The bolt is how I chuck the brass sleeve into the drill press. A hack saw blade screwed to a 1x4 block w/2mm of the teeth hanging over the edge and another block to raise it above the nuts. 1/2 crank per fin on the small ones and progressively more for the zoomie sleeve. Here’s how they look installed.
And
I think mum will be pleased and the delivery notice for the batteries came in the mail today so it and the Blues Bros will be shipping out soon. Everything works on the zoomie, modes etc and the beam comes to a fairly good focus(square die but with rings and artifacts). I turned the lens around and this smooths the beam out and virtually eliminates the rings. However, it is not quite as floody when all the way in. More like a spot to medium range. I have several of these lenses and I have one set up on the end of my “lathe” bolt with a sleeve to center it and I’m going to try and change the sphere radius and see what that does. The bezel is not glued on to the head yet and once it is there’s no changing this lens so I’d like to experiment while I can. Since this will change the focal length it will likely change the image at both ends but I need the data anyway.
I’ll post beam shots when I can show a comparison of the modded vs unmodded lenses.
Here it is again after about an hour and a half of spinning it on a file, various grades of w/d sandpaper, and turtle wax lens clarifying compound(brass sure polished up well!). I tried to match the former image angle to show the difference.
I’m not at home to check it out until Sunday evening.
Chloe, as long as I’m “prototyping” I figure I might as well try a few different ideas in one light rather than mess up multiple hosts. This used one I picked up on the cheap with another light on Fleabay so it made an ideal host for some new ideas. The driver works great and the zoomie mechanism works as well but the lens needs to be tuned to the length of the threads to get much change in the beam.
Thanks DBCstm. If by talent you mean a willingness to screw up and try again then I’m your man. I have a ziploc bag full of toasted 7135’s and more than one or two LEDs from learning to reflow. Some skills elude me still. I can’t say it often enough, I would be lost without my magnifying lamp.
Is that anything like the D Mag aspheric lens I’ve got laying on my nightstand?
Yeah, we’d make quite a team creating Bar-B-Que electronics for the avid DIY’er. I’m learning though. You guys make me take leaps which of course creates more Bar-B-Que which then leads me to take more leaps…it’s an addictive sport for sure! lol
The difference is, you manage to pull it off and make it look good!
Edit: RufusBDuck, I hereby officially offer up my photography skills to better display your glorious work!
I like it Jack. The highest form of praise is not imitation but immortalization by Jack. DBCstm thanks but there’s a reason they don’t broadcast home improvement shows in HD. My work looks better to the eye than to the camera. The defects inherent in hand made work just aren’t as sexy as nice millwork. Believe it or not, I took several shots of each image using different lighting and selected the clearest for posting. Look for a pm if I ever get it right though.
I’ve seen your images. That’s not cheating, it takes skill, knowledge and a lot of work to do that. My qualm is that your skills would make my efforts look worse instead of better and my vanity is arm-wrestling my honesty for publishing rights. If you ever end up with one though, feel free to display it as you please.
OL, I don’t just do miniscule but I do like the challenge and if I can imagine a solution, I’ll probably try it. As you have said, it’s probably been done before but we can all try to add a new facet to the forum.
OL, I’m not enjoying the challenge as much right now.
Statements complimenting my competence seem to be undeserved. Stubborn? Damn straight!
Playing around with trying a different aspheric shape(reground to a smaller radius) I was getting erratic operation and then only high mode and thought “crap” there goes a driver and about 10 hours of work.
diagnosis: intermittent ground shorts from driver solder points to battery tube along with a short from led- wire to gnd(loose wire bypassing chips).
I desoldered the star and pried the two pieces apart and even unsoldered the led- wire came away with the led half instead of the driver half. Then came about 3 hours of painstaking work with an exacto knife carving away at Fujik. How can such a small amount make such a big mess? I cleared the chips and edge of the driver and used solder wick on my ground points then pulled the ground disc and chips off the IC board. More time scraping Fujik and then comes the fun part, relocating 3 smd parts further from the edge of the board. First up was the cap. I desoldered it, scraped the input trace clear of solder mask and removed a portion of the output pad along the edge of the board and resoldered it but this time right up against the IC. The input diode I was able to just slide over against the IC, again carving off any trace copper that might short to the battery tube. And lastly, the resistor. Since it is so thin I had hoped to just stand it on its end and solder it between it’s input side and the ground disc but it’s a bit longer than the height of the IC so I ended up soldering it to its input pad at about 30 degrees from vertical. The other resistor I just nudged one end a scosh. Now having cleared the edge of the board of any possible shorts I can resolder the led + wire and put it all back together, ground solder, Fujik and all. I also need to relieve the hole in the battery tube a bit more as the sleeve around the 7135’s was too tight. After all this I would not be in the least surprised if all those poor little smd components had en mass decided to pack it in but I’ll know when it’s done( I should wire this board straight to an led to see if the modes and memory work and get the optic sorted before I put it together again. Maybe, maybe not. This was all day before yesterday and I don’t go home ’til tomorrow night. I’ll post pics then of the changes I had made along side a similar board for comparison. It’ll be ugly but from more than a few inches away who can tell and who cares.
Repair notwithstanding, I haven’t decided what size hammer to use if this doesn’t work. In the past I’ve used a 20 oz waffle head framer for good aim but if I use an 8 lb sledge my aim won’t need to be so good.
+10000% Mr duck except for the accolades I dont know you from a bar of soap but if I may offer some advice as I reckon I may be just a little older. If you have a wife or girlfriend lose them. Go and find another and get a life. This project is not a challenge in stubbornness.
It hurts others to read this thread. Please, I beg you, As a forum friend get a life.
PS. Tell me the secret on how to make the above advice work when your all better as I know someone else nearly as bad as you. Thanks and Cheers.
Thank God Thomas Edison was like RufusBDuck and wouldn’t give up or we wouldn’t have had light all those years!
I think it goes beyond stubborness, into a realm of self-justification. Once the idea is spawned and the body feels capable then it MUST be completed to preserve ones self-confidence. This develops further abilities as well as the passion to go further, to go “Where No Man Has Gone Before!”
And this is why technology is advancing. People proving daily that it CAN be done!
Thanks for the hard work and the detailed explanations of the continuing saga of SMALL.
Soap? Who has time for a bath? As for many of us, SHE doesn’t understand why I do this and there are times when I wonder myself. I don’t have time for many of the things I would like to do, but when I choose to do something I go all in and see how far it will go. Obsessive compulsive disorder might be confused at times with tenacity but regardless of whether I’m driven or driving the end result has already been seen. The frustration comes from the physical inability to get my hands to to what my brain can clearly see needs doing. The hammer is my hands telling my brain “bugger off, I’m doing the best I can”. Know thyself is lifetime study. Losing ones temper is just a failed quiz.
here above we are witness of stage 7 of the flashoholic: trying to get into the deeper philosophy of flashoholicism and its connection to life in general :-)
