wow that just makes the cool factor move up a notch. i seriously didnt think you were gonna say yes , turned on for 2 years straight. thats unbelievable. and it doesnt get hot in your pockets or the light itself?
yea it has been pretty quiet at fnf. lamda hasnt posted anything new for a while. i always check back for updates for the vpt’s.
Shouldn’t be hard. The internal resistance of the cells should limit current nicely. Which is why Fauxtons work for more than a few milliseconds.
Get the highest efficiency 5mm LEDs you can. You should only need a few tens of microamps current to drive the good ones. Blues are probably the most efficient. But the human visual peak is in the yellow-green area. So those will give more perceived output for a given current and efficiency.
Just make sure you don’t short the cells in the container. Insulation is your friend
Years ago I bought a dirt cheap bag of assorted LEDs - including the world’s dimmest green LED - your typical keyboard LED is about 100x brighter. Unfortunately the efficiency is woeful.
Yeah but these stay on for ‘years’. Some of mine were built in 12/11 and are still running the original batteries. When I get up in the morning i can find my keys without even looking for them because they are glowing green. My GF has a green and pink on her keys. I used to think tritium was the way to go, and there are some instances were it’s definitely the way to go like watch vials and gun sights. But in this case it’s way brighter and replaceable and still lasts for years. It’s hard to convince nonflashoholics how cool something is like this, but when people are like, “your light is on.” Then you are like “It’s ok it stays on for years.”
BTW I do mean to get to Home Depot to get a couple of the new Cree bulbs. I think they are 12.49.
Just a heads up, Lambda says the nano ones should be ready next week Still been super quiet over there and the administrator has been quiet for several weeks. I know they just renewed the domain then nothing. http://flashlightnews.net/forum/index.php?topic=2897.0
I might pick up one of these to check it out. The ones I’ve been using on almost all my keys have been great. I try to keep my keys in the same spot when I get up for work, but they are so much easier to find when they are lit up.
Not heard anything yet about another build. I received one from the Nov build with the top bin SBT90. I see the price on that LED has come down, like they all do. It was 79.99, DigiKey . This is still the most impressive LED light I’ve used. JMPaul measured his VPT3 @ 364K Lux, I believe. 1,538 Lumens at the rated 9A, only thing though these are driven at 13-16Amps, so I think emitter lumens should be more than 2000! I’ve manage to pull together quite a few of the Lambda lights. I believe right now I have 16 Lambda lights; Five of them are VPTs ( 1 SBT90, 1 Dedomed SST90, 1 SST90, 1 XM-L, and 1 XP-G2) and 3 of them are Hydra multiXML (2 3XM-Ls and one 4 XM-L), 12 of them have the VaraControllers and the 4XML Hydra has the VaraLevel. The others are single mode c and D low voltage/high current XM-L mods.
Really good stuff and that’s why I get it and every iteration has been considerably better than the last. For instance, this,(L) is a copper bonded DeDomed SST90 regular Varapower V the (R)VPT3 SBT90mb. The Light on the left still has an OTF lumen of around 1700 and will be impressive to lots of people. I doubt the Olight SR95UT was using this flux bin (MB) since it is considerably more expensive.
But I don’t know any lights that come close to the LUX at even 1/2 the output.
the price on the nanos is $15 each and 12.50 if you are a FNF member (source - lambdas post)
the only thing that would get me to sell my VPT3 sbt90 mb would be a VPTX XPG2 @4amps with aspheric option
my VPT3 puts out about 75% the lux as my TN31MB with a hotspot nearly twice as big, and the aspheric setup is nice also - makes quite a nice LARGE square beam
How long does a standard fauxton led light up until its totally empty?
I have one of my old ones with blind led switched on after seeing this threa(50 hours ago) and it still is burning…
quite a collection of lamda lights you got there lawallac!
prolly gonna order 2-3 of them nanos, but what sucks is, i couldnt register to become a member at fnf and that was 2 years ago.
i could have gotten these nanos with that discount haha
FWIW I made the Flashlight News logo… on cpf i went by nemul, lumen backwards. if you look (zoom) on the head of the flashlight in the logo you will see “nemul”
