RaceR`s BLING 14500 P60 light. Started out as a crappy 4.70$ light.
Thanks for the nice feedback guys!
No blisters. I let my dremel do most of the work.
Sat out in the sunshine, music on the ears, googles on my face, and the sound of the dremel in the background. To avoid getting bored/tired with the job I divided the polishing work between three days. I did get a a decent amount of polishing compound in my face though. :slight_smile:
I could have been easily done in one-two stints, but I did it in the more “chillaxed way”
Ah, so that is where all the nice weather has gone: way north from here. It's been cold and windy for weeks in a row here.
I have no idea what has gone right with the weather lately.
I live outside one of the “rainy” places in Norway. Bergen city.Its know for lots of rain and lots of clouds.
Well, not lately! And not in the near future either!
Seing a weather forecast like that is extremly rare on this time of the year.
Its extremely rare here in general! :smiley:
I spent two summer months outside Bergen in 1960. Was nine years old and do not recall all that bad weather you tell us about. :wink:
Wow, RaceR, that´s very nice. I really love to see mods of cheap lights!
I bet that body feels quite smooth, right?
Now you just need to get your dremel again and engrave “RaceR” to the middle part
Bergen is known to be the rain-city of Norway. Ask any Norwegian which city have most rain. They will probably all say Bergen.
Even Wikipedia agree:
Tripadvisor:
As I mentioned it as a bit better outside Bergen. As always, there will naturally be several days, weeks, or sometime months with decent/nice weather too. :slight_smile:
Smooth as a baby butt! :wink:
I considered engraving my initials or something. But my handwriting sucks, so Ill just keep it clean looking. Dont want to ruin it. :wink:
I wouldn´t ruin it :stuck_out_tongue:
Go check dafont.com, look for a nice font, print it in correct size and use carbon paper to get the font to the lamp and egrave that.
I´ve used that technique to get a name on a big brush/comb for my ex gf. Worked very well.
Thanks for the tip!
Ill look into it! :slight_smile:
The polishing makes it!
You saw where my questions was going . . would love to see if this could be almost as simple as a match mini. Especially if the host can take the mods instead of the drop-in.
Racer should really announce a Giveaway cough
Ill show you the problem if you want to assemble it with a stock P60 reflector.
You see the threads that hold the bezel. If you would open up the front of the head enough for a stock P60 reflector to fit inside. those bezel threads on the head would not have much behind them.
Now, if you use the stock reflector (pictured) I can screw on the bezel 97%. There is a tiny, tiny gap. So if the glass lens was glued onto the bezel from the front, the P60 reflector could remain stock. The bezel would hold it the P60 nicely in place. But I prefer to not glue anything. And I don’t like gaps, even if they are tiny.
hehe… Ill take that as a compliment… :wink:
Once I finished the mod I was thinking that the day I reach 1000 posts (it will probably come some time, I have been active here lately) I can make a giveaway. But most likely on a black one with some nice parts… :wink:
The polished 1. edition is mine. Not sure if I will bother polishing another to that type of finish.
Looks great, you did an excellent job on it. Love it, makes me want to try one myself but I’m going to have to rent a storage building if I keep ordering lights. :wink:
On the other hand, if it was a giveaway, and I won, well, that’d be different! lol
What was the on stock led of this light?
Straight from DX:
Emitter: LED
Number of Emitters: 1
Voltage Input:1.2~1.5V
Battery Configuration:1 x AA (not included)
Circuitry:No
Brightness:50lm
Runtime:10 hours
Number of Modes:1
Mode Arrangement:Steady on
Mode Memory:
Switch Type:Forward clicky
Switch Location:Tailcap
Lens:Plastic double convex lens
Reflector:No
Strap IncludedYes:
Others Features:20 meters lighting range; Water resistant
Not sure what it was. Something really crappy.
I believe it looked just like a typical LED.
Usually, I keep most parts from flashlights. Just in case… But that LED went into the thrash right away.
Edit:
Its a reverse clicky. Not forward clicky (like DX specs say)
Thanks for feedback Dale. Appreciated!
I know his is old but hopefully some of your guys are sti checking in on it. I have some 14500’s I no longer have use for and I was considering this project and putting a UV drop in I have in it. I have a buddy who can turn the body for me no problem but I don’t know how he’ll feel about doing the reflector because it’s easier to damage. Would it be possible to sand down the front of the reflector instead of turning it on the lathe? I know it would be a lot more work but is it doable?
Full size P60 droping, 17mm driver?
Very nice build!
Looks fantastic!
Possible, probably. I would not recommend it though.. The reflector should be narrower than stock too if I remember correctly.. It would be a lot of sanding..
