sha reported heat problems with the driver in the lck-led review page.
I wish I understood electronics enough to say for sure, but I suspect this driver isn’t truly buck/constant current.
The reading I took is roughly 30 watts – which is pretty close to an sst-90 at 9A (I’m not sure how much the Vf goes up). If I’m right, I should get 5 to 6 amps to the MTG2.
If not, then I’ll be reporting back (probably tomorrow night) that I have destroyed the emitter 8)
Girls can shoot!
gords1001
gords1001's picture
Ok, I teased long enough…
This driver.
http://www.lck-led.com/constant-current-circuit-driver-modes-p-935.html
Its the one on the right. Mtg-2’s and xp-g2’s for comparison.
I removed the standard contact board, here you can see the driver sat in the pill.
I shredded the thermal pad to push in around the driver, potting is still an option if it becomes necessary.
I then fitted the retaining ring, adding a little protection to a component I thought may short. The ring went in upside down with the recess to the outside of the pill and a 21mm contact board was soldered on top to carry the spring, not pretty but functional and no chance of careless battery fitment smashing the driver.
I cleaned up the excess solder, built the light back up and its good. I’ve not tried filing the pill to drop the reflector yet, I want to try it as is for a while and then decide. It certainly looks like a usefully bright beam, shocked mrs gords when I showed her, I started on low, she was not impressed with my efforts, flicked it up to high and she was stunned. :bigsmile:
Richie086
Richie086's picture
Hey Gords,
Just checking all your great photos. Looks like you’ve been busy and I’ve missed some things around here…LOL. Yeah, I used a table top sander very carefully and removed just about 1mm on the top. This allowed the reflector to sit closer to the base of the mtg2. I haven’t decided yet if I’m going to try removing a bit from the actual base of the reflector. But focus could still be slightly better.
BTW…with all those photos and great components, you are a tease!
Richie
gords1001
gords1001's picture
Yeah, I have a real problem now though…. I have a spare mtg-2 and 5a driver. What am I to do now? 0:)
Richie086
Richie086's picture
Sell them to me and ship them over to the USA :bigsmile: I’m going to risk putting a huge emitter like that in my Digital Projector Spotlight.
Richie
gords1001
gords1001's picture
Mmmmf yeah, there’s that sst-50 host to try out….
gords1001
gords1001's picture
Besides, you wont like that driver. It has strobe :Sp I only ordered it because its 12mm high it’d almost fit a c8…or an m10….but could be interesting if I can fit it in a trustfire t1 with an xm-l2 on a sink pad or a 3d mag light on a custom heat sink with 3 × 26650/32600…
Richie086
Richie086's picture
Go for it. You shouldn’t waste those components. Toss them in the SST-50.
Richie
gords1001
gords1001's picture
Maybe in a month or so, got to tax and insure two cars and mot one next month, I really need to sell my zuk. The cool down period will let me mull over what to do too. Maybe build something tosell, get some funds back.
Richie086
Richie086's picture
Hi there Jason,
Sorry for the delay. Originally the ceiling bounce at 1 meter was 460 lux. After I performed the pill shave, this resulted in a slight increase to 550 lux. This was actually higher, but that’s at the point it started to settle at.
Richie
FMcamaroZ28
FMcamaroZ28's picture
Last seen: 14 hours 13 min ago
I literally have the 5A driver and MT-G2 sitting in the pill waiting to be potted and fujik’d but havent had the time to finish it.
The I-O 5A driver needed a lot of sanding and caressing to get into that pill.
Perhaps tonight.
My test runs leads a much warmer tint than the beamshots posted. I hope im doing it right. Perhaps because of almost no thermal transfer during the quick test?
Richie086
Richie086's picture
Perhaps tonight.
Hey FM,
Excellent you are so close to getting it going. I’m sure your tint is right. I believe this mtg2 should be rated at 5000k on the money, or close to it. It’s perfect for me because I’m a 4300k-5000k sort of guy. Hopefully you’ll love the excellent color rendering you get from it.
Richie
dthrckt
dthrckt's picture
I got her all put together – de-domed mtg2 on (aluminum) sinkpad, potted 9A driver.
The sinkpad is the perfect thickness. I used a thin insulation disc just to be safe.
6A at the tail at turn on, and that quickly drops to 5A. These panasonic cgr18650ch are rated 10A max discharge. good 26650s might maintain that current.
I tapped the pill and I’m using nylon screws, but I think I’ll switch to steel and nylon washers so that I can be sure the emitter is tightened right down hard.
I’m getting ~20k lux@1m at turn on, dropping to 15k at 30 seconds and staying there. Spill is still very bright.
Girls can shoot!
Richie086
Richie086's picture
Holy cow that driver is really putting out! You really need to post some beam shots. It must be amazing at that current. I’ll bet with good 26650’s in there, amps and lux will maintain much higher than it is.
Richie
dthrckt
dthrckt's picture
yes, but I’m wondering if the emitter will survive
the driver is completely potted to the pill (but can be removed), so if the temperature step-down in the driver works, it should be relatively safe.
i took pictures of the mods, I’ll post them tomorrow evening.
I’ll try beamshots too, but for now I can tell you, it certainly has no trouble illuminating my entire backyard lol
Girls can shoot!
Richie086
Richie086's picture
I’d say you have the hardest driven and brightest MT-G2 LED out there. Another first for BLF Big Smile
Richie
Richie086
Richie086's picture
I used my bench sander with fine paper to remove a small amount of aluminum material from the base of the reflector so see if focus could be made even tighter. It had no effect from what my eye can make out. So I’d have to say it’s as focused as the Torchlite reflector will allow.
It’s easily one of my favorite lights and I love using this thing. I hope the rest of you have as successful a build.
Richie
ImA4Wheelr
Finally got the Manafont "3T6" driver. The perpendicular circuit board is epoxied to the battery board. The epoxy covers several of the components. Fearing I would render the board useless, trying to separate it, I resigned to installing it in the pill (instead of in the space around the reflector. To build the depth of the pill, I cut a .25" length of 3/4" copper pipe coupler and pressed it into the pill. It was pressed to the shoulder that is the threads terminate at. Here is pic with the extension press in, the driver, and the driver in the pill.
Although this route gives more than adequate space for the wiring and driver (driver was not changed), I would not recommend this much of an extention. In order to fit my protected cells, I had to not use a battery spring on the driver and had to switch to a small P60-type spring on the tail cap. Even with that, I can barely tighten the tail cap enough to work. For the emitter side, I used a copper slug to bring up the emitter to the base of the reflector. I soldered the slug and copper sinkpad to the pill. Used a XM-L2 T6 3C. With the cells charged to 4.17V, current at the tail was 2.86A. This number sounds high to me because I thought this driver was a 4.5A driver. With this set up, this light out throws my Defiant Super Thrower (10 7135's, XML U2 NW, Parellel 18650's), my ZY-T08 (stock), HD2010 (11 7135's, XML U2 NW). It only out throws them due to the higher current. With the same current, the others would out throw this light. That being said, I would prefer this light to those in most situations because the throw is already more than I need and the profile is very nice. The great thing is that the transition from the "hot spot" to the spill is so smooth that you get a wider long-distance viewable area. To me, the hot spot is not discernible when looking out far. I live in a very thickly wooded area and I can peer deeper into the woods with this beam profile, because I don't get blinded as much by near by trees as I pan the light
MRsDNF
MRsDNF's picture
Last seen: 3 hours 16 min ago
Ima4Wheelr. Personally Ima2Wheelr type of guy.
I love your creativity here. Does this driver have mode memory and from memory it was only 3 modes, high, med and low?
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
gords1001
gords1001's picture
Nice job ima4wlr, I’d add some braid or wire to the tail spring if you have not already, just so that the spring purely provides clamping and not current path. I really liked mine with an xm-l in it, the mt-g2 just provides a huge smooth beam. I like it, just its not a wow light to the uninitiated. Its subtle.
